SAIS Bypass for 1st gen
Discussion in '1st Gen Tundras (2000-2006)' started by jberkut4, Dec 3, 2020.
  1. Dec 3, 2020 at 6:19 AM
    jberkut4
    jberkut4 [OP] Shake and Bake
    Jordan
    Maryland
    2005 SR5 DC, 2WD
    Just got the p1445 code for my 05 DC, was wondering how many of you guys had luck with the plug and play bypass kit. seems to be a good deal, 200 for the kit and probably 200 for labor vs paying 2k to do it the "legit" way.
  2. Dec 3, 2020 at 6:34 AM
    growit
    growit New Member
    2006 Dbcb SR5
    Go with the Hewitt bypass, I installed it years ago with no issues since. Instillation is easy.
    revtune, 2006Tundra and Casper421 like this.
  3. Dec 3, 2020 at 7:22 AM
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
    revtune likes this.
  4. Dec 3, 2020 at 11:08 AM
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    Hewitt kit has been installed close to a year. No issues, no codes.
    revtune likes this.
  5. Dec 3, 2020 at 8:08 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Went with Rutech Solutions. Module and block off plates easy peasy install and no issues.
  6. Dec 4, 2020 at 9:14 AM
    S P A R K Y
    S P A R K Y New Member
    Mark
  7. Dec 4, 2020 at 12:46 PM
    2006Tundra
    Lou
    Long Beach, CA
  8. Dec 4, 2020 at 7:26 PM
    Becky4835
    Becky4835 New Member
    05 Tundra SR5 Double Cab Crew 4x4
    I have a 2005.....
    I’ve not only got the SAIS P0418/P0419 codes but also the dreaded P2445 that gets thrown secondary to having the ‘Cold Weather Glitch’.
    At the time I looked into the Hewitt option.... The 2005 4.7 had to be hard wired install.... and the add on pump proxy’s..... By the time I ordered the components my 05 had to have ... pay for it to be professionally installed.... it was a lot of $.... that wasn’t going to prevent the P2445 when it was being thrown due to its ECM glitch.......
    After 2 ignition starts... I’d be back into Limp.
    Although for a very long time my method of clearing the codes was by opening the hood... using a disconnect switch to the battery my husband installed.... that gets really old fast n the winter.... so I parked it.... and when spring hit this year... I had this thought just spring in front of me.....
    My Affordable FIX
    I went to Auto Zone..... bought a $59 Bluetooth code reader that has a mobile phone app..... It takes me a few finger swipes....and through the app I clear the code while on my way.
    Someday I might get around to the Hewitt....
  9. Dec 4, 2020 at 8:10 PM
    BoringAttitude
    BoringAttitude New Member
    2016 Tundra TRD Limited Crew Max
    K02 275/70/18 on ATX AX201, 6112's, Blah Bla
    I installed one years ago in My GX470. It worked for a short amount of time but the codes ultimately came back and would go into limp mode. The codes were cleared multiple times. In the end it was removed and proper repairs were completed and never had a problem since.
