Rough Country Front Level Kit
Discussion in 'Suspension' started by taschmidt86, Dec 27, 2024.
  1. Dec 27, 2024 at 12:12 PM
    taschmidt86
    taschmidt86 [OP] New Member
    2022 Tundra 1794 W/ TRD Package
    None
    So at 35k I installed the truck level pucks and have been riding pretty nice until last week. I started to hear a creaking sound while turning at slow speeds and while stopped. I had these install by a Toyota dealer and they had done other like it before. Now I cant imagine that the ball joints or the bearings have worn out after 5k. That’s absurd.
    I do make a habit of taking the truck through the car wash once a week but surely it hasn’t degraded the grease in the joints that bad?
    Anyone else have similar experience?
  2. Dec 27, 2024 at 12:23 PM
    Timmy23
    Timmy23 New Member
    OR
    25 1794 MGM Tundra
    None
    My Readylift SST upper control arms have a grease nipple at the ball joint. Needs grease every 5000 miles or they will creak. Don’t know if that was replaced on yours. Factory are sealed.
  3. Dec 27, 2024 at 12:49 PM
    Nates91xj
    Nates91xj New Member
    Could be a bushing or maybe something is binding up when turning. Stock UCAs? Did they do an alignment after install?
  4. Dec 27, 2024 at 12:51 PM
    taschmidt86
    None
    yep did a double alignment. One on the first day and 5 days later after suspension settled in.
  5. Dec 27, 2024 at 2:11 PM
    Nates91xj
    Not exactly apples to apples but I had something similar happen on my 5th gen 4runner after lifting it and things settled. I had to loosen up some of the stuff in the front end due to control arm bushings binding. Tightened it all back to spec and was fine. Could also be a spring seat?
  6. Dec 27, 2024 at 3:40 PM
    KuehnMK
    KuehnMK New Member
    2023 Tundra Crewmax 4X4 Platinum
    Alot of puck level kits specifically state that all hardware needs to be retorqued every 5K miles...maybe something is loose?!
    taschmidt86[OP] likes this.
