Safe to replace 285/50-20 with 305/50-20?
Discussion in 'Wheels & Tires' started by mddulac, Jun 27, 2016.
  1. Jun 27, 2016 at 11:16 PM
    mddulac
    mddulac [OP] New Member
    2012 Tundra XSPX 4x4
    Looking to replace 285\50\20 with 305\50\20...Has any one done this and do they fit properly and safely? Do I need to put a leveling kit or lift on it? I have 2012 Tundra XSPX 4x4.
    Thanks for the help!
  2. Jun 28, 2016 at 5:05 AM
    chphilo
    chphilo Tundra addict
    Western PA
    285/50/20 is smaller than stock and 305/50/20 is the stock size. You should be fine as long as your wheel offset is reasonable (not too high, not too low). Do you know the offset of your wheels?
  3. Jun 28, 2016 at 6:53 AM
    mddulac
    Not sure of the offset...those are the original tires...I bought the truck off the show room floor...if I do 315, probably would have to trim out wheel wells?
    So I'm thinking that 315 would take some wheel well trimming? I am not sure what the offset is? I bought the truck off the show room floor brand new...those tires were on it from Southern Toyota mods. Correction to tire size 285/55/20...I am in Iraq so trying to do this through a friend while I am gone...
  4. Jun 28, 2016 at 6:53 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    id check the offset of your wheels before putting on 305's.
  5. Jun 28, 2016 at 6:55 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    If you're not going to get new wheels and the ones you have right now are stock, I'd probably get some wheel spacers. 305 and 315 would probably hit the UCA.
