S4 mode
Discussion in '2.5 Gen Tundras (2014-2021)' started by Duffg, Dec 30, 2024.
  1. Dec 30, 2024 at 7:48 AM
    Duffg
    Duffg [OP] New Member
    2016 Tundra
    None
    Help me out. My son drove my 2016 Tundra in S4 mode for about an hour yesterday. Speeds ranged between 55/70mph. I was in the passenger seat and happened to notice the RPMs were sitting around 3k. That’s when I realized he was in S4 not drive. Anything to be concerned about with transmission? Temp seemed normal and no warning lights came on. Thanks.
  2. Dec 30, 2024 at 7:54 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Nothing except mpgs taking a bit of a hit. The trans will run cooler than in D due to a locked up 4th gear no overdrive to cause slippage or excess heat. Its as if you were Towing yet were not.
  3. Dec 30, 2024 at 7:57 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Completely fine and as mentioned it’s designed for it when towing.
  4. Dec 30, 2024 at 8:18 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    That’s the best gear to drive in, don’t worry.
    AZBoatHauler likes this.
  5. Dec 30, 2024 at 8:25 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    He's not getting his beer tonight!
    Duffg[OP] likes this.
  6. Dec 30, 2024 at 8:32 AM
    Duffg
    2016 Tundra
    None
    Thanks for the replies. The MPGs definitely took a hit. Thanks again.
  7. Dec 30, 2024 at 8:38 AM
    You're totally fine. All that did was prevent the transmission from shifting to a gear higher than 4th. It'll still run up and down the gears below that like normal, and you can do 80 MPH in 4th if you need to.
    Duffg[QUOTED][OP] likes this.
  8. Dec 30, 2024 at 8:51 AM
    AZBoatHauler
    So.Arizona
    It’s fine. Just burned a little extra fuel.
    GODZILLA likes this.
  9. Jan 2, 2025 at 10:58 AM
    Tundra Dude 45
    Tundra Dude 45 New Member
    Eric
    2019 SR 4.6L DC 4X4
    8” BAMuffler, TRD airflow accelerator, front window tint/windshield sun stripe, debadged tailgate 4x4 emblem, trimmed mud flaps, antenna removed stainless screw added, TRD rear sway bar, AFE high flow air filter.
    I have been driving in S4 around town (under 45 mph) for many years and have 102,000 miles on the original transmission. 2 dealer flushes so far and it still shifts like new. I prefer the better throttle responses and the trans not shifting constantly and lugging itself. I’ll bump it up to S5 when on the highway and S6 on the highway when it’s level or downhill.
    AZBoatHauler and Duffg[OP] like this.
  10. Jan 2, 2025 at 11:09 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    I use s mode often, just choose the gear based on speed I am traveling. Seem to get better MPG as the engine does not lug or want to downshift as much as it does in auto.
    Tundra Dude 45 likes this.
  11. Jan 2, 2025 at 11:26 AM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    '18 Tundra TRD Sport 2WD 5.7 Crew Cab MGM
    What about driving in Tow Haul mode all the time just for the extra boost?
    I've read comments on here before that someone does that regularly. I'm guessing you wouldn't want to drive at really high speeds in Tow Haul, is that correct?
  12. Jan 2, 2025 at 11:54 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Nothing wrong I only drive in s4 and s5
    Tundra Dude 45 and AZBoatHauler like this.
  13. Jan 2, 2025 at 11:59 AM
    koditten
    Kirk
    Midland of the Mitten
    I drive in S4 for 1600 miles a year dragging an 8000 lbs trailer. It likes 3krpms.
  14. Jan 2, 2025 at 12:32 PM
    mountainpete
    It's a Tundra so "really high speeds" is relative, but there are zero mechanical issues driving every day, all the time with Tow Haul mode on or in S4.
    The 5.7 needs higher RPMs for power. It is fine running at 3000 rpms all day. The only negative is you can watch your fuel gauge drop in real time.
  15. Jan 2, 2025 at 12:47 PM
    Tow haul just changes the shift logic and sensitivity of the pedal. There's not any kind of "boost" or anything that can hurt it anymore than spirited driving.
  16. Jan 2, 2025 at 12:54 PM
    koditten
    Kirk
    I use T/H all the time. With the button pushed the maintenance light comes on at 5000 miles, which is when I do oil changes.
  17. Jan 2, 2025 at 12:57 PM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Someone needs to get this guy a muzzle.
    You're an animal.
