"Sacred"
Discussion in '2.5 Gen Builds (2014-2021)' started by JonasSacredTundra, Mar 26, 2014.
  1. Mar 26, 2014 at 8:05 PM
    JonasSacredTundra
    JonasSacredTundra [OP] New Member
    Well I finally decided that I will "blog" or just put my build here. So - this is a 2014 SEMA Build and I will start slow on the posts updates.
    Black 2014 Crewmax SR5 4x4
  2. Mar 26, 2014 at 8:07 PM
    JonasSacredTundra
    Everyday around here has been like christmas, starting off with the best of the best for what I wanted. No Fine Print - BDS 7" Suspension with FOX Coils I can't thank both of them enough for being part of the build - making my dream come true. IMG_2509.jpg
    csuviper likes this.
  3. Mar 26, 2014 at 8:53 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I have a feeling this thread is going to make me extremely jealous!
    did you line-x the bed already?
    JonasSacredTundra[OP] likes this.
  4. Mar 27, 2014 at 3:09 AM
    himmy33
    himmy33 New Member
    Washington
    2014 Tundra 1794
    I look forward to following the thread. What is the outcome or goal you have for this truck?
  5. Mar 27, 2014 at 5:32 AM
    What tires are you looking at putting on there?
  6. Mar 27, 2014 at 6:13 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    You mention SEMA build, what does that mean? Show truck?
  7. Mar 27, 2014 at 6:17 AM
    csuviper
    Broomfield, CO
    You have a big list of stuff already.
  8. Mar 27, 2014 at 7:57 AM
    Dilsky
    Dilsky Toyota Brand *****
    Shawn
    Edmonton, Alberta
    2014 Platinum Tundra Crewmax Black
    King Front Coil-overs Coachbuilder shims Toytec Rear shackles - Stock Rear Baja Designs Sport Fog Lights Rough Country 30" Lightbar 18" Method Roost Wheels (Bronze) 285/70/R18 Nitto Exo Grapplers Diamondback HD Cover
    Oh man....just when I thought I was going to leave my truck stock for a little while....you have to go and post something like that!
  9. Mar 27, 2014 at 2:20 PM
    JonasSacredTundra
    Hey buddy, the bed is line-x'd already yes. It was done within 2 days of having the truck
    Alright sorry guys I hope I get to everyone.
    My truck is a complete show truck yes, this is the second truck I have built and this will be better than the last. SEMA is the largest automotive convention in the country, its in Las Vegas every year and you have to be invited by a company to represent them for your vehicle to attend.
    The list has changed a little bit since then I went a differen route with some things so its exciting!
    I was originally planning on Toyos but I may have to run Nittos which is no worries with me. I am going to either run 35 or 37 depending on the offset and rim size that I go with.
  10. Mar 27, 2014 at 2:22 PM
    JonasSacredTundra
    Truck is now able to breathe by the best in the business with the Volant CAI!!IMG_2523.jpg
  11. Mar 27, 2014 at 2:37 PM
    Bob
    Bob Member Staff Member
    Bob
    07 Tacoma PreRunner Black
    Can you post a pic or two of the last one you built?
  12. Mar 27, 2014 at 2:46 PM
    JonasSacredTundra
    It was nothing special man but here
    2014 Black tundra likes this.
  13. Mar 27, 2014 at 2:51 PM
    JonasSacredTundra
  14. Mar 27, 2014 at 6:31 PM
    JonasSacredTundra
    I couldn't be happier with this exhaust, best of the best Corsa sounds great no drone but mean when you get on it. Teaming up with the Volant air intake its a bad machine. IMG_2524.jpg
  15. Mar 27, 2014 at 7:36 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    this is going to be so badass.....
    I'm going to try to live vicariously through you and your truck, if you don't mind...
  16. Mar 27, 2014 at 8:37 PM
    JonasSacredTundra
    HAH! Thank bro I truly appreciate that - I am open to all inputs and constructive criticism as well.
    I didn't see this earlier I apologize, my goal is to build a truck for me and others to enjoy. I am not lifting it crazy high but just right, hopefully it comes out classy but yet unique.
  17. Mar 27, 2014 at 9:36 PM
    csuviper
    Broomfield, CO
    37s are a must
  18. Mar 28, 2014 at 7:45 AM
    JonasSacredTundra
    37s are the goal and with the correct fab and trim work should be easily doable.
  19. Mar 28, 2014 at 7:49 AM
    csuviper
    Broomfield, CO
  20. Mar 28, 2014 at 8:47 AM
    csuviper
    Broomfield, CO
    What does this intake look like. Pics inside box?
  21. Mar 28, 2014 at 9:21 AM
    JonasSacredTundra
  22. Mar 28, 2014 at 9:23 AM
    JonasSacredTundra
    One of the most convenient bed covers for my needs and one of the best on the market. Very durable great easy install - thanks Retrax!
  23. Mar 28, 2014 at 11:31 AM
    Foothillsflyer
    Foothillsflyer New Member
    2014 Tundra Crew Max - Mag Grey
    BDS 7" Coil Over w/ Fox shock, AE Alloys 20", 37x13.5 Toyo Tires, AMP Steps, Color Matched Bumpers + Grille, Tinted Tail Lights and 3rd Brake Light, BAK Roll Cover, Bed Rug, Recon LED Bed Lights, Window Tint, De-badged, Stow and Go hitch, Speedo Recal
    I see you are going 7" BDS and FOX setup but debating 35 vs 37 tires. Personally I think the 35 will look small given the 7" lift. I am running the same 7" suspension with 37's and there is zero rub and some trimming was done. I only have 400miles on my truck but the suspension is already starting to smooth a bit. My shop has done 10qty 2014 Tundra's to this spec and they recommend a suspension check and possible adjustment at 1500 and 3000miles to address the settling from break-in miles. Look forward to watching your build.
  24. Mar 28, 2014 at 1:33 PM
    JonasSacredTundra
    Thanks for the input my man I will def. check up on everything at those miles- whats your offset?
    Depending on how things work out I will be running 22x12 with -44 offset. So basically should have quite a bit of rub. There is a guy over on TT with a white 14 on 7" 35s on it and he rubs like mad with -44 offset.
  25. Mar 28, 2014 at 4:42 PM
    Foothillsflyer
    I am not sure of the actual offset. Perhaps that can be found on the AE Alloys site but I have not checked. The rims are 20". Tires are 37 x 13.5. I have backed up and driven forward at lock position both left and right and confirmed no rub in any direction.
  26. Mar 28, 2014 at 7:16 PM
    Javy
    Javy New Member
    2012 Toyota Tundra Texas Edition 4X4
    Nothing yet ?
    Does anyone have a coolant intake. Do they really respond that good
  27. Mar 28, 2014 at 8:03 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Keep us updated! Good luck with the build!
  28. Mar 29, 2014 at 6:42 AM
  29. Mar 29, 2014 at 7:51 AM
    JonasSacredTundra
    I dont recall that I personally know anyone who does have one. My CAI works just fine, it has slightly more throttle response and a nice growl.
  30. Mar 29, 2014 at 7:55 AM
    JonasSacredTundra
    Please Dont honk at me anymore my friend, you think you have train horns? Can't wait to get these installed, off to powdercoater first Thank you Hornblasters for the best train horns out there. I was originally going with the Nathan but I decided the Katrina would suffice. photo-14.jpg
