Rough 4wd disengage
Discussion in '1st Gen Tundras (2000-2006)' started by Foodiescholz, Jun 24, 2018.
  1. Jun 24, 2018 at 7:16 PM
    Foodiescholz
    Foodiescholz [OP] New Member
    Mark
    06 tundra dbl cab
    I recently got into an accent were I slid off the road during a rainstorm. Before the accident my 4wd engaged and disengage perfectly smooth. After repair, I've noticed that while engaging smoothly, when I go to disengage it, there is a noticeable thump or jolt. Since this is my first truck and experience with 4wd I'm looking for thoughts on what happened/broke and any solutions you might have. Thanks in advance!
  2. Jun 24, 2018 at 8:29 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Did any tire(s) get damaged and replaced? Even a small mismatch in tread depth or even tire pressure differences can cause this.
    How major was the damage? No diffs replaced with a different gear ratio I assume?
  3. Jun 25, 2018 at 8:29 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    disengage it on a loose surface, and see if it does the same thing.
  4. Jun 25, 2018 at 8:43 AM
    Pale_Horse
    Pale_Horse Sooooooooo White.
    FL
    White 2013 TRD OR 4x4 DC
    Cupcake chit.
    Mine does that on pavement(accidentally bumped it into 4hi)... stuff starts to bind.
  5. Jun 26, 2018 at 5:00 PM
    Need to know stuff
    Need to know stuff New Member
    2000 black Tundra TRD
    3 front 2 rear leveling
    I was in 4hi and had cruise control on when I turned it off. Now it does the same thing.
  6. Jun 26, 2018 at 5:04 PM
    Rex Kramer
    Georgia
    Find a gravel road and turn it on & off as you drive at a steady speed. I don't know how the cruise changes things, but I would keep it off during this exercise.
