Sage63 21 Limited TRD Offroad 4x4 CM Super White
Discussion in '2.5 Gen Builds (2014-2021)' started by SAGE63, Jan 5, 2022.
  1. Jan 5, 2022 at 4:17 PM
    SAGE63
    SAGE63 [OP] Wannabe Go Fast Overlander Small Rock Crawler
    San Diego County
    Wow it has been a bit over a year since I took this home on Oct 26th 2020. guess it is time to document what I have done and what is still in progress. There are too many of you out there to properly thank for your advise over the past year so here is a THANKS TO ALL OF YOU.
    Day 1
    C4 bumper and Warn vr evo 12kS winch
    Toyo Open Country ATII 295 70r18
    Wildpeak AT3W 37x12.5 r18
    SanDiegoSlovak, the red, Jego and 7 others like this.
  2. Jan 5, 2022 at 5:14 PM
    SAGE63
    San Diego County
    So in no particular order
    Interior
    ESP underseat storage
    Seat Jackers on DS
    tech12volts jbl amp and sub upgrade
    Drivers side grab handle
    Exterior
    AMP Bumper step (removed with C4 rear Bumper upgrade)
    rubber bed mat
    Retrax Pro XR - replaced Bakflip mx4
    KB Voodoo Max Moduler 10" steel bed rack, replaced 10" risers with 14"... now 18"
    Westcott Designs Tundra Roof Rack - Thank you Jeff Westcott and Tundras to Sedona Oct '21 raffle
    Tuffstuff Alpha II RTT
    Overland Vehicle Systems 5' Awning, Replaced with 270LTE Awning
    3.8 Gal Waterport tank, replaced with 8 gal weekender
    2x 3.5 gal Rotopax gas tanks
    4x 2 gal Rotopax water tanks
    2x Rotopax deluxe mounts, 1 extension
    Bumpershelz bumper covers (removed wth c4 bumper), grill surround and hood buldge
    TRD Cold Air Intake Thanks Tundras to Sedona April '22 raffle and Sparks parts
    ROAM 83L case with Sherpa mounts
    Lighting/Switching etc
    Diode Dynamics SS12 grill light kit combo white
    Diode Dynamics SS3 SAE Fog amber
    Baja Designs S2 sport wide amber (chase lights)
    Baja Designs S3 sport combo white (ditch lights)
    Baja Designs Squadron Pro Thanks Tundras 2 Sedona raffle April 2023 w/amber rock guards mounted to bullbar
    CBI ditch light brackets
    Baja Designs S8 30" light bar combo amber
    Switchpro S9100
    Power Trays kit universal mount
    FRAC harness with camera
    secondary OEM rear camera and harness monnted to Wilco Hitch Gate Switch Swing Out
    Baja Designs S2 pro reverse lights
    rack mounted brake light
    Wheels/Tires
    METHOD 701 18 Bronze +25
    Falken Wildpeak ATIII 37X12.5R18 replaced
    Toyo Open Country AT 295 70 r18
    1/2" bumper shim (removed with C4 bumper)
    Armor
    RCI Steel engine/transmission, rear diff skid plates
    RCI LCA Aluminum skid plates
    Built Right 102" welded on rock sliders
    C4 Overland Bumper mid bar. Thank you C4 and Tundras to Sedona Oct 21 Raffle
    Total Chaos bed stiffeners
    C4 rear bumper
    Warn VR EVO 12S
    Factor 55 flat link Thanks to BYOE overlanders
    GCS transmission cooler
    Suspension
    ICON Billet Delta Joint UCAs (replaced Built Right UCAs)
    ICON Hydro Bumps replaced rear Durobumps Durobumps front
    (removed) Coachbuilder +3 shackles and shims 2 driver 1 passenger
    ICON 3.0 VS RR CDCV Coilovers and RXT 2.5 Omega series RR Rears (replaced Bilstien 6112/5160 (Highest setting) removed westcott preload collers)
    ICON RXT Leaf springs Option 3
    Jomax swaybar end links, Removed with sway bar delete
    ICON S2 Omega piggyback bypass Thanks Tundras 2 Sedona April '23 raffle $1000 in ICON gift certificates applied to purchase
    Icon 2.0 hydro bumps
    Dirty Deeds BAM 10" with Resonator (Keith is a wealth of Knowledge and happy to share)
    5.29 Revolution Regear
    BMC (@Speedfreek) Can do everything (almost) you could need!!!! reach out to him... he is on Tacomaworld.com
    diff breather relocate
    spare tire tabs cut off... to fit 295s
    Behind axle exhaust dump
    Iceco VL45 with slide
    Renogy 100w flexable solar panel mounted to RTT
    Jackery 880 and Goal Zero Yeti 1000x
    Wilco Hitch Gate Switch swing out tire carrier
    DV8 Offroad bedside rail mount stand-up tire mount
    Spare tire chain mount removed. cannot use with 37s
    Yeah lots of winnings from Tundras 2 Sedona Raffles Thanks to all the great sponsors and @KevinK for the great causes the raffle benefits Thanks to SGU folks too
    the red, bulldog93 and eccracer104 like this.
  3. Jan 5, 2022 at 5:29 PM
    SAGE63
    San Diego County
    So a call out to @memario1214 Hotshot off road great vendor.
    The Truck Shop and James Ederer I wont pretend to have done the install work myself or sourced the suspension...(Bilstein with Built Right UCA) and The Sliders
    @speedfreek for the BMC and several other jobs
    LK Technica for ICON shocks rebuild and Install
    Wheel Every Weekend suspension tuning
  4. Jan 6, 2022 at 1:12 PM
    SAGE63
    San Diego County
    Here are a few pictures...
    20220106_102915.jpg 20220106_103053.jpg 20220106_102959.jpg 20220101_164206.jpg 20220101_164232.jpg 16415030682561760016249837125283.jpg 16415032269114328144789809846560.jpg 16415033639042041781598687319734.jpg 16415034498371638166835804278218.jpg 16415034836374445819827690444809.jpg
  5. Jan 6, 2022 at 1:16 PM
    SAGE63
    San Diego County
  6. Jan 6, 2022 at 2:08 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Who did you CMC? Looks great
  7. Jan 6, 2022 at 2:09 PM
    sharkmango
    sharkmango New Member
    2014 Tundra TRD 4x4 White
    Looks really good man. That's a lot of work to do in 1 year.
    I have a question for you - and for the rest of the brain trust!
    I was under the assumption that TRD 4x4 Tundras came leveled already - or at least mine did, although I bought it used.
    Is that not generally the case?
  8. Jan 6, 2022 at 3:02 PM
    SAGE63
    San Diego County
    Jason aka Speedfreek at TW... Tacoma World
    Mater[QUOTED] and eccracer104 like this.
  9. Jan 6, 2022 at 3:03 PM
    SAGE63
    San Diego County
    The TRD Offroad Comes with Bilstein 4600 Front and Rear. Not leveled
  10. Jan 6, 2022 at 4:03 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    You've only had that truck for a year?! Would've never thought. Lookin good :thumbsup:
    SAGE63[QUOTED][OP] and Mater like this.
  11. Jan 6, 2022 at 8:11 PM
    SAGE63
    San Diego County
    Thanks Cruz....
  12. Jan 6, 2022 at 8:22 PM
    SAGE63
    San Diego County
    Flyinryank, eccracer104 and drobb like this.
  13. Jan 17, 2022 at 9:05 PM
    SAGE63
    San Diego County
    Update C4 overland bumper installed w warn VR EVO 12S, Baja Designs S8 30" light bar, Diode Dynamics SS3 Sae Fogs
  14. Jan 17, 2022 at 9:09 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    Looks good. Bumper is tucked in nice and tight.
  15. Jan 17, 2022 at 9:32 PM
    SAGE63
    San Diego County
    Thanks.... The Truck Shop does really nice work
  16. Jan 27, 2022 at 12:44 PM
    SAGE63
    San Diego County
    Latest update ICON RXT Leafs Option 3 with Coachbuilder +3 shackles
    the red and eccracer104 like this.
  17. Feb 25, 2022 at 11:43 AM
    Kantoosion
    Kantoosion New Member
    J
    SD
    Inferno Crewmax
    Yo! Is this what you have been doing? Haven't seen you in awhile. Tundra is coming out nice. Still playing the waiting game for my stuff.
    SAGE63[OP] likes this.
  18. Feb 25, 2022 at 11:43 AM
    SAGE63
    San Diego County
    what are you waiting for
  19. Feb 25, 2022 at 11:44 AM
    SAGE63
    San Diego County
    lets grab a beer and catch up
  20. Feb 25, 2022 at 11:58 AM
    Kantoosion
    J
    SD
    Inferno Crewmax
    Explore-overland Sliders since Oct
    CBI Full skid plates since Jan
    For sure! I want to see that C4 front bumper. Thinking about going for the Hybrid version.
  21. Feb 25, 2022 at 12:05 PM
    SAGE63
    San Diego County
    cool I sent you a text
  22. Feb 25, 2022 at 12:08 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    Mmmmmmm beeer
  23. Feb 25, 2022 at 12:09 PM
    SAGE63
    San Diego County
    Yeah cruzer come to SD... I have whiskey and whisky too
    eccracer104 and Cruzer[QUOTED] like this.
  24. Feb 25, 2022 at 12:17 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    Save it for T2S :cheers: although I drink practically any alcoholic beverage :D
  25. Feb 25, 2022 at 12:29 PM
    SAGE63
    San Diego County
    plenty to spare. or I will buy more...
    eccracer104 likes this.
  26. Mar 2, 2022 at 8:09 AM
    SAGE63
    San Diego County
    ok so To compensate for the additional weight up front, bumper, winch etc. After talking with several vendors including Bilstein decided to go with 700lb springs. choose the Eibach 16" springs since Bilstein does not offer a 700lb spring for their 6112 in the 15.25 proprietary spring lenghth. As it turns out there is a hiccup with the Eibach springs... the top hat ID for the tundra is 3.5" including the, lets call it, rubber bushing vs the eibach spring is 3.0"...
    TUNDRA spring ID is 3.0" on the bottom and ID 3.5 on the top to accommodate the rubber bushing.
    so I ended up putting in the Westcott preload coller in the top perch vs the Bilstein coller to regain the lift height. got most of the height back. drove it home and developed a shaking in the stearing at about 50mph. Got it alligned driver caster 1.3 vs passenger 2.1. I still have the shake but a bit less at about 55 now.
    Could the increased preload be the culprit. here is the before and after specs for the alignment. Or maybe the driver coilover just got installed a little off... wish I had the specs from before adding the westcott collers. update a rebalace of the tires eliminated the shake. 16462373692844702019357300092642.jpg
    Mater likes this.
  27. Mar 18, 2022 at 2:09 PM
    SAGE63
    San Diego County
  28. Apr 7, 2022 at 8:05 PM
    SAGE63
    San Diego County
    eccracer104 and vanthesupreme like this.
  29. Apr 21, 2022 at 6:20 PM
    SAGE63
    San Diego County
    Installed renogy 100w flexable solar panel on top of my RTT with 3M VHB tape to maintain the Jackery 880 for my ICECO VL45...
  30. May 23, 2022 at 5:10 PM
    SAGE63
    San Diego County
