Rough running and electrical issue
Discussion in '1st Gen Tundras (2000-2006)' started by Gryf, Jan 15, 2021.
  1. Jan 15, 2021 at 3:42 PM
    Gryf
    Gryf [OP] New Member
    2000 Limited
    None, Yet
    I recently purchased a 2000 Tundra. I drove it from Southern Utah to Northern California and had no problems during the trip. Everything worked flawlessly the entire trip.Since I got it here in mid December I have been driving it as my primary vehicle. Honestly not all that much driving because, well, California lock down.
    Last week I had to drive about an hour on the highway and I noticed that my cruise control would randomly shut off. As I was trying to figure out what is occurring I noticed that my turn signals were acting erratically, fast flicker and then not operate at all. I noted that both of these things happen at the same time. If I put my turn signal on while driving the cruise would shut off.
    What is strangest is when the truck is at idle, like at a stop or when I an coasting down a hill, the turn signals and cruise control work fine. When I put it under load then things get erratic. Sometimes the ABS light kicks on as well and an occasionally the check engine light will flicker.
    My first thought was a bad ground but this all only happens when the engine is revving.
    I am wondering if this might be a bad battery or alternator but I don't want to replace them and find out there is no difference. I can't find any place where there is an electrical issue.
    Would a bad battery cause these types of problems?
  2. Jan 15, 2021 at 4:00 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Swing by your local Vatozone and have them check your battery and alternator.
  3. Jan 15, 2021 at 4:07 PM
    Professional Hand Model
    Hand Protectors
    How many miles on the truck?
  4. Jan 15, 2021 at 4:18 PM
    Gryf
    2000 Limited
    None, Yet
    263,000
    It's had a full run down already. All the engine work was done for the 250K service including timing belt, compression.. all of it. The mechanicals are top notch.
  5. Jan 15, 2021 at 4:21 PM
    Hand Protectors
    Alternator makes weird stuff happen when brushes go bad. Seems our trucks Alternators fail around 220k plus/minus miles.
    Could be a bad battery but usually it doesn’t make weird stuff happen.
  6. Jan 15, 2021 at 4:50 PM
    04DCTundraMan
    04DCTundraMan Crimedog McGriff
    Ryan
    2004 Salsa Red Tundra Limited DC
    Sony Head Unit, Pioneer Speakers, Back up camera, Blacked out Emblems, SPC Control Arms, OME 2.5" front lift, 1.5" rear spacer, Flowmaster Super 44 muffler, LineX bedliner
    Alternator could have shit the bed after it was checked. I second autozone test of battery and alternator.
  7. Jan 19, 2021 at 7:58 AM
    Gryf
    2000 Limited
    None, Yet
    Replaced alternator. Everything is working fine now.
    I had the battery checked and the new alternator voltage regulator fails. I am going to warranty the new alternator since it's possible I got a lemon. Is it possible there is something on the truck that is killing the alternator?
    Is there anything in the electrical system that y'all can think of that might burn out a voltage regulator?
  8. Jan 19, 2021 at 2:29 PM
    Hand Protectors
    What brand Alternator are we warranting with this failed voltage regulator?
