Rubber or nylon washers?
Discussion in '2.5 Gen Tundras (2014-2021)' started by dadtrucklife, Sep 12, 2024.
  1. Sep 12, 2024 at 4:31 PM
    dadtrucklife
    dadtrucklife [OP] New Member
    2021 SR5 TRDOR 4x4 (Army Green)
    My cat shield is making creaking and popping noises. As suggested by other members, I plan to try rubber or nylon washers between contact points. Which is better in terms of vibration noise dampening- rubber or nylon? Durability?
  2. Sep 12, 2024 at 4:36 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Nylon or HDPE for durability
  3. Sep 12, 2024 at 4:47 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Any non metallic thing in between will work. I just used basic weather stripping.
    dadtrucklife[OP] likes this.
  4. Sep 13, 2024 at 4:41 AM
    Bergy24
    Bergy24 New Member
    2021 Cement Crewmax Limited TRD 4X4
    Either should work, however when I added them it helped but did not eliminate the noise 100%.
    My fix was to trace all the plate overlaps with a sharpie and then added a layer of rubber roofing membrane between the plates and where they contacted the frame.
    You should be able to pick up some scrap rubber roofing from a local roofing company for next to nothing.
  5. Sep 13, 2024 at 5:06 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    I used rubber washers at first and I had vibrations that I could both feel and hear. I took them out and mounted the plates up without any washers or anything in between and all that went away, been running it like that for almost 2 years.
