Rough Idle and Dummy Lights
Discussion in '2.5 Gen Tundras (2014-2021)' started by Klempenski, Feb 11, 2025.
  1. Feb 11, 2025 at 2:10 PM
    Klempenski
    Klempenski [OP] New Member
    Clinton
    2019 Gray Tundra TRD Sport CrewMax 4x4
    Working on it
    Howdy! I have a 2019 TRD Sport (SR5 essentially with sway bars) with the 5.7L regular gas engine and about 65k miles. She drove perfectly fine two days ago, but this afternoon on a cold start she was idling real rough, like I immediately noticed it. As soon as I put it in gear, dummy lights lit up. I have a check engine light blinking, and the info screen says the collision system is down and that the trailer braking isn’t functioning properly. She’s always had regular oil changes with the level and color looking good right now when I checked. No other fluids leaking that I can see. I’ve had a rodent problem before in the winters but thought I fixed that with some thick metal grating that I screwed on to that cabin air filter entry point. I’m out of warranty (no extended) so trying to fix on my own if I can. Any recommendations where to start?
  2. Feb 11, 2025 at 2:42 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    check your MAF connections and look in your Airbox...
    Klempenski[OP] likes this.
  3. Feb 11, 2025 at 3:20 PM
    Klempenski
    Clinton
    Working on it
    No oil or anything else of note in the airbox or MAF
  4. Feb 11, 2025 at 3:41 PM
    Klempenski
    Clinton
    Working on it
    Ordered an OBD-II scanner to pull the codes. I have a feeling it’s a misfiring cylinder from a bad plug or CP but we’ll see
    HulkSmurf14 likes this.
  5. Feb 12, 2025 at 8:31 AM
    Klempenski
    Clinton
    Working on it
    Cylinder 8 misfire. Time for a tune up
    OHwendTrd and HulkSmurf14 like this.
  6. Feb 12, 2025 at 8:35 AM
    HulkSmurf14
    2014 Tundra Limited
    New plugs and a new coil, you'll be back!
    OHwendTrd and Klempenski[OP] like this.
  7. Feb 13, 2025 at 12:51 PM
    Klempenski
    Clinton
    Working on it
    Well after changing the the plug and coil pack on cylinder 8 (passenger side closest to firewall), it’s still throwing the same code and idling rough. My next guess is wiring or at worst a blown head gasket. Mother trucker…..
    HulkSmurf14 and KNABORES like this.
  8. Feb 13, 2025 at 1:02 PM
    HulkSmurf14
    2014 Tundra Limited
    Check grounds from engine to firewall, et Al...I feel it's a wiring challenge...any worn wires under airbox, itself? MAF plug is snapped in with an audible "click?"
  9. Feb 13, 2025 at 1:08 PM
    Cold weather, sudden change overnight, previous rodent issue, my guess is some wiring damage from rodents again. Worst case scenario would be head gasket (unlikely, but easy to test) or broken valve spring on that cylinder.
  10. Feb 13, 2025 at 1:18 PM
    Klempenski
    Clinton
    Working on it
    Yeahhhhh as I got a better look and really inspected the area, there’s definitely more damage from these dumba$$ rats or whatever is getting in there. I can work on mechanical stuff, but I’m a complete idiot when it comes to electrical. Need to get a voltmeter to begin with.
  11. Feb 13, 2025 at 1:21 PM
    HulkSmurf14
    2014 Tundra Limited
    I share the same regard..."it's easy!" they say, but yeah, not my thing...I had to redo some chewed on ECM wiring and mak, those hair-like wires made my hand of thumbs super "functional!" I wish you luck...rough idle would make me think to check the MAF harness first...
  12. Feb 13, 2025 at 1:31 PM
    He has a code for cylinder #8 misfire. Probably not MAF related.
  13. Feb 15, 2025 at 10:49 AM
    Klempenski
    Clinton
    Working on it
    Update: checked the voltage to the CP and read a 13.7V drop in voltage so the wiring there was fine. I figured the next thing could be wiring to the injector, but with a toddler this guy ain’t got time to pull the fuel rails. Took it to a Caliber Auto who confirmed the wire to the injector was chewed through. They’re pulling the fuel rails and replacing the wiring and harness for that injector. They’re also spraying an anti rodent chemical in the engine bay. $532 OTD which is a steal if you ask me. Hopefully that’s the only wire and the spray works
  14. Feb 15, 2025 at 11:58 AM
    HulkSmurf14
    2014 Tundra Limited
    Daaaang! That's a great deal and bravo!! Time to make sure your friendly mice stay tFO, now! :bananadance:
