Rough country lift
Discussion in 'Suspension' started by Slin2018, Dec 30, 2018.
  1. Dec 30, 2018 at 10:50 PM
    Slin2018
    Slin2018 [OP] New Member
    Shawn
    2017 SR5 CM
    6 inch lift, 20 in fuel cleavers wrapped in 20x12.5 nitto g2
    This might sound like a dumb question..
    I have a 17 cm with a 6 in lift bought it like that, now if I wanted to drop 2 in and do a 4 in lift, is that even feasible??
  2. Dec 30, 2018 at 11:09 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    @papasmurf switchef from a BDS bracket lift to LT, he may be able to provide some good insight here.
  3. Dec 30, 2018 at 11:50 PM
    Slin2018
    Shawn
    2017 SR5 CM
  4. Dec 31, 2018 at 1:22 AM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    I think the only way would be is find a 4" lift that us the same as your 6" because of the frame being cut for most 6" lifts.
  5. Jan 2, 2019 at 6:48 PM
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    Sorry OP been out of town, whats going on, what questions do you have, what lift is currently on your truck? Wat would you like to go to? And if its a drop bracket that cut out the factory cross member, it abso.uetly can be replaced even stronger.
    Let me know what you need info wise
    zcarpenter92 likes this.
  6. Jan 5, 2019 at 8:23 AM
    Slin2018
    Shawn
    2017 SR5 CM
    Right now I have a rough counrty 6 in lift that came on the truck when I bought it... now can I add new coilovers, or go down to a 4 inch lift?
  7. Jan 23, 2019 at 3:14 PM
    DM 2018 Tundra
    DM 2018 Tundra New Member
    South Carolina
    2018 Limted Tundra
    6inch RC with upgrade struts. 295/65/20 Nitto Ridge grappers 20x9 fuel vapor with 0 off set
    If you have a RC kit and want to go down to 4 and want new coil overs... I don’t think so. I went with a 6 inch RC cause I couldn’t find a 4 inch for the front and went with upgraded shocks. I could be wrong
  8. Jan 23, 2019 at 3:17 PM
    I have a rough country 6 inch lift kit, I have an older version of the kit on my rear cross member is not cut, so technically I can get rid of this kit, if your rear crossmember is cut what you can do is go to the 4.5 inch kit and they just sell you the rear blocks and the front spacers
  9. Jan 23, 2019 at 3:42 PM
    1BadTundra
    1BadTundra New Member
    Clinton
    2010 TRD Rock Warrior Crewmax
    Too Much to List
    You can get rid of the preload spacer in the coil and that drops it to a 4"... Or you can get coilovers, set them to 2" and keep the 6".... If that isn't it, i don't understand the question.
    jeremyd likes this.
  10. Jan 23, 2019 at 4:45 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Yep, remove preload spacer.
  11. Jan 23, 2019 at 5:20 PM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    So if you have a 6 RC you can take the spacers out and it will be a 4?
  12. Jan 23, 2019 at 5:31 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    Yes, provided you do indeed have a preload spacer.
