Rubbing noise coming from wheel when taking right hand turn at speed
Discussion in 'Wheels & Tires' started by chop123, Jun 24, 2017.
  1. Jun 24, 2017 at 11:02 AM
    chop123
    chop123 [OP] New Member
    clifton
    2007 dark green tundra sr5
    I purchased this 2007 sr5 used it only had 82,000 when I got it.The first owner worked at the Toyota dealer and he put rock warriors wheels on it. Back in January I had new rotors put on it in on all for corners,had the work done at Meineke,when went to pay the guy at the desk said something about the brake shield rubbing or something to that effect and they push it back and it was not a problem and to bring back if it did it again.Now I play my music pretty loud so I don't know when the noise started,but I pulled both front wheels and they are tight with no play in them and also took off the rear ones also,checked the brake shields and saw no rub marks.I then took it back to Meineke and had then check it over and they could find nothing wrong.The noise does have that kind of brake shield hollow metal sound to it but we see no wear marks,and again wheels are tight no play at all,i don't think its the bearings and they didn't think so either,what could be making this rubbing sound? thanks!
    Jsena likes this.
  2. Jun 24, 2017 at 8:11 PM
    chop123
    clifton
    No lights are flashing and it makes the noise without brakes being engage,if you turn the stirring wheel while going straight, back and forth it makes the sound when to to the right.It makes me think about wheel bearings,but the wheels have no play in them,and Meineke check for that too,and the noise sounds like that thin brake shield that's around the rotor.Is it possible that Meineke miss it.Iam going to take it to another shop to get it check out.Any other thoughts would be great from my tundra driving brothers.Thanks yalll
    Jsena likes this.
  3. Jun 24, 2017 at 8:20 PM
    chop123
    clifton
    That's just it, got the standard 285/70r 17 that come with the rock warrior wheels and we don't see any rub marks
    Jsena likes this.
  4. Jun 25, 2017 at 6:24 PM
    chop123
    clifton
    I really don't think its in the rock warrior wheels, its something in rotors or brake shield,bearings or something.Anymore ideas out there?Hope to take it to a shop in the morning.
    Jsena likes this.
  5. Jun 26, 2017 at 12:47 AM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
    Wheel bearing
    Jsena and GNTundra like this.
  6. Jun 26, 2017 at 2:38 AM
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    +2 on a wheel bearing. They don't always become "loose". Also, yank those brake shields back! They're pretty flimsy. Not sure about the gen 2, but my gen 1 was ALWAYS getting some kind of weird debris stuck up in there (sticks, small pebbles, rocks...you name it)
    Jsena likes this.
  7. Jun 26, 2017 at 8:11 AM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    +3 on wheel bearing. I just replaced them on wife's 4R... they were noisy when turning, silent the rest of the time and no play in them whatsoever. Changed out bearings.. running like new again.
  8. Jun 26, 2017 at 8:12 AM
    tomsinamerica
    Tom
    Wilmington, NC
    alternatively... it's totally the rock warrior wheels... you should replace them. I'll take them off your hands? ;)
    Sspencer79 likes this.
  9. Jun 26, 2017 at 8:39 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Thats what i am thinking. The wheels are large enough to fit without rubbing unless there is a tall stack of weights in there or the sheild is bent the opposite way. Instead of hitting the rotor it is bent out and hitting the wheel.
  10. Jun 26, 2017 at 8:47 AM
    csuviper
    Broomfield, CO
    Jsena likes this.
  11. Jun 26, 2017 at 9:47 AM
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    I just had the same issue checked on my 2012 CrewMax the calipers were sticking
    GNTundra and Jsena like this.
  12. Jun 26, 2017 at 1:15 PM
    chop123
    clifton
    Just got back from the shop,they say its the driverside rear wheel bearing,sound right to you all?Let me know!
  13. Jun 26, 2017 at 2:58 PM
    Bear
    Bear
    Custer, SD
    Sounds about right. How many miles on her? If you have a few, I'd say replace them all at once. Save yourself the troubles later on
    Edit: just re read first post. 82k seems a bit low for the bearings. Could just be a manufacturer problem as well. Hell...if it were me, I'd still change all of em
  14. Jun 26, 2017 at 7:25 PM
    chop123
    clifton
    You all I still have not got up off the floor,this shop wants to charge me $850 to do the job,i know import stuff is high, but sh!! no way I could do all of them,he said something about the parts are sold in kit,with brakes and all included,is this right or are they trying to scam me.anybody else had this done at a shop?let me know!
