Rubber mat/liner suggestions for my Double Cab bed?
Discussion in '3rd Gen Tundras (2022+)' started by DarkStrr, Nov 21, 2023.
  1. Nov 21, 2023 at 11:11 AM
    DarkStrr
    DarkStrr [OP] New Member
    2022 Tundra SR5 2wd
    ARE Fiberglass Cap
    I mainly haul around band PA gear on short "tours" and gigs. I found the rubber mat on my old first gen Tacoma easy on the gear and my knees when I had to climb in. And when I needed to crash out in the truck overnight!
    The liner in the Tundra has much sharper edges -- anyone know what sources there are for a decent correctly cut rubber mat?
  2. Nov 21, 2023 at 11:21 AM
    Two words. Bed Rug
    Adventurer likes this.
  3. Nov 21, 2023 at 11:29 AM
    SD Surfer
    Bruce
    So Cal
    Two more words... Hell Yeah.
    Your knees and your gear will thank you.
    DarkStrr[OP] likes this.
  4. Nov 21, 2023 at 11:44 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Feed and supply store and get a 3/4" stall mat; easy on the knees and it'll provide protection for the equipment and keep it from sliding around so much :thumbsup:
    Mike59 and DarkStrr[QUOTED][OP] like this.
  5. Nov 21, 2023 at 12:00 PM
    This is the way
  6. Nov 21, 2023 at 1:19 PM
    SD Surfer
    Bruce
    So Cal
  7. Nov 21, 2023 at 3:44 PM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    Does bedrug make one for the 3rd gen already?
    I had one in my 2011 and loved it. The foam bottom is shaped/fitted to the ridges in the bed and the rug top is flat. Perfect for what you're doing.
  8. Nov 21, 2023 at 4:07 PM
    Wood-Dro
    Wood-Dro New Member
    Which one works with the bed liner installed similar to the OP's truck?
    I just want one for the bed and it's looking like they only make for spray in liner or no liner at all?
    Or do we have to go with the cut to fit option?
  9. Nov 21, 2023 at 4:12 PM
    Hella Krusty
    Hella Krusty New Member
    I have the OEM rubber matt....kinda stinks . If you want to save money I would just cut a hunk of carpet to fit. If you are loaded ....carpet like it all like Knabores
  10. Nov 21, 2023 at 4:24 PM
    Oldandfat
    Oldandfat New Member
    Cannuckastan
    2024 SR5 TRD Offroad Lunar Rock
    What’s wrong with the oem mat? (Other than it being back ordered)
  11. Nov 21, 2023 at 5:07 PM
    It’s a kit. Sides and bottom. It’s padded. It’s divine. Washable. Non slip. Easier to move stuff on than rubber though. The best.
  12. Nov 21, 2023 at 5:56 PM
    DarkStrr
    2022 Tundra SR5 2wd
    ARE Fiberglass Cap
    The problem with the bed rug is that I want the option to sleep in the back.
    I’m sure you ask “wait isn’t the carpet then a good thing?” Well yes, but in the real world there’s rain and mud getting in the back — and a plain rubber mat wipes dry very fast. Carpet? Not so much.
  13. Nov 21, 2023 at 6:11 PM
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    Thought you had a cap.
    Anyway, it's not really carpet. It's poly fibers and you can brush it, hose it, vacuum, etc.
    The only downside is dog hair and sawdust. Gets stuck in the fibers and a bitch to get out.
    The best part is the foam bottom that interlocks with the ribs in the bed. If they don't make a bedrug for your truck that does that, then I'd say you're better off with a rubber mat, stall mat, etc.
  14. Nov 21, 2023 at 6:24 PM
    DarkStrr
    2022 Tundra SR5 2wd
    ARE Fiberglass Cap
    I’m quite tall and sleep with the cap and tailgate open, with maybe a tarp over. These are usually post gig crashouts in the back at music festivals etc.
    RichterScale[QUOTED] likes this.
  15. Nov 21, 2023 at 7:58 PM
    DarkStrr
    2022 Tundra SR5 2wd
    ARE Fiberglass Cap
    The more I look at this, the less I’m
    Worried about a little rain coming in
  16. Nov 22, 2023 at 4:28 AM
    DarkStrr
    2022 Tundra SR5 2wd
    ARE Fiberglass Cap
    I have an ‘89 Ford with a Spirtsmobile conversion — which was great for attending festivals. Now that I’ve joined a band and started playing them, it’s not as easy to focus on creature comforts…!
