Runaway Truck Wheel Sends Kia Soul Flying
Discussion in 'General Automotive' started by katekebo, Mar 27, 2023.
  1. Mar 27, 2023 at 1:05 PM
    katekebo
    katekebo [OP] New Member
    https://jalopnik.com/runaway-truck-wheel-sends-kia-soul-flying-off-the-highw-1850268219
    Here is a perfect example why DIY car modifications should be illegal. Highly educated engineers spend thousands of hours designing a car to make it safe, just to have some half-brained redneck idiot "mechanic" to "improve" his truck, putting other road users at danger.
    Guys who make dangerous mods to their cars should be put in jail and their vehicles confiscated and destroyed.
    If you believe that you are "good at cars", go to college, get an engineering degree, pass the selection process to one of the (highly selective) automotive companies, and then put your talent to a good use. If you fail at any of these steps, it means that your don't have enough brains to mess with cars and keep your vehicle stock.
  2. Mar 27, 2023 at 1:06 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    I'm sorry about your Kia.
    alaska_bou, Blang805, Bogus6 and 13 others like this.
  3. Mar 27, 2023 at 1:16 PM
    Taco-Spike
    Two Trucks
  4. Mar 27, 2023 at 1:17 PM
    WhiteTundra0013
    WhiteTundra0013 New Member
    2013 white tundra
    Trd rear sway bar, Rims, Goodyear wrangler tires,Topper, Nerf bars
    Really? And how do you know that the driver modified his/her truck? Do you have a crystal ball? Maybe the auto place that rotated his/hers tires forgot to torque them down. You are making alot of assumptions when you do not know all the information.
    If you are so againt people who make modifications to there trucks you should stay off this fourm because almost every one here does.
    V3N0M, MTsparky, Gravy and 3 others like this.
  5. Mar 27, 2023 at 1:21 PM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    There may have been a spacer installed on this vehicle, but I can almost guarantee the wheel bearing was screaming well before this moment occurred. This sure looks like the hub separated to me... And if there was a spacer it's still sandwiched in there. Not saying that a spacer may or may not add additional load and decreased life to a wheel bearing, but the spacer itself wasn't the cause here IMO.
  6. Mar 27, 2023 at 1:36 PM
    katekebo
    Watch the video in the link. The truck clearly has aftermarket wheels with large offset. I'm not making assumptions - the video is crystal clear that the wheels were not OEM.
    I am not against car modifications that are made by professionals. I am against DIY idiots who make modifications without a slightest idea of the consequences. As an experienced engineer I deal with such idiots every day.
  7. Mar 27, 2023 at 1:41 PM
    katekebo
    Of course spacers add load to the bearings. Ball bearings have very good radial load capacity, moderate axial load capacity, and very low bending load capacity. Any wheel load that is offset from the bearing plane will add bending load, drastically reducing the life of the bearing.
    mayan likes this.
  8. Mar 27, 2023 at 1:46 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    I mean unless you’re some sort of cyborg programmed by a non-human… even the most well trained individuals make mistakes…
    so much so that there are TV programs to highlight and demonstrate this..
    get off your soap box…
    MTsparky, Blang805, DZ_ and 6 others like this.
  9. Mar 27, 2023 at 1:49 PM
    katekebo
    There is a BIG difference between "mistake" and "stupidity".
    ZappBrannigan likes this.
  10. Mar 27, 2023 at 1:51 PM
    DFW_SoldTacoBoughtTundra
    DFW_SoldTacoBoughtTundra New Member
    DFW
    2021 Limited 4x4
    6112s, Icon add-a-leaf pack, Icon 17s
    Not sure where I fall in this. I did my own modifications but am also a mechanical engineer. Graduated #1 in my class and am in grad school.
  11. Mar 27, 2023 at 1:51 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    There is also a fine line between arrogant and confidence...Would you like to guess which side of the gauge you're on?
    kudzuking, MTsparky, Gravy and 7 others like this.
  12. Mar 27, 2023 at 1:55 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Also, let it be known that an "educated" individual, doesn't necessarily equal a "smart" individual....
    SnrDisregardo, Gravy, 2mchfun and 5 others like this.
  13. Mar 27, 2023 at 1:57 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  14. Mar 27, 2023 at 1:59 PM
    Saltyhero13
    You are permitted to make all the mods you want but can also tell yourself to pound sand if you attempt to make any mods.
    Gravy, 2mchfun, PermaFrostTRD and 4 others like this.
  15. Mar 27, 2023 at 2:04 PM
    TaquitoBandito
    Joel (AKA Bif)
    Mind if I join you?
  16. Mar 27, 2023 at 2:05 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Well after a mundane day at work, I stumble across this Pulitzer-esque op-ed.
    :popcorn:
  17. Mar 27, 2023 at 2:09 PM
    ArticTundra
    ArticTundra New Member
    Cold
    As an accident/crash investigator, this is quite possibly the coolest crash I've seen. Holy Hell...
    "Well you see what happened was...."
  18. Mar 27, 2023 at 2:10 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Engineers are chest thumpers, too. Nobody really has a clue. Just remind yourself these people are doing the best that they can.
    Gravy, 2mchfun, BiggHertz and 2 others like this.
  19. Mar 27, 2023 at 2:11 PM
    Mr Badwrench
    Mr Badwrench New Member
    The wheel rolling into the back of the kia at the end made this infinitely more funny.
    The person walked away, by the way.
    2mchfun, Johnmatrix and Saltyhero13 like this.
  20. Mar 27, 2023 at 2:15 PM
    Mr Badwrench
    Where will this end?
    Can I not put fuzzy dice on my rear view mirror because they *might distract me?
    Gravy, 2mchfun, PermaFrostTRD and 3 others like this.
  21. Mar 27, 2023 at 2:18 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    The government has NEVER been able to save us from stupidity. Good luck finding a law that could prevent this.
  22. Mar 27, 2023 at 2:25 PM
    Saltyhero13
    I was going to say the timing couldn't have been more unfortunate, gladly the driver walked away.
    2mchfun and Johnmatrix like this.
  23. Mar 27, 2023 at 2:41 PM
    TaquitoBandito
    Joel (AKA Bif)
  24. Mar 27, 2023 at 2:48 PM
    Saltyhero13
    BiggHertz likes this.
  25. Mar 27, 2023 at 2:51 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  26. Mar 27, 2023 at 3:09 PM
    Another "look at me"
  27. Mar 27, 2023 at 3:09 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    The biggest thing is simply knowing your limits of your capabilities and resources, being big enough to seek help of a qualified individual to assist.
    2mchfun, ZappBrannigan and Bakershack like this.
  28. Mar 27, 2023 at 3:10 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    all of whom are undermined by the bean counters who haven't a clue...
  29. Mar 27, 2023 at 3:14 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Clearly. F1 engineers and trained athletes with wheel guns get it right every time!
    Life lesson I've learned..."I can make something idiot proof, the lord will devise a better idiot"
  30. Mar 27, 2023 at 3:28 PM
    Windsor
    Windsor Why do I do this to myself?
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    Maybe you should go get a few IT degrees before posting half brained sh** online. However, I did learn quite a bit about you from your posts.
