Rough start when 20 or below
Discussion in '2nd Gen Tundras (2007-2013)' started by jham101, Nov 26, 2023.
  1. Nov 26, 2023 at 4:05 AM
    jham101
    jham101 [OP] New Member
    Hey
    my crew max is really starting rough when it’s 20 or below. It sounds like a belt is slipping for a second or so. Any thoughts?
    thanks
  2. Nov 26, 2023 at 5:32 AM
    gnatehack
    gnatehack New Member
    Middle of Minnesota
    13 SR5 5.7 4x4 Bench
    Up to date maintenance
    - Pulley bearings (fan, tensioner, idler, water pump) going bad.
    - Serpentine belt slippage due to cold/age.
    - AC compressor or PS unit bearings going out.
    Maybe its you screaming when you grab the cold steering wheel??!!
  3. Dec 21, 2023 at 8:13 PM
    platinum12
    platinum12 New Member
    Is your truck a flex fuel? If so you may want to lookup hard start issue on flex fuels. The alcohol density gets too high and causes starting issue on the first start of the day.
  4. Jan 16, 2024 at 9:12 AM
    jham101
    No it's not a flex fuel. I'm taking it to get the serpentine belt replaced tomorrow. we will see what that does. thanks
