Running grinding sound coming from transmission area
Discussion in '1st Gen Tundras (2000-2006)' started by Broken4\4, Sep 1, 2024.
  1. Sep 1, 2024 at 7:56 AM
    Broken4\4
    Broken4\4 [OP] New Member
    Isaac
    2006 tundra 4.7 double cab
    I purchased my tundra with a bad frame and ended up swapping the frame, after it was fully put back together I took it for a test drive and there’s a rubbing sound coming from the transmission area, I replaced wheel bearing and no change, I checked the trans fluid and it was pink and it shifts good, but it will make the rubbing louder in first gear and change pitch and get quieter as it shift up into the higher gears, and also I can hear it from outside of vehical (It wasn’t making sounds before I swapped it)
  2. Sep 1, 2024 at 8:55 AM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Possible cracked flywheel. Can you add a video.
  3. Sep 3, 2024 at 2:52 PM
    Broken4\4
    Isaac
  4. Sep 3, 2024 at 11:55 PM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Add a video from under the truck.
  5. Sep 4, 2024 at 9:37 AM
    Broken4\4
    Isaac
    Can’t really here anything from under it, just from the cabin , but I can take a Video
  6. Sep 4, 2024 at 9:58 AM
    shifty` In South Dakota Trouble ain't hard to find
    Yeah, I'm not hearing it. You're sure you installed carrier correctly, and driveshafts were clocked properly at reinstall? No rubbing or anything? I recall someone complaining about something rubbing/grinding under the truck near the transmission at one point... like, the front driveshaft physically smacking into something, did you try getting under the truck with it OFF and spinning the front driveshaft to see if it's contacting anything?
  7. Sep 4, 2024 at 12:51 PM
    Broken4\4
    Isaac
    The rear slip shaft was about 90* off for about a week but I aligned that, could that have caused damage somewhere? And I’ll check the carrier
    Also if I put it in 4 wheel and slightly break tourqe it, it’ll make the scraping sound so I assume it’s not anything in the drive shaft
