ROUND 3 | GROUP BUY: Morimoto XB LED FOGS (20% Off)
Discussion in 'EleDobleU's Retrofits' started by eledobleu, Apr 5, 2017.
  1. Apr 5, 2017 at 9:17 AM
    eledobleu
    eledobleu [OP] retrofitwholesale.com
    Orlando, FL
    Koito Bi-LED Retrofit
    XB LED FOG LIGHTS GROUP BUY ROUND 3
    ***GROUP BUY IS NOW CLOSED***
    10+ MEMBERS NEEDED FOR GROUP BUY
    Current Member Purchase Count = 20+
    20% + FREE Shipping to Continental United States
    HOW TO PURCHASE:
    Click the following links below to go directly to the purchase page on RetrofitWholesale.com. During checkout, use coupon code "tundras20" Coupon is restricted to 1 item per order. So if you want to order more than 1, you must do separate transactions.
    If you don't see an email confirmation after purchase, please check your Spam Folder.
    END DATE:
    TO GIVE PEOPLE PLENTY OF TIME TO PURCHASE, THIS GROUP BUY WILL LAST UNTIL SUNDAY @ MIDNIGHT 4/23/2017 Eastern Time. HAPPY EASTER!
    Please note fog lights will not begin shipping until after group buy has closed. You will receive a shipment confirmation email once your order has shipped so please check your inbox/or spam folder.
    PURCHASE LINKS:
    XB FOGS TYPE T (14-Present) TOYOTA (OVAL): MORIMOTO XB LED FOG LIGHTS - Retrofit Wholesale
    XB FOGS TYPE T2 (07-13) TOYOTA (ROUND): MORIMOTO XB LED FOG LIGHTS - Retrofit Wholesale
    RULES:
    1. You must be a forum member.
    2. During checkout, you must include your forum username (SEE EXAMPLE). Any orders without verified forum usernames will be canceled and refunded before or after group buy has closed
    WARRANTY:
    Fog lights comes with a 10 year warranty!
    Please read Warranty Details: Warranty - Retrofit Wholesale
    SPECS
    • Light Source: 3x Philips Luxeon-T
    • LED Optics: Kuria-2 Projector Fog Lens
    • Intensity: 2400 Lumens (1200 per fog light)
    • Kelvin Rating: 5500K (pure white)
    • Input Socket: Sealed H11 Male
    • Weather Rated: IP67 Waterproof
    • Lens Material: High Impact Polycarb (UV-Resistant)
    • Shell / Heat Sink: Powder Coated Cast Aluminum
    PICTURES:
    XB FOG LIGHT INSTALL GUIDE
    XB FOGS ARE A DIRECT SWAP
    Gen 2
    1. You need to go through the wheel well liner. Once you remove it, you will have access to the fogs.
    2. Disconnect the fog lights connector.
    3. Theres 1 Plastic retainer that holds the fog light in place. Use a flat head screw driver to unlock it. Remove the fog light by pushing foward and out.
    4. Get your new XB fogs. The fog lights are NOT L/R Oriented.
    5. Check the connectors polar pattern. Its reversed compared to standard connectors. Insert the wires into the blank connector noting the proper orientation of the Positive and Negative wires. (Be careful as once you lock it in the connector, its extremely difficult to remove).
    6. Slide the XB fogs in its place and use the plastic retainer to lock it in place.
    7. Connect the Fog Lights to OEM connector.
    Gen 3
    3. Disconnect the fog lights connector.
    2. There are two slots and 1 screw that holds the stock in place. Remove the scew and slide the stock fog light.
    3. Get your new XB fogs. The fog lights are L/R Oriented. Look on the back of the lights to locate the L/R letters to know which side. R= Passenger, L=Driver.
    4. Check the connectors polar pattern. Its reversed compared to standard connectors. Insert the wires into the blank connector noting the proper orientaion of the Positive and Negative wires. (Be careful as once you lock it in the connector, its extremely difficult to remove).
    5. Slide the XB fogs in its place and either use the new screw that came with the fogs or re-use the old. Its a tighter fit as the tabs on the XB are thicker. Tighten the screw down.
    6. Connect the Fog Lights to OEM connector.
    AIMING
    Since everyone has different heights on their truck, I cant give you a specific way to aim them. Best way is before removing your old fogs, drive back 10-15ft from a wall or ground and use tape to mark where your lights are.
    The XB fogs are projector base LED's so the light will be more focused. Start by aiming them to the stock levels. Drive around without headlights on (parking lights off) so you can see where the spread is.
    Spread should be about 4-10 ft in front of your truck depending on your headlights.
    For those with retrofits, you want the XB fogs to end right at the beginning for your main HID or LED projector beam spread.
    For those with stock halogen reflectors (with or without hid or led upgrades in reflector housings), you want the beam to end towards the middle of the main headlights beam spread.
    Raise and lower to get your optimum desired height.
    Hope this helps guys
  2. Apr 5, 2017 at 9:27 AM
    Viper3G
    Viper3G Why isn't work more like this?
    Rick
    2016 Crew Max 1794 4WD Super White
    Phillips X-treme Ultinon LED H4 bulbs, 3M Color Stable 35 tint on front doors, 3M Crystalline 40 on sunroof, OEM bed liner, OEM running boards, Morimoto fog LEDs, Fold-A-Cover G4 Elite, Husky X-Act Contour floor mats
    If you haven't replaced your OEM fogs lights get these. Plug and play, and it is easy to install! One of the best changes I've done to my Tundra so far.
    SouthBoundSteve likes this.
  3. Apr 5, 2017 at 9:47 AM
    ej63090
    ej63090 New Member
    Eric
    McHenry, Illinois
    2017 White Crewmax SR5
    Does anyone have pictures with the lamix film?
    Also getting this error.
  4. Apr 5, 2017 at 10:31 AM
    eledobleu
    Orlando, FL
    Try again! Coupon code has been fixed.
  5. Apr 5, 2017 at 10:52 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Steve and @Viper3G, do you guys run these fogs all the time with your headlights? Ever get flashed? And since Retros are so far down on my list, do these help a lot with the crappy stock headlights while driving?
  6. Apr 5, 2017 at 11:03 AM
    Sporto
    Sporto New Member
    2014 Radiant Red Tundra Limited CM TRD
    Just ordered a set. Coupon code is now working.
  7. Apr 5, 2017 at 11:08 AM
    ej63090
    ej63090 New Member
    Eric
    McHenry, Illinois
    Have you gotten any feedback on these with the Lamin-X yellow film on them? Any pictures?
  8. Apr 5, 2017 at 11:44 AM
    mazmaz17
    mazmaz17 New Member
    2017 Cement TRD Pro
    Awesome! Just placed my order. I can't wait to see how these look with my retrofits.
  9. Apr 5, 2017 at 12:27 PM
    Viper3G
    Rick
    I played with the leveling screws when I installed mine so the beam would extend farther out, but not as far as the headlights. :devil: Saying that, I have them on 95% of the time and have never gotten flashed once. And I drive around Los Angeles which has a lot of impatient, temperamental, awful drivers. Of course now that I've put that in writing I know what's gonna happen the next time I'm driving around at night.
    The Morimotos do make the OEM headlights look pathetic which is why they are on almost always.
  10. Apr 5, 2017 at 1:32 PM
    eledobleu
    Orlando, FL
    Not many ordered the Lamin-X film. The ones who did I havent heard anything from them. Hopefully they can post pictures and night shots of it. I will add those pictures to the first post.
  11. Apr 5, 2017 at 1:41 PM
    TheBeast The Beach
    btw for gen2 instructions, no L/R orientation. They are the same.
  12. Apr 5, 2017 at 1:56 PM
    Drew05
    Drew05 New Member
    With the laminx film do the light look yellow or are they still white?
  13. Apr 5, 2017 at 2:05 PM
    eledobleu
    Orlando, FL
    Post updated Thanks!
    TheBeast[QUOTED] likes this.
  14. Apr 5, 2017 at 3:12 PM
    ej63090
    ej63090 New Member
    Eric
    McHenry, Illinois
    I did some outside research and saw that some look very yellow (JDM style) and some look almost green or pale yellow, typically with the same setup (Morimoto XB with lamin-x). Is the Lamin-X removable.
  15. Apr 5, 2017 at 3:13 PM
    baylrballa
    baylrballa New Member
    2016 Black Crewmax Limited
    This might tide me over nicely until time for retrofits.
  16. Apr 5, 2017 at 3:24 PM
    Drew05
    Drew05 New Member
    How many orders we got so far??
  17. Apr 5, 2017 at 3:30 PM
    eledobleu
    Orlando, FL
    I added a counter at the top
  18. Apr 5, 2017 at 3:37 PM
    Drew05
    Drew05 New Member
    If it gets to 9 i will make it 10.
  19. Apr 6, 2017 at 6:40 AM
    eledobleu
    Orlando, FL
    Already at 10 buddy!
    Help likes this.
  20. Apr 6, 2017 at 7:46 AM
    ej63090
    ej63090 New Member
    Eric
    McHenry, Illinois
    Will the lamin-x film come off or does it come not covered?
  21. Apr 6, 2017 at 7:52 AM
    eledobleu
    Orlando, FL
    You have to apply it on your lights. Once applied, it will not come off.
  22. Apr 6, 2017 at 8:40 AM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
  23. Apr 6, 2017 at 9:04 AM
    ej63090
    ej63090 New Member
    Eric
    McHenry, Illinois
    I'm in!
  24. Apr 6, 2017 at 1:36 PM
    eledobleu
    Orlando, FL
    Current Member Purchase Count = 13
  25. Apr 7, 2017 at 6:45 AM
    eledobleu
    Orlando, FL
    Order #6205 , please send your username via PM
  26. Apr 8, 2017 at 10:10 AM
    eledobleu
    Orlando, FL
    Current count=19
  27. Apr 8, 2017 at 10:30 AM
    Pcoz
    Pcoz New Member
    Patrick
    Southern MD
    TRD Grill and Hood Bulge
    I'm probably in but I want to do the headlights too.
    I haven't quite figured out how (or what) to assemble....lol
  28. Apr 8, 2017 at 11:51 AM
    ej63090
    ej63090 New Member
    Eric
    McHenry, Illinois
    Did you get my PM on changing the delivery address of my order? I had an issue with people jacking my packages from my porch.
  29. Apr 8, 2017 at 6:06 PM
    McReef
    McReef '17 Tundra TRD Pro Crewmax
    Eastern MA
    Ok, I'm on board.
  30. Apr 8, 2017 at 9:56 PM
    AKJ78
    AKJ78 New Member
    Aaron
    San Diego
    2016 Silver Platinum 4X4
    3/1.5 lift. TRD sway bar. Bakflip V1 cover. Fuel wheels w/BFG A/T.
    Order placed! Can't wait to get them!
