Running Lean - What's leaking in this smoke test?
Discussion in '1st Gen Tundras (2000-2006)' started by ohmygoshpleaserun, Aug 31, 2022.
  1. Aug 31, 2022 at 3:44 PM
    ohmygoshpleaserun
    ohmygoshpleaserun [OP] New Member
    2006 Tundra 4.7, DC, 2WD, 220k miles
    CEL for running lean on bank 2 -- but both banks have high long term fuel trim ~20-25%
    I hooked a smoke machine up to the intake with the throttle closed, and smoke is coming from the pictured areas. I can't see obvious vacuum lines here. Could this be the intake gasket? Could this be the vacuum leak? Thank you.
    DarkMint likes this.
  2. Sep 1, 2022 at 6:25 PM
    zgurrola21
    zgurrola21 New Member
    Zyan
    2001 Toyota Tundra SR5 TRD OFF-ROAD
    It kinda looks like it’s leaking from the intake manifold sits, maybe the intake manifold gasket is leaking, if you pore tiny drops of water near the area, the idle should change, you would be able to hear the idle changing or you can even use a automotive stethoscope to listen to the suction
  3. Sep 2, 2022 at 9:28 AM
    ohmygoshpleaserun
    Hi zgurrola21, thanks for your reply. I'll try spraying water around it. I don't know what intake manifold sits are. Does that mean the manifold could be cracked? Other pictures I see online have the manifold looking aluminum and mine is plastic -- not sure if that's after market.
  4. Sep 2, 2022 at 8:27 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I'm not sure about using water. Seems sketchy to me. I've always heard using flammable carburetor cleaner and spraying that around the area and seeing if idle changes.
    N84434 and FrenchToasty like this.
  5. Sep 2, 2022 at 9:25 PM
    zgurrola21
    Zyan
    It’s super dangerous to use carb cleaner, highly flammable, it’s only small drops but you can also use which is my favorite is using a automotive stethoscope to listen to the leak
    NickB_01TRD likes this.
  6. Sep 2, 2022 at 9:28 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    The other tried method is raw propane gas out of a torch with a hose to pin point the leak.
    N84434 likes this.
  7. Sep 3, 2022 at 5:18 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    That's what I've always done.. Works like a charm.
