Running RCA cables to amp under rear seat?
Discussion in 'Audio & Video' started by Riskyguy, Oct 14, 2017.
  1. Oct 14, 2017 at 8:33 PM
    Riskyguy
    Riskyguy [OP] New Member
    Stewart
    2018 Tundra SR5 Crewcab
    What route have you taken to get the RCA cables to the back seat area? I would like to run them along the door sills but I am having trouble getting them thru the post area between the front and rear seats. Would it be OK to run them down the middle of the cab under the carpet? Thanks for any ideas you can offer.
  2. Oct 15, 2017 at 5:11 AM
    birdman076
    birdman076 Bird, bird, bird...bird is the word
    Chuck
    Montana
    2015 Brown Tundra Crew Max Limited
    Airbox with K&N Filter, 2" lift on 33's, Alpine iLX-F309 head unit, Pull out bed tool boxes, brown with black trim, rims, etc, black leather interior, matching topper. Muffler delete (too loud..) 62k miles!!!
    Running them down the middle of the cab under the carpet is fine and saves some cable length. The trick to getting them through the post area is to run a metal coat hanger or mechanics wire through first, tape the RCA cables to it and pull them through. its tight through there and that's the only way unless you unbolt the seat belt bolt and remove the panel.
    Dougthebeast likes this.
  3. Oct 15, 2017 at 5:58 AM
    MikeyMTBs
    MikeyMTBs New Member
    It is no problem to run them under the carpet. I have the excess length laid out in a giant loop under the carpet behind the front passenger seat.
  4. Oct 28, 2017 at 10:48 PM
    Riskyguy
    Stewart
    Thanks. I ended up running them through the center console and under the carpet to the amp which is installed under the back seat. 12' cables would have been plenty long enough.
  5. Sep 28, 2024 at 1:50 PM
    jaywill808
    jaywill808 New Member
    2020 Tundra TRD-Pro
    How did you guys get under the carpet and fish to the center console? Did you remove the center console entirely? Did you cut holes in the carpet to gain access?
  6. Sep 28, 2024 at 2:25 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Just pull the top pannels off the console and you should be able to fish your cables thru.
    I used 3' HVAC zip ties to fish cables thru the console and dash.
    Amazon.com: K-T Industries 5-9560 36.5-Inch Cable Ties, Extra Heavy Duty, Natural, 10-Pack : Electronics
    The carpet will pull out around the edges of the console, you just tuck it back in.
  7. Sep 30, 2024 at 8:52 AM
    Snert
    Snert New Member
    2021 SR5
    Late to the party, but if you want to run along the door sills, removing the b-pillar trim to get through there is super easy. Just have to undo the seat belt bolt and reinstall when you're done and be sure to torque to the correct spec. The rest of the b pillar trim is just held on by clips from what I recall and it was easy to take out and reinstall.
