Safe location for a 2016 Crew Max 40/20/40 front seat
Discussion in 'Guns & Hunting' started by Sam74, Jul 11, 2019.
  1. Jul 11, 2019 at 9:31 PM
    Sam74
    Sam74 [OP] New Member
    Sam
    2016 Toyota Tundra CrewMax
    None
    Does anyone have a gun safe in the front or rear seat area for a Crew Max with the 40/20/40 front seat configuration?
    I do not have the center console because of the front seat configuration. I've seen the long gun storage for the rear seats, but they raise the seats 3".
    Any advice or products?
    Thanks,
    Sam
  2. Jul 14, 2019 at 2:47 AM
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
    locker down safes makes one for the bench seats
    Tundra234 likes this.
  3. Sep 27, 2019 at 6:20 PM
    FancyPants
    FancyPants Not my Husband’s truck
    Amber
    Oregon
    ‘19 SUPER WHITE Platinum Crewmax
    I just had a safe installed under the back seat of my crew max. Even my thinnest gun case wouldn’t fit under my seat with how little room there is. Since there is a dead space underneath the truck with it being raised so much there, it’s a perfect spot to install a small safe. Not gonna be helpful if you are needing one for a rifle, but for a small hand gun it’s doable.
    07BCD28A-7166-4CEE-9DF2-9C468DD0FAD9.jpg 685AECE6-EF48-47CB-A580-544585DC06A2.jpg
    equin, hitech and Voyagermike like this.
  4. Sep 27, 2019 at 7:51 PM
    Sam74
    Sam
    None
    Nice, looks like a clean install. Do you know the dimensions of the safe? Or do you have the make/model of it?
    Thanks,
    Sam
    Voyagermike likes this.
  5. Nov 28, 2019 at 2:15 AM
    Tiamat
    Tiamat New Member
    2015 tundra crewmax xp
    Locker down makes a great long gun storage, the crew max version requires lifting the back seats 3” and it has one door not two like the extended version which allows quick access to firearm from the drivers side . The crewmax version requires having both seats up to gain access to interior of box. And the biggest issue 1250.00!!! (Not sure if comes with an ar15 an 1k rounds in it) just kidding, its a serious security box, but it is expensive!
  6. Nov 28, 2019 at 8:11 AM
    Sam74
    Sam
    None
    I found a similar product at esptruck.com.
    It’s aluminum instead of steel and the seats don’t get raised three inches like the locker down product.
  7. Nov 28, 2019 at 9:39 AM
    Tiamat
    Tiamat New Member
    I looked at that one too. It has two Things that Im not sure of. The biggest one is that it’s made from aluminum. Second, it as a single cam bolt for lock in each section.
    I worry that even a smash and grab guy can use a hammer and pry open the edge gaining access to the rifle inside.
    The fact that in rests inside the void area is genius!
    Man I would love see this product in 10 gauge cold rolled steel with separate compartments to facilitate a three point lock utilizing steel rods. Like cabinets.
  8. Nov 28, 2019 at 11:08 AM
    Sam74
    Sam
    None
    I agree, the aluminum is the reason I haven’t bought it yet. The locks could be modified but for that price, still looking for other products. I haven’t found anything besides the ESP and lockerdown safes yet though.
  9. Nov 28, 2019 at 3:46 PM
    FancyPants
    Amber
    Oregon
    Sorry that I never did reply to this. Here is the make/model. (The smaller of the two)
    equin likes this.
  10. Nov 29, 2019 at 4:58 AM
    Sam74
    Sam
    None
    Thanks for the reply, will check it out.
