RPMs jump and speed drops near top of steep grades
Discussion in '2.5 Gen Tundras (2014-2021)' started by DSTundra, Jun 9, 2019.
  1. Jun 9, 2019 at 5:01 PM
    DSTundra
    DSTundra [OP] New Member
    Dave
    Albuquerque, NM
    2017 Tundra Platinum
    I own a 2017 Tundra Platinum with just under 22,000 problem free miles -- until today. My daughter was house sitting for her college roommate's parents in Las Cruces, NM when she had problem with her vehicle, a 2015 Ford Focus SE. So being the good dad, I went to U-Haul, grabbed a car dolly, and my wife and I made the 3 hour trek down I25 from Albuquerque where we live to Las Cruces to pick up her and the vehicle. The trip down with just the dolly was uneventful...
    The road from Albuquerque to Las Cruces certainly isn't mountainous, but there are some fairly steep grades in a few places. On the way back, with the Ford Focus now in tow, I hit the tow/haul button, set the cruise control for 70, and started back home. On 3 separate occasions near the tops of those fairly steep grades, the truck, which would be running at around 3000 RPM at the time, suddenly felt like it went into neutral -- the RPMs jumped to 4000 or more and the speed dropped dramatically -- like it was trying to downshift, but couldn't find a gear. If there would have been anyone behind me -- especially the first time it happened -- I probably would have been rear-ended. In each case, the transmission seemed to reengage immediately when I hit the gas.
    What would cause something like that to happen? Transmission issue? Tow/haul issue? Cruise control issue?
    I'm at a loss...
    Dave
  2. Jun 9, 2019 at 5:34 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    These damn transmissions and their AI are often more like counselors and therapists than hard working mechanical components.
    Don't tow with cruise control on. I use the S mode. So I can pick the gear which really means monitor my RPM's to stay solidly in the torque curve.
    JohnLakeman, CMB and Black Wolf like this.
  3. Jun 9, 2019 at 5:36 PM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    In theory you should have thrown a code. Outside of bad gas and carbon build up from consistent low rpm driving, we'll have to resort to old school mechanical evaluation. Has this reocurred with the same tank of gas, or engine load, or higher rpm? Dirty or neglected air filter? Aftermarket intake or exhaust? Dirty MAF, throttle body, etc?
    OTH, Did it seem as if it was "cut off" as opposed to a mechanical fault? I haven't towed with cc on. You could hook up to something and try towing in THM without cruise on and see if you can replicate it.
    :popcorn:
  4. Jun 9, 2019 at 6:21 PM
    DSTundra
    Dave
    Albuquerque, NM
    Probably good advice...thanks. My truck is my daily driver, so I don't tow with it often. In fact, it's probably the first time I've towed anything with this particular Tundra. I towed small trailers and a car with my 2001 Tundra, but not on the same route. I think I used tow/haul back then (the button on the end of the shift lever on first gens) with cruise control and I didn't have any issues.
    Today was the first time I've every had this happen, so I don't have much in terms of a pattern to go on other than a relatively steep grade seemed to bring the condition on. As for gas, I suppose it's possible the issue can be bad gas. When I started the trip down, I had just over 1/2 tank of gas, so I'd been driving around town using that tank of gas with no issues. I filled up at a Chevron for the trip back home. I always use Chevron and have never had issues with gas before. (That sounds bad... LOL) I use two bottle of injector cleaner every 5000 miles or so. Air filter is clean. OEM exhaust. Didn't seem like a gas issue. No bucking, surging, etc. -- just felt like it went to downshift and couldn't find a gear.
    Dave
  5. Jun 9, 2019 at 6:30 PM
    Tierhog
    Tierhog SIG-AHOLIC
    If your not experiencing any of the symptoms now, I'd suspect that your cruise settings may have played a role as others suggested. Just FYI the detergents in most gasoline keep injectors and the valve area clean nowadays, even with Costco gas, etc. Just to be certain, no TSS interference? 17s even have it?
    Tundyfundy likes this.
  6. Jun 9, 2019 at 6:41 PM
    DSTundra
    Dave
    Albuquerque, NM
    No, 2017 was the last year without the TSS stuff.
    Tierhog[QUOTED] likes this.
  7. Jun 9, 2019 at 7:26 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    No. The 2017's don't have those like were introduced with the 2018's.
  8. Jun 9, 2019 at 7:40 PM
    DSTundra
    Dave
    Albuquerque, NM
    Looking at the manual now -- something I should have done BEFORE my trip -- I see where it clearly states that cruise control should not be used when towing. Luckily we all made it back in one piece and I learned something along the way. There's a good chance that there's nothing wrong with my truck other than with the idiot behind the wheel.
    Dave
  9. Jun 9, 2019 at 8:01 PM
    This^^^.S mode.
  10. Jun 9, 2019 at 8:05 PM
    RTFM???? I've been explaining for years with my junior cal techs.....before you come to me....did you RTFM? Read the f:censored:ing manual?? All is good but a huge pet peeve for me.:frusty:
  11. Jun 9, 2019 at 8:08 PM
    Don’t use cruise control when towing.
    Rica25 and Black Wolf like this.
  12. Jun 9, 2019 at 8:11 PM
    Rica25
    Ricardo
    Tulare
    Do you have stock tires or lift?
  13. Jun 9, 2019 at 8:51 PM
    ChrisTRDPro
    ChrisTRDPro New Member
    MT
    2017 Tundra TRD Pro CM
    Yep, the cruise control will just cut power and shut itself off instead of doing a double down-shift to keep speed up.
    Small grades it seems to do fine if it only has to down-shift once, but if it determines it would need to go down more than one gear it will just deactivate itself. At least that's what happens in my experience, when I step on the gas afterwards it clearly shifts down more than one gear. Had it happen a few times when not towing.
    lewi3069 likes this.
  14. Jun 9, 2019 at 8:52 PM
    handyman
    handyman New Member
    2016 Crewmax Limited in Sunset Bronze Mica
    BFG All-Terrain TA KO2 Tires, Pillar Grab Handle, Curt Front Hitch & Winch Mount, Smittybilt XRC-8 Winch, Escort Solo S3 Radar Detector, Tekonsha P3 Brake Controller, Galaxy DX 2547 CB Radio, Center Console Organizer & Tray, ESP Rear Seat Storage, SumoSprings, Pop & Lock Tailgate Lock, AMP Bed Step, AMP Side Steps, BacFlip G2 Tonneau Cover, and more pending.
    As you've discovered, the owners manual does say the cruise control is not compatible with towing. My truck did the same thing, with nearly the same response from me (worry & concern). And, like you, I discovered this little tidbit afterwards (after noticing a connection between the problem & the cruise control). I have since towed several more times, without the cruise control and without the problem returning.
    Sadly, towing (slower speeds over long distances) is exactly the time I'd most want the cruise control. :annoyed:
  15. Jun 9, 2019 at 8:52 PM
    Boxer310
    Boxer310 New Member
    2018 white tundra crewmax sr5
    Use the s mode sonthe truck doesnt need to switch gears
  16. Jun 10, 2019 at 5:04 AM
    DSTundra
    Dave
    Albuquerque, NM
    Exactly!
  17. Jun 11, 2019 at 12:24 PM
    VTYOTA
    VTYOTA I DECLARE BANKRUPTCY!!
    Howard
    'Merica
    2014 SS CM TRD
    Sometimes you just want to cruise in beast mode.
    Watt maker likes this.
  18. Jun 11, 2019 at 1:36 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    How so? The gears still shift while in S mode.
  19. Jun 11, 2019 at 2:26 PM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    The gears will still shift in S mode for sure. If WE choose the gears, they'll be the gears that won't allow all the needless, heat producing, transmission frying shifting. Lugging down the transmission like that under load, with the Torque Converter never getting a chance to lock, will shorten it's life. Transmission Techs will tell you the same thing. Our Tundra's Manual Shift Mode is there for a reason....BUT, it takes a little effort; that's why I look for Toyota to delete it in the coming years!o_O
  20. Jun 11, 2019 at 2:33 PM
    Tundyfundy
    Bay Area, CA
    I believe you are saying S mode is manual shift mode? That is not true. S mode limits the transmission from shifting into a higher gear then selected: for instance if S mode is set to 4, the transmission cycles through 1-4 normally, no need to shift manually. It just won't go into 5. Set it and forget. It's a gear limiter, not a mode for manual shifting. That's why when you turn it on it always goes to 4 or 3, not the gear you are currently in. So if you're in 4 and press the gas hard, it will jump gears down until needed and then function like a regular transmission up until your selected gear. If S mode is in 6, it functions exactly the same as D mode. Is this what you're saying?
  21. Jun 11, 2019 at 2:54 PM
    CMB
    CMB New Member
    Cecil County MD.
    This is how I use S mode. My speed, load and road conditions dictate the highest gear I choose. Normally, I'll drop down through the gears as speed permits (my 10" BA Exhaust and IPT Valve Body with shift kit makes this procedure more informative:D) When stopped at a light, I choose 3rd gear, sometimes 2nd. Truck shifts through those gears and at that time, I decide when to upshift through at least till 5th. Going around corners at a slow speed, I shift into 2nd,then shift up as needed. Low speed hills, I drop to a gear I know will be low enough to stay 'locked-up' and up-shift as speed allows. On down grades, I choose the lowest gear to maintain a safe speed. My OEM brakes will need replaced at 100,000 miles or so, according to my Mechanic. All this works "for me", we're all different.:thumbsup:
    Tundyfundy[QUOTED] likes this.
  22. Jun 11, 2019 at 3:11 PM
    Tundyfundy
    Bay Area, CA
    Nice, I think we're saying the same thing. Please post more info on your truck! Looks awesome! What is that shift kit and valve body doing for you?
  23. Jun 11, 2019 at 4:26 PM
    CMB
    CMB New Member
    Cecil County MD.
    Thank you Sir! I started out with the 'Spoolin' valve body kit that used Billet Rods as spacers but it slammed into gear as hard when creeping along in traffic, as it did under full throttle. Read about John Lombardo and his Transmission Shop in NJ and contacted him. He was great at explaining his Valve Body upgrades and assured me my truck would "wake-up" as the RPM's increase, just like I was after. Easy to do deal because he sends his kit to you and after install, he gets your old Valve Body. The core charge comes right back in a few days. I normally 'let-up' between the lower gears when just "airing her out" but if I stick with it and keep the pedal down, it'll bark between 2nd and 3rd like F-150 owner's only have wet dreams about!:devil: As far as more info about my heap, my "mod-list" is better than 40 items long!:eek: Yes, I have a problem.:anonymous:
    Watt maker and Rica25 like this.
  24. Jun 11, 2019 at 7:40 PM
    Rica25
    Ricardo
    Tulare
    My 2008 seems to be fine when in cruise control in up hill travel I wonder if it a third gen ecu new set up
