Rubbing issues with 305/65r18?
Discussion in 'Wheels & Tires' started by dv8TRDPRO, Apr 22, 2017.
  1. Apr 22, 2017 at 6:49 PM
    dv8TRDPRO
    dv8TRDPRO [OP] NOOGTRDPRO
    Chattanooga
    2017 Tundra Pro White
    Weather Tech mats, Stubby antenna, AJT gear shift knob, AJT keyfob, Tundra door sill protectors, Cup holder inserts, door pocket inserts, console inserts, Tundra tailgate letter, and TRD PRO bed insert. Kenwood dnx996xr 1299 with navigation, vehicle gauges, and tire pressure sensors gauges Keyless Remote CL6 app remote start 4 rolls of sound shield 1 Jl rd 900/5 2 Jl c2 650 components 2 Jl 10w1
    I just got my 2017 Tundra TRD PRO want different wheels. Not a fan of the stock wheels. I don't want to modify the suspension. I want to stay with the stock TRD setup. I am not sure on how to figure the offset.
    This the set up I am looking at:
    Tires:
    BF Goodrich All Terrain T/A KO2 - LT 305/65r18
    Wheels:
    Fuel
    18 inch 5 lug
    Anza D558
    Will I have rubbing issues?
    Voyagermike likes this.
  2. Apr 22, 2017 at 7:14 PM
    Bienvenidos de Tejas!
    dv8TRDPRO[OP] likes this.
  3. Apr 22, 2017 at 7:21 PM
    R0CKETMAN
    R0CKETMAN IG: @rocketmanmtb
    NGAMTNS
    '17 TUNDRA TRD PRO CEMENT ‘15 TUNDRA SR-5 WHITE
    What's wrong with the Pro wheels?
    Wanna be like everybody else?
    Your question can't be answered without more info.. ie wheel offset.. what suspension mods?
  4. Apr 22, 2017 at 7:21 PM
    Voyagermike
    Voyagermike New Member
    California
    Welcome! Post some photos when you can!:thumbsup:
    Bob likes this.
  5. Apr 22, 2017 at 7:27 PM
    Voyagermike
    California
    Looks like the fuel anza are a +20 offset. He'll most likely have to trimming and a CMC. Not what suspension mod/upgrade he's planning
    R0CKETMAN[QUOTED] likes this.
  6. Apr 22, 2017 at 7:29 PM
    R0CKETMAN
    NGAMTNS
    Maybe but "modding suspension" leaves an open canvas so dunno
    Voyagermike[QUOTED] likes this.
  7. Apr 22, 2017 at 7:33 PM
    dv8TRDPRO
    Chattanooga
    My apologizes for not having a better first post. I just don't like the stock wheels. I don't want to change the suspension, I want to stay with stock TRD PRO suspension. I would like to stay at 0 offset but not sure how to figure that out.
    I also edited my first post to help any confusion.
    zcarpenter92 and Voyagermike like this.
  8. Apr 22, 2017 at 7:35 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Come on man, where my shout out? LMAO
    Welcome @dv8TRDPRO from Colorado.
  9. Apr 22, 2017 at 7:39 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Welcome from Canada!
  10. Apr 22, 2017 at 7:50 PM
    Voyagermike
    California
    Not a huge fan of the PRO wheels myself. Plan on changing them out to something different.
    From what I've read here on the forum anything above 295/70 will require trimming and may have to do a CMC (cab mount chop) Seems like a good offset is between +18 to +25. The 295s will still have slight clearance issues with stock pro wheels(+60 offset IIRC) And have about a finger width between the UCA and tire. That's why offset is important. This is just some information I have gathered from this great site. FYI I don't have my Tundra yet so other members may have some better feedback.
  11. Apr 22, 2017 at 7:55 PM
    Otaku4life69
    Otaku4life69 Welcome to the Dark Side.
    David
    Bay Area CA
    2017 Black SR5 CM
    Pro Comp 7" lift, King Shocks. Moto Metal 961's, 37" Pro Comp Xtreme MT2's, Custom Leather seats, Corsa Exhaust
    Congrats and welcome to the forum.
  12. Apr 22, 2017 at 7:59 PM
    Voyagermike
    California
  13. Apr 22, 2017 at 8:08 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Need to know the offset
    SouthBoundSteve likes this.
  14. Apr 22, 2017 at 8:15 PM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    Method Con 6 or SCS SR8...both in bronze. (Search the forum for pics)
  15. Apr 22, 2017 at 8:29 PM
    TheBeast The Beach
  16. Apr 22, 2017 at 10:29 PM
    I did on Tundras Live! HELLO!o_O
  17. Apr 23, 2017 at 3:48 AM
    R0CKETMAN
    NGAMTNS
    Do your research as did I.
    You'll learn some Coachbulder shims/shackles with give you a small amount of added lift. It will improve the feel of the rear.
    O offset...I dunno
    Yep
  18. Apr 23, 2017 at 5:36 AM
    PermaFrostTRD
    Northern NY
    I wish I knew this tire size existed before I got my 275/70 r18. Basically the same height and 1.6" wider. I currently have zero rubbing and I'm not even the pro suspension (Just stock trd off-road). I'm at least 1.5"-2" from the UCA when the wheel is straight (I don't know enough about suspension to know if that changes when the wheel turns).
    Love the KO2 tire and will definitely get it again. Unless there's some sort of catastrophic failure with them (8000 mi currently. So far so good).
    I like the height of my tire just wish it was a little wider. So I'll likely go 305/65 r18 in the KO2. And probably the billstein 6112 on the low/mid setting up front. But that's a couple of years away. Or another 30k miles. Hahaha.
  19. Apr 23, 2017 at 6:58 AM
    Joeshaker
    Joeshaker New Member
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Bilstein 6112/5160 trd sway bar and ride rite bags. Black and burnt orange wet okole seat covers.
    Stock wheels are +60 offset. The closer you stay to that the less rubbing issues you'll have. You will need to decrease the offset just enough to clear the ucas to fit the 305's. Probably a +35 that is about an inch less. You may still have to stretch the inner fender liners and lose the mudflaps.
    PermaFrostTRD likes this.
  20. Apr 23, 2017 at 8:48 AM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Check out my build thread. I run that size on my truck.
    Voyagermike and PermaFrostTRD like this.
  21. Apr 23, 2017 at 9:05 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
  22. Apr 23, 2017 at 9:09 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Yup. The higher the offset(higher number) the easier it will be to fit. Typically you want to stay +18 and above. There are lots of options with +25 offset wheels
  23. Apr 24, 2017 at 7:39 PM
    dv8TRDPRO
    Chattanooga
    Planning to order wheels and tires tomorrow. Staying with Fuel ANZA 18 D558 but changing the tire to Nitto Terra Grappler G2 285/75 18 in hopes that i wont have any rubbing issues.
  24. Apr 24, 2017 at 7:40 PM
    dv8TRDPRO
    Chattanooga
    Awesome build. Do the back wheels have center caps?
    BlueBottle[QUOTED] likes this.
  25. Apr 24, 2017 at 8:18 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    The wheels come with center caps.. I just choose not to run them.
  26. Apr 24, 2017 at 9:35 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Here is a pic i found online with the center caps
    dv8TRDPRO[QUOTED][OP] likes this.
  27. Apr 25, 2017 at 6:39 PM
    dv8TRDPRO
    Chattanooga
    thanks for the pic
  28. Jul 14, 2017 at 12:39 PM
    JackWagon
    JackWagon Dr. Wookiee
    16 Tundra DC TRD Pro MGM
    Did you order the 285/75/18 and do you have any rubbing?
