Running hot
Discussion in '2nd Gen Tundras (2007-2013)' started by Karask88, Jul 14, 2020.
  1. Jul 14, 2020 at 3:05 AM
    Karask88
    Karask88 [OP] New Member
    2011 Toyota trunda sr5 double cab
    so I have a 2011 sr5 tundra. I did not even a .5 mile drive and the engine is hot. It isn't overheating at all this has been going on for about 2 months but now I'm worried
  2. Jul 14, 2020 at 4:07 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Without much info, I'd tell you to do the obvious:
    Check your coolant level
    Check for oil / coolant milkshake
    Check your thermostat
    Check your rad cap
    Bleed your cooling system
  3. Jul 14, 2020 at 4:28 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    That ^^^. Until that is understood no sense in going any further.
  4. Jul 16, 2020 at 7:57 PM
    Karask88
    Sorry I was little busy with work but basically I didn't get a chance to bleed it yet but when I check the coolant level it was full the near survey it went down to < 25% and now it's back to halfway
  5. Jul 16, 2020 at 7:58 PM
    Karask88
    The truck has not overheated nor Is the thermostat going upwards towards hot
