Rubber eraser wheel
Discussion in 'Detailing' started by Pudge, Jul 25, 2019.
  1. Jul 25, 2019 at 7:15 PM
    Pudge
    Pudge [OP] Super Secret Elite Member #7
    CT
    2015 Blue Ribbon Platinum
    I used one today for the first time. Hooked it to my drill, after getting used to it I am throughly impressed. Used it to get foam and adhesive off a truck beside top that was there from when the truck had a cap.
    I hit it with some stoner tarminator after and was shocked how well the area cleaned up.
    Btw that tarminator is an amazing product in itself, I plan to buy a few more cans and use it often. I'll do a post about that too .
    Beforeand after bedrail
    jeremyd, War Machine, NUDRAT and 3 others like this.
  2. Jul 25, 2019 at 7:22 PM
    Pudge
    CT
  3. Jul 25, 2019 at 7:30 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Be careful with the eraser if you are going over a panel that has been painted before. You stand a fairly good chance of damaging the paint, I see it a lot at the shop.
  4. Jul 25, 2019 at 7:37 PM
    Omohundro
    Jody
    McMinnville TN
    As a matter of fact one of my guys did it today. This is NOT the proper way to fix this when it happens, but this truck is a train wreck. If the panel is not prepared correctly the heat from the wheel will lift the paint right off. It had a LIMITED nameplate on it (F-150) E62A0B80-A32F-436A-8C03-EEBE16D52FF1.jpg
    Pudge[OP] likes this.
  5. Jul 27, 2019 at 8:24 PM
    Pudge
    CT
    Yikes. I guess I got lucky. I had always read these were paint safe.
