RPM increase when excelerating.
Discussion in '2nd Gen Tundras (2007-2013)' started by danjoe, May 12, 2024.
  1. May 12, 2024 at 1:21 AM
    danjoe
    danjoe [OP] New Member
    2008 5.7 4x4 Tundra
    4'' lift kit, Stainless Step Tubes.
    My 2008 tundra revs up when accelerating while making a turn. Any ideas?
  2. May 12, 2024 at 5:09 AM
    Low transmission fluid maybe? Feel like the transmission is slipping?
  3. May 12, 2024 at 5:30 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I suspect that it's probably a 2-1-2 down/upshift, particularly when things aren't warmed up yet. The transmission has a different shift schedule when it's not up to operating temperature.
  4. May 12, 2024 at 5:31 AM
    2mchfun
    Revs go up when accelerating???:der: Generally speaking,, that is what occurs. More info or move the seat back.
  5. May 12, 2024 at 9:26 PM
    danjoe
    2008 5.7 4x4 Tundra
    Well I mean that the rpm's increase to a greater proportion than the acceleration would suggest. Feels like clutch is slipping.
  6. May 12, 2024 at 9:57 PM
    Vizsla
    Vizsla pretend2send
    The power steering has a pressure sensor to raise rpm under higher pressure, if it only happens while turning, might be good place to start.
    Zoso and 2mchfun like this.
  7. May 12, 2024 at 9:57 PM
    2mchfun
    Watch the car care nut video on Youtube for a lesson on checking the fluid if you need a little help on checking the fluid level. Check your cooler lines and and rear seal at driveshaft for signs of leakage.
  8. May 13, 2024 at 12:58 AM
    Zoso
    Zoso New Member
    SE Georgia
    2021 Cement DC LTD
    accelerating -
    • increase in amount or extent
    • (of a vehicle or other physical object) begin to move more quickly.
      "the car accelerated toward her"
  9. May 13, 2024 at 8:07 PM
    danjoe
    2008 5.7 4x4 Tundra
    So I guess this is normal? Anyhow I'll check my fluid.
  10. May 13, 2024 at 8:14 PM
    2mchfun
    Depending on how long you have had and been driving your truck you might or might not know normal. I have never used it before, but some folks swear by Lubeguard bottled additive for treating slipping. Good luck!
