S Mode on shifter
Discussion in '2.5 Gen Tundras (2014-2021)' started by TundraTss, Nov 14, 2017.
  1. Nov 14, 2017 at 2:03 PM
    TundraTss
    TundraTss [OP] The Mistress
    Brandon
    2019 TRD SR5
    Everything. Literally.
    What’s the purpose? is it Sport mode? I’ve read that it’s only for towing or hauling heavy loads, so it seems a little wired that it’d be called sport mode if that’s the case..?
    4x4_Angel and dcsleeper408 like this.
  2. Nov 14, 2017 at 2:15 PM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    I used it in the dirt for some speed-to stay in gear/higher rpm without the automatic shift, use it to engine brake in the down hill with or without tow, and in 4L when just creeping through a rough patch of trail/uphill or downhill.
  3. Nov 14, 2017 at 3:04 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    for when you want to...:burnrubber:
    Homar23, htw_hawaii and dcsleeper408 like this.
  4. Nov 14, 2017 at 3:20 PM
    BHarry
    BHarry New Member
    Northern Nevada
    2014 BRM CM TRD
    It is sport mode, for heavy loads you can use the tow\haul mode ( I am honestly not sure if that is available on every model). Sport mode does change your shift points to a higher RPM, but it also allows you the ability to manually shift gears. I like to turn them both on and turn your traction control off, then have some real fun ... :burnrubber:
  5. Nov 14, 2017 at 3:24 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    S actually stands for sequential.
    Tundralicious, Newm, Kerch71 and 11 others like this.
  6. Nov 14, 2017 at 3:29 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    It would be more useful if you could use the shifter while in D. Instead of having to switch to S. That's an option on my wife's car. Sometimes you just want to downshift one gear and it's not even worth switching to S. Come on Toyota.
    Kerch71 and 831Tun like this.
  7. Nov 14, 2017 at 4:14 PM
    BHarry
    BHarry New Member
    Northern Nevada
    2014 BRM CM TRD
    I looked in the manual and it is just listed as S mode, so l’d imagine you are correct. Sport mode in my wife’s Subaru is set up very similarly, but they actually call it Sport mode. :notsure:
    joonbug[QUOTED] likes this.
  8. Nov 14, 2017 at 4:44 PM
    xj2202009
    xj2202009 New Member
    x
    Lutz, Fl
    2017 tundra sr double cab v8 5.7L black 4x2
    looking to replace factory Radio with a pioneer avix588bhs
    I have an sr and is an option..it keeps more torque at the wheels by changing the shift points..you can tow with it as it locks the transmission to the lower four gears..but tow mode is always best when towing as there's more benefits with it. Using S, tow mode and shutting the "nannys" off = fun mode..
  9. Nov 14, 2017 at 4:53 PM
    xj2202009
    x
    Lutz, Fl
    The reason is "sequential" is due to the dual clutch transmission. Basically when the truck is getting ready to shift the truck will spool the next gear and both match the shift occurs. I have not research this answer but that's how it was explained to me..
    EvilOne and Toyotoholic like this.
  10. Nov 14, 2017 at 5:01 PM
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2022 Tundra Crewmax Hybrid TRD Pro
    This is correct!
    Sequential is what you're in, not a sport mode on the Tundra or any Toyota which offers the availability of the S on the shifter. The only vehicles with the "sport" mode will have a sport button, as in the Rav4/Corolla S... etc
    EvilOne, Toyotoholic, JMB and 2 others like this.
  11. Nov 14, 2017 at 5:06 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    The point is that once you get into it, it’s damn SPORTY!
    Viking, 040Tundra and NewImprovedRon like this.
  12. Nov 14, 2017 at 5:58 PM
    17TundraDCEd
    17TundraDCEd New Member
    Ed
    SE Pa
    2018 White SR5 Crewmax
    Rear Sway Bar
    Aftermarket exhausts can drone when trans in 6th and converter locked and mph under 60. You can use S to move between 5th and 6th to get out of drone range.
    Kerch71 and Krezz like this.
  13. Nov 14, 2017 at 6:08 PM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    yep I use it off road For the fun factor it puts a big :)
  14. Nov 14, 2017 at 6:35 PM
    Ericsopa
    Ericsopa Old man and the sea
    The tranny, while in regular auto mode, has built-in AI programming. It anticipates the driver's intent. If you let up completely on the throttle, it anticipates that you will be braking at some point soon, and will downshift the tranny sooner than most autos would normally do. I've found this to be an MPG killer if you live in a hilly area. It just doesn't coast well downhill with a closed throttle. The "S" mode cancels the AI programming, so the truck coasts a lot farther. When you switch over to "S" mode, the default gear that the tranny goes to is 4th, so you have to be quick to push the laver forward to have it go immediately to 6th without a downshift. If you put it in "S" mode at a stop it will have 4th as the highest automatic gear, unless you you push the lever forward. You can push it forward and hold it for a second or so and it will move right to 6th. But you have to "bump" it down to downshift, one bump per gear. If you have manually put it in 1st gear, you can bump it up through the gears with short movements, or hold it to go directly to 6th as the highest gear. If you put 6th in the display, and just drive it like a regular automatic. You'll notice no difference at all (except that it will coast better). It will start in 1st and shift through the gears automatically. I use the "S" mode all the time now and get about 1-1.5 MPG better than I did in the regular mode. I just put it is "S" mode, hold the lever forward to make the display indicate "6" and drive it like a regular automatic.
  15. Nov 14, 2017 at 6:42 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Good information bro
    Kerbey7011 likes this.
  16. Nov 14, 2017 at 6:46 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    I thought it meant "Sexy"....we don't have a sexier mode for our trucks?
  17. Nov 14, 2017 at 6:47 PM
    That comes standard.
    ColoradoTJ and blue16 like this.
  18. Nov 14, 2017 at 6:47 PM
    Ericsopa
    Mine's sexy enough without any input from me.
    4x4_Angel likes this.
  19. Nov 14, 2017 at 6:49 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    sexIER....like if you see a sexy chick wearing her every day clothes and then she changes intro her sexy little black dress it makes her sexier:D
    Krezz likes this.
  20. Nov 14, 2017 at 6:51 PM
    R-C
    R-C http://101financial.com
    Ryan
    Las Vega$
    2017 TRD Pro
    Thats good info right there
    Bobo64 and Kerbey7011 like this.
  21. Nov 14, 2017 at 7:05 PM
    TundraTss
    Brandon
    2019 TRD SR5
    You win this thread.
  22. Nov 14, 2017 at 7:05 PM
    Ericsopa
    My MPG figures come from a test I've been doing over the past 6 months and 10000 miles. MPG prior was about 16, mixed city/hwy. Over mentioned time period, it has been a consistent 17.3. Calculated figures, of course. I've found that the displayed MPG for each fillup (reset each time) has been all over the place, from 15.8 to 18.3, but the calculated MPG is always much closer to 17.3. I had my son give it a try where he lives, bigger city, more stop and go, but flat terrain. He only messed with it for a few weeks, but didn't think it made much difference in his '07 Tundra.
  23. Nov 15, 2017 at 4:16 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    LOL, don't listen to that person any more. These exist, but not in trucks....yet.
  24. Nov 17, 2017 at 9:06 AM
    Toeb
    Toeb Well! That escalated quickly!!
    Toby
    North Carolina
    2014 SR5 double cab
    2.5 leveled 20x10 -19 hostile sprockets w/ 305-55-20. And just getting started
    actually tired this last night to see if it made any difference. cant speak for mpg but truck did seem like the "engine braking" was removed. noticed it especially coasting down hill under no acceleration was almost as if it was in neutral gear. great info!!!!
  25. Nov 17, 2017 at 9:13 AM
    mlucas555
    mlucas555 New Member
    Mark
    San Antonio, Tx
    2016 MGM Double Cab
    Still rocking the stock height.
    Thanks for the info! I had been wondering what it would do in "S" mode. I will be using it more now.
    TexBex and Kerbey7011 like this.
  26. Aug 18, 2019 at 3:21 PM
    conviccted
    conviccted New Member
    Victor
    2019 Voodoo TRD Pro
    Ceramic Tint,Spray on bed liner
    Do you have to ease off the gas pedal when shifting up gears on S Mode ?
  27. Aug 18, 2019 at 3:51 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    No, just keep it to the floor. ;)
    conviccted[QUOTED] likes this.
  28. Aug 18, 2019 at 4:00 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I toggle up and down through the gears often, it shifts nicely when you leave it in 6.
    Kerch71 likes this.
  29. Aug 18, 2019 at 4:04 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    This. Selective. I use it only to keep the revs up when needed. Soft sand and such.
  30. Aug 18, 2019 at 4:46 PM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    I'm too sexy for my truck
    Viking, 4x4_Angel[QUOTED] and JMB like this.
