Rough Country Front Struts
Discussion in 'Suspension' started by VSB, Sep 20, 2020.
  1. Sep 20, 2020 at 6:42 AM
    VSB
    VSB [OP] New Member
    Dino
    2008 Dual Cab with Supercharger
    Hey Gang. Putting in the 3.5” RC Lift in my 08 Tundra Double Cab. Want to replace front struts at the same time. Stupid question but would you recommend using the RC Front Struts? They mention that they don’t work with strut spacers but the lift kit comes with strut spacers. Is this as simple as just not using the spacers? Sorry this is all above my pay grade.
  2. Sep 23, 2020 at 7:16 AM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    I think that kit is either the struts or the spacers, you will pick one or the other. I've heard those new struts are pretty nice.
  3. Sep 23, 2020 at 8:03 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Can you post a picture of the RC front struts that you are referring to?
    No, it's not that simple because the length will be different..
    toyofan87 likes this.
  4. Sep 23, 2020 at 2:16 PM
    VSB
    VSB [OP] New Member
    Dino
    Here is the lift kit and also the front struts I’m looking at
  5. Sep 23, 2020 at 2:38 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    IMG_4129.jpg IMG_4129.jpg ok, yes you can use just the RC front struts. Although I believe the RC front struts are 3 inches..The kit is advertising 3.5..But you will be fine. And yes I recommend using the RC coilover without the spacer. There is a difference in the ride comfort. Hope that helps.
    Here is the 6 inch version that I used to replace the spacers. It works like a champ.
    k0diak8o8 likes this.
  6. Sep 23, 2020 at 2:54 PM
    VSB
    VSB [OP] New Member
    Dino
    Awesome! Thx!!
  7. Sep 24, 2020 at 4:31 AM
    parker44
    parker44 New Member
    I believe when you pick that kit, you select the front option you want. Just wanted to make sure you don’t order too much.
    VSB[OP] likes this.
  8. Sep 24, 2020 at 5:06 AM
    VSB
    VSB [OP] New Member
    Dino
    Yeah I wish I had planned to replace the front struts when I ordered the lift. I would’ve saved around $20 order the new fronts as part of the kit.
  9. Oct 22, 2020 at 2:31 PM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Any updates OP?
  10. Oct 24, 2020 at 3:58 AM
    VSB
    VSB [OP] New Member
    Dino
    Not yet. Working on a few other expenses that unfortunately had to take priority! Will update as soon as I’m caught up. Thx for checking in.
  11. Oct 24, 2020 at 7:11 AM
    1BadTundra
    1BadTundra New Member
    Clinton
    2010 TRD Rock Warrior Crewmax
    Too Much to List
    I have these on my lift... We've been selling, installing and running them on our trucks since they've been released. Haven't had one complaint yet.
  12. Oct 24, 2020 at 8:46 AM
    VSB
    VSB [OP] New Member
    Dino
    Look great!!
    1BadTundra likes this.
  13. Oct 27, 2020 at 6:09 AM
    TNTundra53
    TNTundra53 New Member
    Question for those running these coilovers. I know its not recommended to use the spacers in conjunction with these. My question is could you run a 3.5" maxtrac or QSA spindle to achieve 6 inches of lift with these coilovers? I have a 2WD and do not want to pay half my life to buy one of the 1500 dollar kits that has parts I do not need to put on my truck. So looking and trying to think of alternatives to go higher on a budget.
  14. Oct 28, 2020 at 1:05 PM
    InBigTrouble
    InBigTrouble New Member
    2015 Black Tundra
    6 inch rough country lift kit, procomp traction bars, N3 full coils front, N3 rear, airlift aibags, Coachbuilder driveline spacer, Coachbuilder carrier bearing drop, 20" Rockstar II XD, 35 12.50 R20 Nitto Ridge Grappler, Go Rhino Dominator step bars, Bakflip Tonneau cover. AJT vent rings&shifter trim.
    just get the ones made for 6"s I have the 6" ones, like them a lot. rides good. no spacers
  15. Oct 28, 2020 at 1:35 PM
    preacher35
    preacher35 RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    NO. These Rough Country coilovers are NOT designed to provide lift of any sort. They are merely designed to replace OEM coilover/lift spacer assemblies on 6" lift kits. The spacers that come with 6" spindle/block lift kits are only there to fill the gap above the OEM coilover after the kit is installed. It's the 6" lift kit spindles that provide the lift in the front of the vehicle, NOT the coilovers and gap spacers. That being said, the Rough Country 6" coilovers do give a MUCH better ride, then an OEM coilover/spacer assembly. I have them installed on my rig with the PRO COMP 6" lift.
  16. Oct 29, 2020 at 10:27 AM
    TNTundra53
    The RC 6" coilovers are not designed for 2WD application so those are not usable, that's why i was asking if you could use the 35" coilovers and a 3.5' spindle to make a 6' kit.
  17. Oct 30, 2020 at 6:11 AM
    CowboyTaco
    CowboyTaco New Member
    Michael
    2011 Tacoma DCSB
    Interesting. I'm used to the Tundra little brother. I clearly have a lot to learn about lifting full sized trucks. I would have thought that the struts would be included in the kit. Regardless, getting a strut/coil combo that is designed for that lift is going to be much better than a standard shock with a spacer.
  18. Nov 1, 2020 at 4:30 PM
    VSB
    VSB [OP] New Member
    Dino
    FINALLY getting everything installed later this week. Will update after it’s done
    toyofan87[QUOTED] likes this.
  19. Nov 2, 2020 at 1:49 AM
    preacher35
    I cannot, for any reason, understand why they cannot be used on a 2WD with a 6" spindle/block lift. Could you explain?
  20. Nov 2, 2020 at 4:06 AM
    CowboyTaco
    Michael
    2011 Tacoma DCSB
    Yeah....no front axles or diff angles to contend with. Less stuff in the way and/or to consider. Seems anything for a 4x4 should work on a 2wd...
  21. Nov 2, 2020 at 8:21 AM
    TNTundra53
    Just stating what RC has told me.
  22. Nov 2, 2020 at 8:37 AM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax
    The 6" strut only works with a 6" bracket lift.
    A 2wd spindle works by moving the mounting point for the 2wd wheel hub farther down on the spindle to achieve the lift. The suspension itself is unchanged from factory.
    For the 2wd, either get a 6" bracket lift or a 3" spindle and 3" spacer/shock.
  23. Nov 5, 2020 at 6:16 AM
    toyofan87
    Seth
    Gettysburg, Penna
    Can't wait to see Op. Congrats
  24. Nov 6, 2020 at 3:26 PM
    VSB
    VSB [OP] New Member
    Dino
    Finally got the lift and struts put in with the BMC. New Wheels tires and Nerf Bars. When I pulled up and saw the truck I didn’t even recognize it. It felt like Christmas morning. Snapped a couple photos before I had to leave. Got home after the sun was down so I couldn’t snap any more yet
    Boerseun, Ted4311, parker44 and 2 others like this.
  25. Nov 6, 2020 at 3:27 PM
    VSB
    VSB [OP] New Member
    Dino
  26. Nov 6, 2020 at 3:31 PM
  27. Nov 7, 2020 at 3:16 AM
    toyofan87
    Seth
    Gettysburg, Penna
    Looking good...IS this the said Rough Country 3.5 COILOVER lifted complete kit as seen from OP first post?? Congrats
  28. Nov 7, 2020 at 3:49 AM
    VSB
    VSB [OP] New Member
    Dino
    This is. Finally.
  29. Nov 7, 2020 at 4:12 AM
    Mrs is fixing to buy the new RC 6" coilovers and get rid of the spacers up front
  30. Nov 7, 2020 at 9:04 AM
    CowboyTaco
    Michael
    2011 Tacoma DCSB
    Looks great, @VSB !
    VSB[OP] and toyofan87 like this.
