Saggy Leaf springs normal?
Discussion in '2nd Gen Tundras (2007-2013)' started by FNG007, Mar 6, 2020.
  1. Mar 6, 2020 at 1:47 PM
    FNG007
    FNG007 [OP] New Member
    Picked up a 2013 DC SR5 not to long ago. I can see the person before me hauled some heavy stuff because the bed it pretty beat up.. wondering if my leaf springs are toast? Or are 2013 SR5s rear leafs usually flat?
  2. Mar 6, 2020 at 2:07 PM
    TheBeast The Beach
    they do get flat after a while.
    Rica25 likes this.
  3. Mar 7, 2020 at 7:58 PM
    Dirt Dawg
    Dirt Dawg "It'd be a lot cooler if you did"
    Connor
    Denver, CO
    2014 Toyota Tundra Limited CrewMax 4x4
    The PO of my truck towed a heavy gooseneck and my springs were definitely shot when I got it. Tundra springs are pretty flat in nature, but mine almost had a negative bow. Kinda looks like yours are too. The biggest tell was the ride quality (shit). Replaced with a custom set of Alcans and couldn't be happier.
    Rex Kramer and Rica25 like this.
  4. Mar 7, 2020 at 8:19 PM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    Mind sharing the cost and production time of your Alcan leaf packs? I'm in Moab off and on. It would be easy to pick them up in Junction Co.
  5. Mar 7, 2020 at 8:21 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Definitely an issue with the Tundra. The leafs are only 2.25" wide and that, I believe, is the problem. There is some development of aftermarket 3" wide leafs in the works.
    joonbug, TXTundra2722 and Dirt Dawg like this.
  6. Mar 7, 2020 at 8:25 PM
    vegas4x4
    vegas4x4 Blaaack
    Las Vegas
    2016 Black TRD CM 4x4
    :popcorn: Im curious as well. Alcans were popular amongst my friends that did alot of wheeling. I didnt even consider putting alcans on the tundra but it sounds like a cool idea.
  7. Mar 7, 2020 at 8:44 PM
    Dirt Dawg
    Connor
    Denver, CO
    I believe I paid a tad over $800 for the springs including shipping to Denver.
    As for lead times, Alcan told me 4-6 weeks, and I believe they were at my house at the end of 7 weeks. I was a little impatient at first, but shipping took a little bit, so local pickup would be better.
    I asked for 2" lift height, and spec'd 200+ lbs in the bed at all times (thinking I was gonna throw a toolbox in). I ride unloaded and still think they ride great.
    B.Ross[QUOTED] likes this.
  8. Mar 7, 2020 at 9:04 PM
    vegas4x4
    vegas4x4 Blaaack
    Las Vegas
    Thanks for the info. Seems like a fair price. How many leafs are in each leaf pack? My buddy’s ones before had A LOT, i think there was a bunch of soft leafs to allow lots of flex, but still could maintain the lifted stance (they both had lifted older toyota pickups, one was a 10” lift, one was 12”)
  9. Mar 7, 2020 at 9:19 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
  10. Mar 7, 2020 at 9:19 PM
    Dirt Dawg
    Connor
    Denver, CO
    Each pack has 8 leafs.
    vegas4x4[QUOTED] likes this.
  11. Mar 10, 2020 at 11:20 AM
    Forcefed
    Forcefed New Member
    2007 Tundra Limited
    6 inch lift, ADS suspension, Alcan custom rear springs, 46 gallon metal gas tank, Full Line-x body, Wheels with 35's, Smittybilt bumpers front and rear, 10k warn winch, custom rack.
    I would check locally first. I went to a local place and was quoted $430 for new leafs with a 500 pound increase. With install and alignment I was quoted $550. Full custom leaf for a 6 inch lift on my tundra. Plan on doing it next month to fix my driver side sag (48 gallon metal gas tank). Shop around and you might find a shop that does custom springs and they will be built and installed with full alignment for cheaper.
  12. Mar 10, 2020 at 11:23 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I have used Alcan on two different Toyota trucks, they are the best bang for your buck.
  13. Mar 10, 2020 at 1:26 PM
    Northbound Train
    Northbound Train Masshole
    Glenn
    Western MA
    Black 2016 SR5 Double Cab 4x4 5.7
    Go look at the springs on a new one in a parking lot or at the dealer, they are pretty much flat when new.
    15whtrd likes this.
  14. Mar 10, 2020 at 1:38 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    if your bed is empty on that pics then its shot.
  15. Mar 10, 2020 at 1:45 PM
    Rex Kramer
    Georgia
    Mine were replace at 270,000 miles.
  16. Mar 10, 2020 at 3:16 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    But the factory leaf spring is junk anyway. all three leaf spring is soft to give a softer ride and once you put any weight on the bed it will flatten out and ride on the overload spring.
  17. Mar 11, 2020 at 10:19 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    This is probably why mine creaks as well.. besides shocks..
  18. Mar 14, 2020 at 6:54 PM
    nuclearlemon
    nuclearlemon New Member
    wyoming
    2012 dc
