running wires for backup camera 2006 Tundra
Discussion in 'New Member Introductions' started by Knucklehead, Feb 28, 2019.
  1. Feb 28, 2019 at 4:21 PM
    Knucklehead
    Knucklehead [OP] New Member
    I have a 2006 extended cab Tundra and I'am installing a back up camera, on to a Pioneer head unit. I got the head unit working fine. And I have the wires ran from the license plate camera frame under the bed up to the back of the cab. My question is what is the best way to enter the back of the cab with the wires? Should I just drill a hole under the carpet and cover it with caulk. Or is there access holes that I'm unaware of. Any help would be appreciate Thanks
    Mcoop, Prostar 190, T-Rex266 and 2 others like this.
  2. Feb 28, 2019 at 5:12 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    :wave: Hiya and welcome from SoCalif!!!
  3. Feb 28, 2019 at 5:58 PM
    Welcome.
    There’s got to be a better way to do it
  4. Feb 28, 2019 at 6:13 PM
    dumbassdave
    dumbassdave Member
    Dave
    2016 Crewmax Limited
    I ran mine up into the engine bay and poked a hole through a firewall grommet. No drilling required and would need some serious balls to the wall wheeling to get that part wet.
  5. Feb 28, 2019 at 7:57 PM
    Welcome from Ohio
  6. Feb 28, 2019 at 8:42 PM
    Knucklehead
    I was thinking about going under the door rocker panel
  7. Mar 1, 2019 at 1:25 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Welcome to the party!!
    You should already have wires ran from back of truck to inside the cab, for tail lights and such. Look a little harder abd run with whats already there.
  8. Mar 1, 2019 at 4:09 AM
    Jrfor0
    Jrfor0 New Member
    James
    In my 2006 DC, there was a rubber grommet access under the drivers seat. Maybe it will be the same on the AC?
    because_wumbo-truck likes this.
  9. Sep 20, 2019 at 12:00 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    I also have a pioneer and I'm trying to find the reverse wire in the dash to tap into
  10. Nov 6, 2019 at 12:06 PM
    Chris Barnes
    Chris Barnes New Member
    2006 Double Cab Tundra
    To use the back up camera is it as simple as plugging into the stereo. . does it engage when put in reverse?
  11. Nov 6, 2019 at 1:03 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Should be there on all trucks. Pull the scuff plate on the drivers door and it should be pretty easy to lift the carpet up and see.
    Green/Red wire on the passenger side. Marked as connector J28/29 in the attached file.
    Depends on the camera/monitor. I used the older version of this kit https://www.amazon.com/AUTO-VOX-T2-...d_r=13GX4DPH0ZB89FVQRE8Y&psc=1&qid=1573073540 . It works off of the signal from the camera input no reverse wire necessary in the cab.
    wbrigance and Pearl-snap like this.
  12. Nov 6, 2019 at 1:06 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    Too late for me mate. I took it to a pro like a month ago lol
  13. Nov 6, 2019 at 3:43 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    Ah foiled by the zombie thread. Well hopefully it helps someone else.
  14. Aug 27, 2023 at 9:50 AM
    Chris Barnes
    wonder if I could revive this tread! so I installed a new head unit w/ backup camera installed on tailgate. . everything works EXCEPT. . . I have to manually put the stereo in backup camera video mode. . When I shift to reverse it doesn't go automatically. . . wondering if anybody has insight. . thanks!
  15. Aug 27, 2023 at 5:38 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Go ask in the FRAC thread. Lou might be able to answer your question.
