Running board lights?
Discussion in '2.5 Gen Tundras (2014-2021)' started by wyone, Nov 10, 2018.
  1. Nov 10, 2018 at 5:33 PM
    wyone
    wyone [OP] New Member
    2018 Tundra DC
    dashcam... more to come
    New 2018 Tundra SR5 owner here. Love the truck, but there are no puddle lights or other outside lights that will illuminate the doors.
    I have factory running boards. I am thinking some sort of tape light or such that maybe I can tie into the interior lights? That way they would come on with the fob or when I open the doors.
    Has anyone done this? Not sure if the adhesive style would stay on, or if there are different brightnesses that might be better.
    Thanks in advance!
  2. Nov 10, 2018 at 7:23 PM
    wyone
    2018 Tundra DC
    That is nice.. I was thinking I had to do a long strip on each side.. but that actually makes sense to do two small to light at each door. So where did you connect to the cargo lights? I was thinking of running to the underdash light
  3. Nov 10, 2018 at 7:57 PM
    wyone
    2018 Tundra DC
    thank you... I need to go to ebay and look for some lights.. :)
    NewImprovedRon likes this.
  4. Nov 10, 2018 at 8:19 PM
    Macks
    Macks New Member
    Kevin
    Same here. One under each step.
  5. Nov 10, 2018 at 8:21 PM
    wyone
    2018 Tundra DC
    that looks perfect for what I am thinking.. did you find lights on ebay or where?? where did you connect them?
  6. Nov 10, 2018 at 8:30 PM
    Macks
    Macks New Member
    Kevin
  7. Nov 11, 2018 at 5:30 AM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
  8. Nov 11, 2018 at 5:36 AM
    Macks
    Macks New Member
    Kevin
    Yes. They are a close fit to the cab so I had to put the lights underneath, but I like the way the light comes up through the steps. Its nice to see what I'm about to step in, as well as see if anyone is hanging around (or under) the truck at night.
    619Tundra likes this.
  9. Nov 11, 2018 at 5:42 AM
    619Tundra
    Nice. I have some too.
  10. Dec 1, 2018 at 4:09 PM
    Okietundra
    Okietundra New Member
    OKC OK
    2025 Lunar Rock Platinum
    So you tied into both the driver and passenger sides? I'm assuming that way you didn't have to run wire from one side of the truck to the other? Or I'm missing something... I'm not the most knowledgeable about wiring science Haha.
    Norfolk757 likes this.
  11. Dec 1, 2018 at 4:51 PM
    Okietundra
    OKC OK
    B-e-a-utiful. Thanks man!
  12. Dec 2, 2018 at 7:09 AM
    Okietundra
    OKC OK
    Awesome thanks!
  13. Dec 28, 2018 at 11:31 AM
    Okietundra
    OKC OK
    So I'm about to pull the trigger on the lights. I think I will just tap into the footwell light, that way the lights will fade on and fade off. I should be able to flip the interior light switch to manually turn them one as well. https://www.ebay.com/itm/Running-Bo...rentrq:f644be381670a9ccac0e8e94fff4c123|iid:1
    I think these look fairly decent. I might mount them up on the frame so I get light thrown onto the running boards and the ground around the truck.
    ldale likes this.
  14. Dec 28, 2018 at 1:44 PM
    ldale
    ldale New Member
    Txk Tx
    17' Limited Silver Sky Metalic
    Tonno Pro LowPro , TRD Sway Bar, Helwig Leaf Pack
    Same set I used on my last and current truck.
    Okietundra likes this.
  15. May 29, 2019 at 9:54 PM
    iPerea
    iPerea New Member
    2017 SR5 Tundra
    Leveling kit, under seat tool box, window tint
    Can you give me some tips on how to test which wire to tap into for the running lights? I am going to give this a shot so all info is greatly appreciated!
  16. May 30, 2019 at 3:32 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    Ive gone through 3 different sets on my amp boards. The best I've found was from @mattgecko they are fantastic. 2 Ohio winters and they are as good as the day I installed.
  17. May 30, 2019 at 4:21 AM
    iPerea
    iPerea New Member
    2017 SR5 Tundra
    Thanks for the tip! More specifically, do you have any tips on locating the hot wire under the kick plate so I tap into the correct wire and can still use the switch on the dash etc.?
  18. May 30, 2019 at 6:05 AM
    TundraTSS19
    TundraTSS19 New Member
    San Antonio, TX
    2020 Tundra TSS SR5 Crewmax 5.7L
    LED step bar light strips
    I just used the the little parking brake bulb socket and tapped into that to wire up my running board lights and it works great.
  19. May 30, 2019 at 2:35 PM
    madmatt
    madmatt New Member
    Ocala Florida
    2018 Crewmax 4x4. TRD
    So you guys are all using the existing wiring to supply all the power to your puddle lights, or are you using them to trigger a relay?
  20. May 30, 2019 at 2:39 PM
    phabej
    phabej New Member
    NO LONGER HAVE A TUNDRA... Waiting
    BIGGEST PINK one.. 2018 UP.
    SiberianTundra likes this.
  21. May 30, 2019 at 3:10 PM
    madmatt
    madmatt New Member
    Ocala Florida
    Hmmmmm, I’ve been debating doing this but didn’t want to run a dedicated power wire. This changes things!
  22. May 30, 2019 at 8:29 PM
    2chains
    2chains New Member
    Southern Ablerta
    Will this give you the light fade on/off in 2019?
  23. May 31, 2019 at 9:05 PM
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
    anyone know what to tap into on a 2012
  24. Jun 1, 2019 at 12:23 PM
    Okietundra
    OKC OK
    I tapped the footwell light as well. I like that the lights fade on and off with the lock/unlock keyfob use. Ordered two strips of LEDs off of Ebay and bought a roll of wire. Needed the extra wire to run over to the passenger side.
  25. Jun 1, 2019 at 12:26 PM
    TundraTSS19
    San Antonio, TX
    These are the strips I got and got extra wire as well to run from passenger tod river side and tucked the wires out of site behind the curtain under the passenger seats
    PryEU Daylight White 6000K LED... https://www.amazon.com/dp/B00YXBEHQK?ref=ppx_pop_mob_ap_share
    Okietundra[QUOTED] likes this.
  26. Jun 1, 2019 at 12:33 PM
    phabej
    phabej New Member
  27. Jun 2, 2019 at 7:28 AM
    Okietundra
    OKC OK
    Here are some pics at night.20190601_224444.jpg 20190601_224501.jpg 20190601_224506.jpg
    parker44, 2chains and TundraTSS19 like this.
  28. Jun 7, 2019 at 4:28 PM
    madmatt
    madmatt New Member
    Ocala Florida
    Ok everybody, I’m stupid. How are you running your wires from under the rear drivers side under the kick plate out and under the truck? I just looked pretty hard and didn’t see a way to bring it out. I have a set of lights just BEGGING ME to put them on.
    Thanks!
  29. Jun 7, 2019 at 5:55 PM
    Okietundra
    OKC OK
    Well I ran mine across the front. Tucked down into the console and out through the passenger front door kick plate.
    madmatt[QUOTED] likes this.
  30. Jun 7, 2019 at 9:11 PM
    TundraTSS19
    San Antonio, TX
    When you pull up the kick plate you'll see some holes that look like they don't go anywhere. You'll need a flash light and a thin wire like safety wire. Just under the hole where the body is pinch welded, you can get the safety wire through it and I was able to pull the wires through using a small hook with the wires pinched to it.
    mav7021234 and madmatt[QUOTED] like this.
