Rusting
Discussion in '3rd Gen Tundras (2022+)' started by Brenardrindon, Jul 24, 2023.
  1. Jul 24, 2023 at 4:59 PM
    Brenardrindon
    Brenardrindon [OP] New Member
    Bren
    2022 lunar rock tundra
    I have a 2022 tundra and it’s showing rust corrosion on passenger side roof edge. Any one else have the same issue? And is it covered under warranty?
  2. Jul 24, 2023 at 5:21 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    I had a similar event (much worse) on a two year old 4Runner. The dealership painted above my windshield, all the door sills, and around the back gate. Toyota did it all free of charge which was nice. But after finding more bad rust that required the body being removed from the frame, I cut my loses and traded it in. So more for a Japanese made truck…
    Brenardrindon[OP] likes this.
  3. Jul 24, 2023 at 5:42 PM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    Live in a hail area? Perhaps the roof was repaired and painted before you took possession…if so the dealer is on the hook.
    ETA And yes, still under warranty. Unless they try to put it on a sloppy windshield replacement if you’ve had one done.
  4. Jul 24, 2023 at 6:11 PM
    TundraMoe
    TundraMoe New Member
    2023 GMC Sierra Denali 3.0 Duramax
    I would ask the dealer about prior damage. Before my Tundra arrived it was delayed for a bit in the rail yard due to a hail storm that damaged a bunch of vehicles. Toyota was taking inventory and fixing the damaged ones. The dealer assured me that mine was not damaged. I hope that is the truth.
  5. Jul 24, 2023 at 6:18 PM
    Brenardrindon
    Bren
    I did have the windshield replaced by Toyota. I’m just afraid they’ll put the blame on me.
  6. Jul 24, 2023 at 6:20 PM
    Brenardrindon
    Bren
    no hail up where I’m at.
  7. Jul 24, 2023 at 6:28 PM
    Brenardrindon
    Bren
    My truck was delayed coming from Texas. Maybe my truck was one of the damaged vehicles.
  8. Jul 24, 2023 at 6:30 PM
    Brenardrindon
    Bren
    I did have the windshield replaced by a Toyota dealership.
  9. Jul 24, 2023 at 6:44 PM
    Northern Toyota
    Northern Toyota New Member
    2023 Tundra TRD Off Road, 2022 Tacoma TRD off road premium
    Tires and bilstein
    that is the first thing I thought of, that is typical windshield replacement damage there. Common years ago but newer tech makes this damage rare nowadays. 100% whoever replaced that’s windshields fault, good luck getting it fixed right so it doesn’t come back.
  10. Jul 24, 2023 at 6:54 PM
    TundraMoe
    Zero reason you are at fault for this. No way.
    Brenardrindon[OP] and Mattedfred like this.
  11. Jul 24, 2023 at 6:57 PM
    2mchfun
    FWIW, a bunch of brand new vehicles get damaged prior to delivery. Not necessarily hail, but numerous types of damages. Good luck getting it corrected!
  12. Jul 24, 2023 at 8:01 PM
    PERRY1060
    PERRY1060 Hammer Down
    Perry
    Indiana
    Blk on Blk 22 Ltd 4x4
    TRD wheels, skid plate, black fender flares, mud flaps and running boards. Pirelli Scorpion 275/70/20 Allterrain Plus tires
    Windshield replacement is almost always the cause of rust in that area. To properly stop the rust the windshield needs to removed, rust removed and metal treated to prevent rust from returning. Then repainted and windshield reinstalled. If it is not done this way the rust will likely return. Toyota should pay for the entire bill because they replaced the windshield.
  13. Jul 24, 2023 at 8:15 PM
    Brenardrindon
    Bren
    Thanks brother. Greatly appreciate you.
  14. Jul 24, 2023 at 9:44 PM
    Sixty9Four20
    Sixty9Four20 TRD is not a trim
    2023 TuRD Pro
    I didn’t spend the money to just swap out stuff.
    Mattedfred and Taikowaza like this.
  15. Jul 25, 2023 at 9:28 AM
    Tundra Dude 45
    Tundra Dude 45 New Member
    Eric
    2019 SR 4.6L DC 4X4
    8” BAMuffler, TRD airflow accelerator, front window tint/windshield sun stripe, debadged tailgate 4x4 emblem, trimmed mud flaps, antenna removed stainless screw added, TRD rear sway bar, AFE high flow air filter.
    Keep us updated OP on what the dealer does.
    2mchfun likes this.
