Rumble Rattling Sound
Discussion in '3rd Gen Tundras (2022+)' started by KingIsCmn, Apr 29, 2022.
  1. Apr 29, 2022 at 7:40 AM
    KingIsCmn
    KingIsCmn [OP] New Member
    2022 Tundra Limited
    I have this annoying rattling/rumbling/gurgling sound in the back right rear of the truck. It only happens when moving. It actually sounds like a bottle is in the door panel and its rattling but I have removed everything from the truck. Does anyone else have this? I am wondering if it happened when they dropped the gas tank to "fix" (its not fixed) the gas gauge. Ive never owned a turbo so Im wondering if it's that or an exhaust leak or something
    Scott
    2022 Toyota Tundra Limited
  2. Apr 29, 2022 at 7:42 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Never heard of this one yet. I would notify your dealer and try to get a video for them. Post it up here too, some smart folks around here will have some feedback.
  3. Apr 29, 2022 at 7:50 AM
    KingIsCmn
    2022 Tundra Limited
    its such a low/quiet tone Im wondering if it would even pick up on the video. It's one of those, "If I turn my radio up" you can't hear it. it's annoying more than I think it's a real problem.
  4. Apr 29, 2022 at 8:07 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Bottle of Mexican Coke left behind? lol j/k
    Sorry about your Gremlin. I hope you get it figured out.
  5. Apr 29, 2022 at 8:25 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    I thought this was a joke about a V8 rumble initially.
    Good luck
  6. Apr 29, 2022 at 10:41 AM
    Phatpanda
    Phatpanda New Member
    I have the exact same sound in the exact same spot. They didn't drop the tank though on my truck. It's a double cab 4x4 TRD OR SR5.
  7. Apr 29, 2022 at 11:17 PM
    GG2SSM
    GG2SSM New Member
    I seem to have the same thing. Going over larger bumps and pot holes on real shtty roads. Like a deep rattle or knocking from the back. Tried with the seats up, down... removed the jack kit and still had it. It's very annoying. Sounds like something hitting the back of the cab.
    Interesting enough, I notice that the rattle wasn't as often or pronounced after I filled the tank to 50%. Got me thinking that I never really noticed it when the tank was full and it seemed to get worse as the tank emptied. Could be just a coincidence but am burning gas just so I can get down to empty to see if the rattle gets worse.
    I figure I would try some trouble shooting before it goes in.
  8. May 6, 2022 at 6:56 PM
    KingIsCmn
    2022 Tundra Limited
    So today I got my Tundra back. The Good news is they had a Tundra for a rental exactly like mine so I was driving a Tundra at least. The bad news….they didn’t find it. They admitted it’s something. Next stop is I take it back Monday (the Tundra is rented out this weekend and I want to drive a full size truck while they have mine…might sound petty but I traded my taco ONLY for room) and they will remove the bed to see if it’s the bed making the noise. The fuel gauge isn’t working STILL and now when I manually turn off the auto start/stop and come to a stop the engine acts like it going to shut off and then “remembers” the start/stop is off only way I can explain it.
  9. May 9, 2022 at 6:52 PM
    GG2SSM
    GG2SSM New Member
    Filled up the tank the other day and went down the same pot filled street. The rattle was not as bad but still there.
    Anyway - I think the gas tank thing was a long shot. Still sounds like something hitting the back window or back of the cab when there is a lot of motion. Maybe bed flexing?
    Rattle was there with the back window down but I can't seem to really hear it if the sunroof is open. Probably another rabbit hole. Anyway, going to the dealer in a couple of weeks so I'll let them figure it out.
  10. May 9, 2022 at 7:03 PM
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    IIRC, I remember seeing pictures of a '22 that someone took extreme four-wheeling at high speed and the bed actually banged against the cab and put dents in the cab. It was almost like there wasn't enough room between the bed and the cab and they were rubbing against each other.
    Maybe you are experiencing a minor version of what happen to this other guy.
  11. May 9, 2022 at 7:50 PM
    KingIsCmn
    2022 Tundra Limited
    My dealer mistakenly kept my spare out and I haven’t heard it in 2 days. Driving tomorrow down a road I know causes the noise. We shall see and will report back.
    GODZILLA likes this.
  12. May 11, 2022 at 12:02 AM
    Gshift
    Gshift New Member
    I have the same thing. But I hear it when I hit a bump and my window is up. It sounds almost like something tapping the glass. I can’t find it though
  13. May 11, 2022 at 1:03 AM
    KingIsCmn
    2022 Tundra Limited
    I really thought I had found mine in the hanging chain from the spare. I taped the chain to the frame but still hear it.
  14. May 11, 2022 at 1:12 AM
    I'd crawl under and see if any heat shields are loose. They've been the culprit for many rattles through the years.
  15. Oct 4, 2022 at 10:36 PM
    Woo1178
    Woo1178 New Member
    Willie
    Grey 22 Tundra Crewman SR5 TRD Sport
    None
    I have sr5 sport crewman i too heard this rattle with the back window down sound like rattle like glass or tin hitting I though it might be tire chain or tail gate chain but no it seems like between the bed and body but only when tank is low
  16. Oct 5, 2022 at 11:32 AM
    Gshift
    Gshift New Member
    I had the same thing. My dealership was able to find and fix it. Behind the backseat they removed the plastic liner and tried to replicate it. They found that a bracket on the passenger side was a little loose. Tightened it and sound has never repeated since. The fix however moved the sensor that tells the truck if the window is open. So my app kept telling me window open. Went back and forget fixed that. So the bracket in question is somewhere near that sensor. Hope that helps
    zonehenge likes this.
  17. Oct 5, 2022 at 1:34 PM
    zonehenge
    zonehenge New Member
    Pete
    Western Mass
    2022 Solar Octane TRD Pro
    285 75 18's Wild Peak, PPF for front, Go Rhino RB20 slims, Truxedo Sentry CT, TVD decals
    Good to know, thanks.
