Rough idle and vibrations
Discussion in '3rd Gen Tundras (2022+)' started by CalTunda23, Feb 27, 2023.
  1. Feb 27, 2023 at 6:55 AM
    CalTunda23
    CalTunda23 [OP] New Member
    Cal
    2023 Tundra Limited
    Anyone else have an issue where their third generation tundra starts to idle a little rough and vibrate when stopped? It doesn’t do it all the time but often enough where I’ve taken it to the dealership twice and they have not been able to do anything. It’s really starting to drive me nuts, I’m not sure if it’s a loose motor mount or something like that but it’s been checked out by a master technician and they cannot find anything.
    GoFast157 likes this.
  2. Feb 27, 2023 at 9:13 AM
    GoFast157
    GoFast157 New Member
    Yep, noticed since new all the way past 13k miles. Recently turned off the fake engine noise and no longer notice it. Maybe something to do with having the music and my preference of bass mixed with Toyotas engineered crap coming through the same speakers? Not sure
  3. Feb 27, 2023 at 1:19 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
  4. Feb 27, 2023 at 2:31 PM
    KroppDuster
    KroppDuster A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    You've gotta get in there and play around with the idle speed, adjust the fuel mix screw, and maybe even check the vacuum lines on the OEM 4-barrel carburetor in the 3rd Gen Tundras.
    /s
    KNABORES, Piki, TopTierToyo and 3 others like this.
  5. Feb 27, 2023 at 3:07 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Are you being serious? If yes a more detailed response please
    Black widow TRD likes this.
  6. Feb 27, 2023 at 3:26 PM
    nodak67
    nodak67 New Member
    JR
    some people never notice the /s
    pwpblue likes this.
  7. Feb 27, 2023 at 3:28 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I thought they used one 4 barrel for each turbo? Could it be a sticky float?
    I too would like to hear the detailed response...
  8. Feb 27, 2023 at 3:48 PM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Remember this engine has 2 fuel injection systems. In addition the fuel injectors are driving individually per cylinder mechanically, Atleast the direct injection fuel injectors. So they my be contributing to the additional noises or vibrations.
    my gen 3. Coyote Mustang does the same thang what has been aformentioned.
  9. Feb 27, 2023 at 4:11 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    The intermittent rough idle might be some other load coming on like the A/C pump or air pump (for emissions if they still use those).
    It might be dragging the idle down when it kicks in. I had that in my Honda. I could hear the pump clicking on so I knew what it was.
  10. Feb 27, 2023 at 4:12 PM
    KroppDuster
    Bilstein 5100s
    This issue is 100% from a sticky float ball in the carb. New ethanol fuel really gums up these modern carburetors. :rofl:
    MrKABC likes this.
  11. Feb 27, 2023 at 4:15 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I will switch to Chevron High Test 94 Octane and maybe some octane boost :)
    This might be going the way of the "blinker fluid" threads.
  12. Feb 27, 2023 at 4:19 PM
    KroppDuster
    Bilstein 5100s
    This. I would turn off would all of the HVAC off and see if you can start isolating systems that might be dragging down the idle. Mine does this occasionally in stop & go traffic, but I'm not worried by it. Most vehicles I've ever had did this.
  13. May 13, 2023 at 5:27 AM
    David713
    David713 New Member
    2023 Tundra Platinum
    King shocks, TRD UCAs, Hellwig rear bar, 295/60-20 tires on 20x9 Sparcos
    Any update on this? I vaguely remember a while back someone wrote it was the turbo wastegate not fully closing at idle and there was supposed to be a new ECU program coming.
    Mine will cycle from super smooth to rough to smooth to rough over and over a few seconds apart.
  14. May 13, 2023 at 5:49 AM
    CalTunda23
    Cal
    2023 Tundra Limited
    Ive been talking to Toyota corporate for a few months now and I've demanded a replacement vehicle. Dealing with them has been a disappointment to say the least. This truck is definitely a lemon. So many issues it's not even funny. Brake squeak like crazy, bad vibration at idle, plastic around the seat adjustment controls has completely snapped off. Loud clunk when starting the truck. All the common issues with the new tundras mine has. Looks like maybe a class action suit is the only way Toyota is going make things right. Either that or they need a serious recall.
  15. May 14, 2023 at 11:37 AM
    MrKABC
    MrKABC Not so new Member
    Art
    Corona, CA
    2023 Mesquite 1794 TRD OR Hybrid
    Miller Cat Shield, Sumo Springs Blue, Diode Dynamics Stage Series hidden light bar.
    Yep... this thread has officially jumped the shark. OP, you're not going to get a "replacement vehicle", full stop.
    Your options are: trade it, try to lemon law it, or live with it. I don't know if you live in CA (from your username) or not but here in CA the vehicle can be considered a lemon if it is disabled and there have been documented repair attempts exceeding a set time period where you don't have usage of your vehicle. The stuff you describe are chump change nuisances.
    Get the seat fixed, do what @KroppDuster recommended to isolate the shudder, and wash yer truck to get the brake dust off the wheels and be happy.
    (I love the "I DEMAND A NEW TRUCK NOTHING LESS ANDI WANT IT RIGHT NOW" threads...)
    digitalwiz, Mattedfred and xeuxaz like this.
  16. May 14, 2023 at 11:51 AM
    CalTunda23
    Cal
    2023 Tundra Limited
    I never said I expected a replacement vehicle, I said I demanded it. I know that isn't going to happen. It's called negotiating.
    And no I'm not going going on a fishing expedition to find a shudder on a brand new $60k vehicle. I expect a brand new Toyota to run fairly smooth. If Toyota can't twist the dealers arm and have them find the problem I'll dump the vehicle. Not going to be a mechanic on a brand new car. These aren't chump change nuisances either. It's a brand new vehicle with a bad shudder at idle.
    Washing the truck doesn't keep the brakes from squeaking...
    What are you a Toyota dealer or something?? You seem pretty defensive and upset, maybe you're just a serious Toyota fanboy.
  17. May 14, 2023 at 11:57 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
    I feel your pains, and the expectations. A new expensive truck shouldn't have such issues....
    However, many of our new tricks do have these issues, and while we're not exactly thrilled, we try to figure them out and get them fixed. Many of us have the issues that you mentioned, and there's not much you can do except work together with the dealer to try to fix it.
    To sum it all up, we have a brand new first/second year of a new design, so we're the Guinea pigs. (buy older model years next time if you don't like this)
  18. May 14, 2023 at 12:00 PM
    MrKABC
    Art
    Corona, CA
    Nope, just a guy that has been on the Tacoma forum since 2014 and now here. I get amused at these "Veruca Salt" threads where the disgruntled owner starts DEMANDING a new truck.
    Spoiler alert: it never happens.
    Carry on, soldier. I'm back to lurking to see how this will work out for you... but I have seen this movie many times before and know the ending. :cheers:
    digitalwiz, Mattedfred and korslite like this.
  19. May 15, 2023 at 2:20 AM
    TopTierToyo
    TopTierToyo New Member
    2022 Blueprint Tundra 4x4 Limited
    I don't mean to rain on your parade, but those issues aren't terrible. These trucks idle weird but that's a byproduct of a 2 injector types and things like AC turning on and off, that doesnt mean anything is wrong with it. There is a TSB to correct the clunk at startup. Fix your seat under warranty.
    Not sure on the brakes though... maybe you do need a whole new truck because of a squeak.
    Rcflyersd, digitalwiz, MrKABC and 2 others like this.
  20. May 16, 2023 at 6:42 AM
    Jasco1
    Jasco1 New Member
    23 SR5 Crewmax TRD OR Lunar Rock
    @this^^^^^. I took mine to an excellent dealer service department and they told me the same thing regarding the rough idle was a result of the a/c cycling on and off. I also had the clunk and they fixed that with a TSB.
  21. May 16, 2023 at 7:29 AM
    korslite
    korslite New Member
    Justin
    Bellingham, WA
    2022 SR5 TRD OR 6.5' Bed
    This is gold :rofl:
  22. Dec 6, 2023 at 11:25 AM
    BIGGilly444
    BIGGilly444 New Member
    23 Tundra TRD ORP
    3in TRD Lift, afe intakes, afe scorcher
    So did anyone actually find out if this is normal or is there a fix? Mine has been doing this since new as well. Annoying but would be less annoying if I new it's supposed to do it and not just toyota cutting corners on something.
