Rough Shifts 2024 Sequoia
Discussion in 'Sequoia 3rd Gen (2023+)' started by Chiahead4ever, Sep 29, 2024.
  1. Sep 29, 2024 at 5:29 PM
    Chiahead4ever
    Chiahead4ever [OP] New Member
    I recently purchased a 2024 Sequoia. I only have 100 miles on it but started to notice when coming to a stop on a hill or slowly accelerating it seems to shift abruptly and not as smooth as I remember during the test drive. I used to have a 2017 highlander so the transmission was very smooth and never seemed to jump between gears. Is this normal for one of these transmissions?
  2. Sep 29, 2024 at 5:33 PM
    thomez
    thomez New Member
    NE Ohio
    Silver ‘24 Tundra Platinum
    Hybrid right? You might be noticing the change between regenerative braking and hydraulic? And the changes between electric operation and the engine kicking on?
  3. Sep 29, 2024 at 5:45 PM
    Chiahead4ever
    Yes it’s a hybrid. When accelerating you can’t tell any difference in hybrid vs the engine…I watch the max gauge and listen for the engine and it’s not happening there. On accelerating slow it’s when the engine is engaged.
    For slowing down, engine is off, but it’s definitely a shift of the transmission. I hold the brakes at a constant pressure and you still feel a rough shift. Not sure if the tundras with the max system do that as well?
  4. Oct 3, 2024 at 6:59 PM
    manofsteele2003
    manofsteele2003 New Member
    Grant
    24 Sequoia TRD Pro
    Westcott designs 3"/1" lift 295/70/18 Falken Wildpeak RTs Canvasback cargo liner aFe Tow hooks
    They're all hybrid BTW
