S vs D and Tow/Haul Switch
Discussion in 'Towing & Hauling' started by smstoyloy, May 31, 2020.
  1. May 31, 2020 at 7:13 PM
    smstoyloy
    smstoyloy [OP] New Member
    Stephen
    2020 Cement Tundra SR5 TRD OR 4x4
    None Yet!
    Hi Folks. I will be picking up a 20’ travel trailer weighing in around 3800 lb dry (and later up to 4200 lb loaded) on Tuesday. Been a while since I have towed. I have a new Tundra SR5 TRD 4x4 with tow package and Max Trailer Weight Rating of 9600 lb. So trailer will be less than 50% of towing capacity (but could be greater if grey and black tanks were full before dumping). My question then, given the relative low weight of the trailer should I still use S mode and 4th gear on the AT (instead of D mode) and should I still engage the Tow/Haul switch? Thanks, Stephen
  2. May 31, 2020 at 7:36 PM
    AZBoatHauler
    So.Arizona
    I would always engage tow/haul when towing. I would leave in D on flat terrain and use S mode to get out of OD gears on hills as necessary. Small hills get S5 and big ones S4.
  3. May 31, 2020 at 8:44 PM
    smstoyloy
    Stephen
    None Yet!
    Thanks, valuable info. The “leave in D” comment triggered a follow on question. If using D and on relatively flat terrain and driving around 60 mph, can I use cruise control?
  4. May 31, 2020 at 8:53 PM
    AZBoatHauler
    So.Arizona
    I do without hesitation but only on flat terrain. I usually set mine around 65 mph and am pulling approx 6,000 lbs.
    BravoDeltaRomeo likes this.
  5. May 31, 2020 at 9:16 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    here are the pages. It says never use CC when towing and to always keep in S4 to maintain emerging braking and charging efficiency. Also an explanation of T/H mode.it also says never use the engine in D mode when towing.
    CEC82B9B-5E3B-4D50-B176-EA9197DED0E6.jpg 9A8D477D-774F-4CA0-B045-12AAEDF985ED.jpg 7C3A1712-B9C6-4E21-9E35-33F20163B86B.jpg
    Saltyhero13 likes this.
  6. May 31, 2020 at 9:27 PM
    Tundyfundy
    Bay Area, CA
  7. May 31, 2020 at 9:48 PM
    AZBoatHauler
    So.Arizona
    I have the benefit of an OBD trans temp monitor so I go ahead and save a few gallons of fuel by using higher gears when appropriate. Shifting in and out of 4-5-6 or using reverse up an incline is what gets these transmissions hot. I can run 6th gear towing at 70 mph on flat terrain all day and the trans will stay 195.
    IMO the manual is a one size fits all rulebook that you can safely modify the rules to if you know what you’re doing and what to avoid. The manual has to assume you’re towing maximum weight and will tell you to take precautions as though you’re pulling max weight. I will occasionally put my truck in cruise control while towing because I know what lugging the engine is and how to avoid it even while using cruise. Drivers who don’t know or don’t pay attention can damage their truck.
  8. May 31, 2020 at 9:55 PM
    Tundyfundy
    Bay Area, CA
    I agree and since we don’t know the skill level of OP I’m giving him the specification ms for his truck as a baseline and then he can decide his own comfort level as opposed to bringing him up to our comfort level without the baseline. Now he also knows the reasons why Toyota recommends this. Ie.. engine braking disabled when in CC.
  9. May 31, 2020 at 9:55 PM
    Tundyfundy
    Bay Area, CA
    Looks like he just got the truck, he may not be as comfy modifying the rules as we are.
    Dorks68 and smstoyloy[OP] like this.
  10. May 31, 2020 at 9:56 PM
    Tundyfundy
    Bay Area, CA
    OP make sure you finish your break in period before towing as well.
  11. Jun 1, 2020 at 6:53 AM
    ATHiker
    ATHiker New Member
    Tom
    2015 DC SR5TRD 5.7L 4X4
    I tow a 4500lb camper (loaded). I use Tow/haul and put the transmission in S5. I use an OMD transmission monitor. If I encounter a hill and see the transmission temp climbing, I down shift to S4 and the temp will drop. If it is a steep or long hill, I may have to shift to S4 or S3. Once over the hill, I shift back to S5. I rarely if ever use D or S6 when towing.
  12. Jun 2, 2020 at 8:33 PM
    smstoyloy
    Stephen
    None Yet!
    Thanks for the info. I had owned Tundra in past but did not tow with it. Anyway, yes, since picking up Tundra last Friday I drove 530 miles over 4 days and then 110 miles to fetch the Bambi 20’ today. I used Tow/Hall driving back home, mostly in S4, but some S5. Since the hwy from Greensboro to southeast of Raleigh, NC is flat to gently rolling I did use CC on occasion to bring my leg up to rest an acheing right knee. I tended to stay at 60mph, but on occcasion drifetd up to 65 mph. All felt ok and my crude dash temperature gauge for engine was normal. I don’t have a reading for the transmission.
  13. Jun 2, 2020 at 9:00 PM
    Tundyfundy
    Bay Area, CA
    Nice man! That first haul is intimidating! Sounds like your on you way to being a pro! Next big one is learning how to reverse!
  14. Jun 3, 2020 at 9:33 PM
    smstoyloy
    Stephen
    None Yet!
    Learned to reverse years ago, then forgot again. Stopped by parking lot of closed school on the way home from dealer. But could not yet get the swing of it. I know to start by turn truck steering oposite direction, but seems I start to jack-knife and cannot see association of corner of truck bed to trailer. So when I came home instead of backing into driveway I parked on street. My driveway starts going up and it could be that the 7 foot trailer overhang behind axle would cause trailer to bottom out on back end. I need to get my adult son to go with me to a parking lot and proctor me. Thanks for advice.
    Tundyfundy[QUOTED] likes this.
  15. Jun 4, 2020 at 12:00 AM
    Tundyfundy
    Bay Area, CA
    So think of it like this, you turn the opposite way until you get the pitch you want, then you correct immediately to the point that holds that pitch. You when you steer the trailer will continue to sharpen the angle until you correct. Try not turning so hard initially. You basically have to correct until you reach an equilibrium that will hold the angle you want. So turn opposite until the trailer pitches to the angle you want then start correcting until the pitch stops increasing. It’s not like reversing in a car where once you get the angle you want you just hold it there and the car will hold that angle. A trailer takes one steering wheel position to achieve a pitch, and then a lesser steering wheel position to hold that pitch you achieved. Tongue pull trailers are a bit squirrelly because they are sensitive. Especially short ones like yours.
    Dorks68 likes this.
  16. Jun 4, 2020 at 3:16 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Slightly different topic from the OP but would you guys also use S4 or S5 and tow/ haul when towing something very light? I was just trying to think about how I might tow my dad's boat if I ever end up offering to do that for him. It probably weighs 1500 lbs or less fully loaded and it's relatively flat between here and our lake lot.
    Tundyfundy likes this.
  17. Jun 4, 2020 at 4:52 PM
    Tundyfundy
    Bay Area, CA
    @AZBoatHauler may have the info, I mean that’s literally his name but as far as me Inwould think you wouldn’t want to let it go into 6th gear at all when hauling. As far as T/H mode I think try it both ways and if you don’t feel you need the extra power or extended shift intervals then leave it off.
  18. Jun 4, 2020 at 5:37 PM
    AZBoatHauler
    So.Arizona
    IMO It really depends on the actual weight being placed on the truck and how much you’re pulling. If the boat on the trailer ready to go truly is only 1,500 lbs, even 15% tongue weight only puts 225 lbs of weight on the truck which is a fair bit less than if I was sitting in your Tundra.
    With these trucks weighing nearly 6,000 lbs, another 1,500 rolling behind it will be hard to feel if your hitch is at the proper level.
    Long story short, I really don’t think it matters what you choose to do when you’re pulling something that light. The truck won’t know it’s back there.
    All that being said, same rules apply whether towing or not, if you hit mountain grades or experience excessive shifting or gear hunting, put it in S mode and take over control. When I’m between two gears I always pick the lower one and let the revs go up. You’ll burn a little more fuel but it will be a much more pleasant drive and you’ll save your brakes if you’re going downhill.
  19. Jun 4, 2020 at 7:09 PM
    So that’s not how I read it.
    “To maintain engine braking efficiency and charging system performance when using engine braking, do not use D.”
    You added some of your own words or auto corrected to something. The only time someone will be using engine braking is down hill or stopping. That’s what S4 and lower is for (maintaining safe speed with engine braking). The reason this helps with your charging system while engine braking is required:
    - D will most likely have the engine at lower RPM while going downhill (unless you have grade braking, which the tundra does have an OK system). The charging system at low rpm will be minimal. What is being used the most going down a grade if engine braking is not being utilized? Trailer brakes, brake lights and what not. This can drain the electrical system.
    The Tundra in all other situations is fine in D with T/H mode.
    Everything else...100% agree.
    astro-jason, rebmo, Y0TA PR0 and 4 others like this.
  20. Jun 4, 2020 at 7:16 PM
    Tundyfundy
    Bay Area, CA
    I see what your saying. When would you not want to maintain engine braking efficiency or charging system performance? Engine brake is always on except for in cruise right? I haven’t read the section on engine braking but I thought that was the case. I guess I assumed that would be what would be preferable.
  21. Jun 4, 2020 at 7:32 PM
    Tundyfundy
    Bay Area, CA
    I agree with you. I guess I misunderstood what it was saying.
  22. Jun 4, 2020 at 7:59 PM
    I’ll get with you Later tonight. I’m tied up for a bit.
  23. Jun 4, 2020 at 8:18 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    I look forward to my first tow with our Tundra. I'll be towing the same load I towed with our Sienna for 10y, so I should be in for a treat. :thumbsup:
  24. Jun 4, 2020 at 8:31 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I use whatever gear the truck is happy to sit in and maintains trans temp. Without an external gauge that's hard to judge, but if you have an OBD2 reader or something else use that for reference. I routinely am in 6th gear even with heavy loads (6000lbs+), granted that's with a supercharger, but same logic applies to the trans regardless. 6th gear with the torque converter locked up and cruise controlled at whatever speed I want and trans will be at 190F and the truck is happy. I've seen people claim that the higher trans gears will get destroyed towing in a higher gear, I have yet to see any physical proof or logical argument to believe that's true.
    Listen and watch the truck and do what makes it happy and you'll be fine.
  25. Jun 4, 2020 at 9:32 PM
    Tundyfundy
    Bay Area, CA
    I’m betting the difference will be huge! If you can dodge a wrench you can dodge a ball!! Or more specifically if you can tow with a van you can tow with a truck! Those siennas are nice man. So many creature comforts!
  26. Jun 4, 2020 at 9:32 PM
    I’m sure you figured it out, but just going to say it for others to read.
    Even towing on flat land your RPM will be higher due to being higher than idle engine speed. Towing my TT I was rarely in 5th, mainly in 3-4th for hours....or about 125 miles when I was desperately in need of fuel.
    Jtundra81 and Tundyfundy[QUOTED] like this.
  27. Jun 4, 2020 at 9:35 PM
    Tundyfundy
    Bay Area, CA
    So no need for engine braking and or charging efficiency as your RPMs are already high. I’m with you and completely agree. :thumbsup:
  28. Jun 5, 2020 at 5:42 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Yeah, I'm thinking I should pick myself up some kind of scan gauge and learn how to use it.
  29. Jun 5, 2020 at 6:08 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I use D and tow/haul towing 5000 lb boat. Relatively flat around here. With a strong headwind or hills i will use 5th. I only use cruise in known speed trap areas. Mainly one town and flat terrain at 50 mph.
  30. Jun 13, 2020 at 7:54 PM
    102dalz
    102dalz New Member
    Andy
    2017 Tundra CrewMax White
    None
    My 2017 SR5+ has no tow/haul switch...but it appears to have the wiring for one under the antiskid panel. Any idea if I add a switch, will it give me the tow/haul functions?
    I'm also adding a Tekonsha brake controller, so I'm thinking both will help my towing ability?
