Sais Limp mode
Discussion in '2.5 Gen Tundras (2014-2021)' started by Ryan911, Jan 22, 2025.
  1. Jan 22, 2025 at 7:30 PM
    Ryan911
    Ryan911 [OP] New Member
    Ryan
    2010 Tundra sr5 crew cab
    Hewitt bypass kit
    Have a 2010 tundra with 130000 mile . Hewitt bypass kit installed with Hewitt sensor bypass. Check engine light is on trac cntr light stuck in limp mode installed new ecm immediately went into lamp mode check engine light came on in traction control light came on after jumping pins four and 13 with a paper clip for 30 minutes to program new ECm . Haven’t been able to get the truck out of limp mode since installing bypass kit and ecm .
  2. Jan 22, 2025 at 7:43 PM
    j_supra
    j_supra Dreamin about boooost!
    Manitoba, Canada
    2008 Tundra Limited
    20x9 Vision brawls, 285/60 Toyo at3s, Bilstein 5100s, Tint, rock warrior grille, all chrome removed. fully paint matched, HID headlights, LED tail lights, LED fog lights, Doug thorley LTH, custom exhaust, AEM filter, TRD intake pipe, Joying HU, hertz components and sub,
    Why was the ecu replaced? What fault codes is it throwing? Have you cleared the codes and do they come back? Is the bypass kit wired correctly and was the correct kit installed for the year and faults you're having?
  3. Jan 22, 2025 at 7:51 PM
    2020_Tundra
    2020_Tundra New Member
    2020 MGM Platinum
    What are getting for ODB-II codes? Hewitt bypass requires additional add-ons for the following ODB-II codes.
    P2431 – Air Flow / Pressure Sensor Circuit Range / Performance Bank1
    P2432 – Air Flow / Pressure Sensor Circuit Low Bank 1
    P2433 – Air Flow / Pressure Sensor Circuit High Bank 1
    P2436 – Air Flow / Pressure Sensor Circuit Range / Performance Bank 2
    P2437 – Air Flow / Pressure Sensor Circuit Low Bank 2
    P2438 – Air Flow / Pressure Sensor Circuit High Bank 2
    P106B – Pressure Sensor Correlation / Evap. Pressure Sensor
