Rubber Steering Thingy Replacement
Discussion in '2nd Gen Tundras (2007-2013)' started by myt1, Feb 22, 2020.
  1. Feb 22, 2020 at 3:35 PM
    myt1
    myt1 [OP] New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    I noticed that the rubber thingy...sorry I don't know what it is called...on both sides of my steering arm...I think this is what it's called...are badly worn and torn.
    Do I need to replace it?
    If I do replace it, is there something better than stock that will last longer?
    Thanks so much.
  2. Feb 22, 2020 at 3:57 PM
    Yzed608
    Yzed608 New Member
    Wisconsin
    Is it the boot? The blow up view makes it kind of hard to see what's circled.
    Off-topic, but that photo makes me want to get the Al sensor protector, I have the original steel ones from SDHQ and they're all rusted already. Hope that bolt would come out and not break (I already have 2 snapped bolts on my bumper, yay road salt).
  3. Feb 22, 2020 at 5:30 PM
    It looks like the outer tie rod end.
    Mountun Goat and JohnLakeman like this.
  4. Feb 22, 2020 at 7:44 PM
    myt1
    Richard
    Scottsdale, AZ
    Yes, it appears to be the outer tie rod.
    Are they hard to replace?
  5. Feb 22, 2020 at 8:13 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    That rubber boot on the tie rod end is not serviceable. You will need to replace the entire tie rod end assembly. There is no immediate concern or risk, but if/when dirt gets in through any tears, the joint will wear creating excess movement in the steering linkage. It should become noticeable long before it becomes dangerous. If the tie rod end is going to be replaced, you can do it now, or you can begin "watchful waiting"; i.e. if you're underneath occasionally for oil changes, give the tie rod end a tug to check for looseness in the joint. IMO, it will be years before any wear develops.
    Mountun Goat and Slayer like this.
  6. Feb 22, 2020 at 8:26 PM
    johnnyskullface
    johnnyskullface New Member
    Beaverton, Oregon
    2018 White Tundra Limited Crewmax
    I agree with @JohnLakeman. It’s the outer tie rod ball joint. Don’t worry about it. These are rarely bad enough to cause an issue.
    Mountun Goat likes this.
  7. Feb 23, 2020 at 6:22 AM
    myt1
    Richard
    Scottsdale, AZ
    Thank you sooooo much.
    This is exactly what I needed to know.
    At this point I'm not noticing any symptoms.
    I"ll just continue to watch it.
    JohnLakeman and Mountun Goat like this.
  8. Feb 23, 2020 at 7:01 AM
    bryand
    bryand New Member
    Alabama
    2010 4.6L 2wd DC Black
    Bilstein 5100
    If it does become a problem, outers are easy to do yourself. Just plan on an alignment after.
