S-pod Substitute?
Discussion in 'General Tundra Discussion' started by rudedawg, Feb 3, 2021.
  1. Feb 3, 2021 at 7:10 AM
    rudedawg
    rudedawg [OP] New Member
    Rudy
    2013 Tundra Crewmax
    35 in tires, rock sliders
    Greetings all from Texas!!!
    Is there an S-pod substitute available for my 2013 Tundra Crewmax 4x4 that wont break the bank? I love the concept of all the wiring under the hood and control module inside the cab. Suggestions are greatly appreciated. Thanks and stay safe on the trails!!!
  2. Feb 3, 2021 at 7:16 AM
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    Check out trigger wireless controllers, same concept more or less and significantly cheaper
    rudedawg[OP] and YotaBro like this.
  3. Feb 3, 2021 at 7:19 AM
    YotaBro
    Calvin
    FL
    Lots of shenanigans.
    I second the trigger system, currently running the 6-shooter and love it.
    rudedawg[OP] likes this.
  4. Feb 3, 2021 at 7:20 AM
    rudedawg
    Rudy
    2013 Tundra Crewmax
    Thanks for the intell!!!
    Much appreciated!!!
  5. Feb 3, 2021 at 7:26 AM
    Tundra-in-Cement
    Tundra-in-Cement Truck Chump
    David
    2021 Tundra CM-OR
    Scanguage-II, Decked Systems, Leitner Rack, CaliLED lights, Firestone Air Bags, Trans-cooler kit, 2017 Pro grille and bulge, S-Tech 6 way switch, Corse Evo Darks w/ Stock Tires, 17-inch Alpha Equip Delta w/ Wildpeaks, Falcon Suspension, Coachbuilder +1 Shackle, Valhalla Cat Protectors.
  6. Feb 3, 2021 at 12:40 PM
    801Tundra
    801Tundra New Member
    UTAH
    2019 Crewmax Limited
  7. Feb 3, 2021 at 6:43 PM
    preacher35
    preacher35 RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    I too contended with this issue. I wanted something that would not be shoddy, but not be crazy expensive either. So, I went with "Corey Georges" 3d printed dash switch bay for $35.00, which is designed to be installed south of the HVAC controls.
    He can do many variations, but I decided on 5 LED light switch ports, and two ports for the glass breakage sensor and OEM USB, and therefore eliminating the two OEM auxillary/cigarette lighter/power ports as I never used these anyway. In addition, I installed, a BP Automotive, waterproof relay/fuse box in the engine bay, to act as the power hub for said switches and all of the LED lighting that I intended to install.
    https://www.bp-automotive.com/produ...ff-road-fuse-relay-power-distribution-center/
    And damn! It turned out beautiful! The setup looks fantastic inside and out!
    rudedawg[OP] and biebs96 like this.
