Rwd vs 4wd Stock Ride Height
Discussion in '3rd Gen Tundras (2022+)' started by LateOnTheBrakes, May 2, 2024.
  1. May 2, 2024 at 7:52 PM
    LateOnTheBrakes
    LateOnTheBrakes [OP] New Member
    Charlottesville, VA
    2021 Voodoo Blue Platinum
    TRD exhaust, TRD skid plate, TRD pro wheels, TRD sway bars, AIRAID intake
    Has anyone measured both the stock ride height for the two-wheel drive versus four-wheel drive? I want to order a platinum and would prefer it as low as possible to make it easier to get my motorcycle in and out of the bed. I'm wondering if there is any benefit in ordering the two-wheel drive version or if it will be the same ride height as the four.
    whodatschrome likes this.
  2. May 2, 2024 at 8:30 PM
    blenton
    blenton New Member
    https://sosperformance.com/products/2022-tundra-23-lowering-kit-tr-2030
    Here’s one solution for you. Have to order the truck with rear air suspension.
    If the Gen 3’s are anything like the Gen 2’s in regards to 2wd vs 4wd ride height, the difference would be mostly negligible on a stock truck comparing same trims. You should be able to look up the specs on Toyota’s site? It’s not like the tacomas that have a 4 or 5” ride height difference from going spring under 2wd and spring over 4wd.
    pwpblue likes this.
  3. May 2, 2024 at 8:32 PM
    LateOnTheBrakes
    Charlottesville, VA
    I have the SOS lowering kit on my 21 tundra. The install wasn't bad but I don't want to have to do it if there is a lower model from the factory.
  4. May 2, 2024 at 8:54 PM
    Hella Krusty
    Hella Krusty New Member
    My 3rd Gen 1794 has air and you can lower the rear from the dash. I am sure it would be low enough. 3rd Gens sit WAY lower than 2nd
    My 2nd gen I would launch my boat and would be fine, my 3rd gen.....bumper is in the water...exhaust bumbling away
  5. May 3, 2024 at 9:12 AM
    LateOnTheBrakes
    Charlottesville, VA
    Are you saying you paid extra for the auto leveling air suspension? Or is it height adjustable because of the active suspension? I had a LX470 with the adjustable height suspension and I could drop it or raise it depending on what I was trying to accomplish.
  6. May 3, 2024 at 10:33 AM
    Hella Krusty
    bought the truck with the Advance Pack which includes Auto Leveling Air , Power running boards + bed step. 5 mode AVS and some other thing
  7. May 3, 2024 at 12:18 PM
    LateOnTheBrakes
    Charlottesville, VA
    So is it the adaptive variable suspension that lets you adjust the height or is that the auto air leveling? In my Lexus the AVS is just how firm the shocks are. The AHC was a separate switch. I honestly don't like the complication of variable suspension. Too expensive/complicated if I keep the truck long-term.
  8. May 3, 2024 at 7:42 PM
    cabiczzz
    cabiczzz New Member
    Clyde
    2024 SR
    Stock
    it all depends what options, trd suspension (almost levelled in the front), trd susp with 3" factory lift, or black stock coilovers and cv axles and shocks (big front droop)
  9. May 3, 2024 at 8:05 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    I like the way you think. While 95% of guys want to lift their trucks to commute on the highway (and there’s nothing wrong with doing that), you go against the grain and want to buy a truck that will work best for actual hauling.
    I can’t help you with the differences between a 2x and a 4x, but my friend bought a brand new 2wd Colorado and promptly lowered it 3”. It’s totally awesome for loading and unloading motorcycles!
  10. May 3, 2024 at 9:08 PM
    Sixty9Four20
    Sixty9Four20 TRD is not a trim
    2023 TuRD Pro
    I didn’t spend the money to just swap out stuff.
    Bro is really trying to give up the value of 4x4 transmission for ease of motorcycle loading.
  11. May 4, 2024 at 5:42 AM
    LateOnTheBrakes
    Charlottesville, VA
    It doesn't snow where I live. No need for 4wd. My previous truck before the tundra was a Tacoma xrunner. And I load my motorcycle a lot. I do track days all summer long.
