Rotten '05 Tundra diffrential/axle housing...
Discussion in '1st Gen Tundras (2000-2006)' started by devino, Oct 30, 2023.
  1. Oct 30, 2023 at 8:00 AM
    devino
    devino [OP] New Member
    05 TRD rew
    frame replacement
    I have an '05 TRD Crew Cab with the typical Northeaster differential housing rot and failuere. Anyone know where I can buy a new housing, or housing/axle assembly from a "no road salt" state? Thanks!
  2. Oct 30, 2023 at 8:07 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    They sell an aftermarket diff cover that you could weld over the existing one if you have any leaks.
  3. Oct 30, 2023 at 8:08 AM
    shifty` Animals and insects don't do drugs
    Double cab? You left off the most important part. Is it 2WD or 4WD? If 4WD you'll need to determine gear ratio on your truck and pick up same, which may be a challenge. You also can't use any cab except double cab donor, since regular and access cab axles are different width from double.
  4. Oct 30, 2023 at 8:09 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    2001 4x4 4.7L “Best Cab”/AC Limited 51k mi
    Search junkyards that have their parts indexed at Car-part.com. You will almost certainly be able to find a whole third member and just slap that on, much easier than trying to bolt/welt/attach good metal onto shite metal.
    devino[OP] likes this.
  5. Oct 30, 2023 at 8:14 AM
    Third member won’t solve his rusted out axle housing issue. He needs an entire axle housing.
    bfunke and devino[OP] like this.
  6. Oct 30, 2023 at 8:16 AM
    devino
    05 TRD rew
    frame replacement
    The problem, which is universal for all Tundra/Sequoias of that vintage, is that the diff housing is all part of the axle assembly, and it's the bottom of the housing, not the cover, that shites the bed. Good point Shifty, thanks, and also Jason C for the parts finder tip. What I learned through it all - the worst parts on US Mfr. Tundras are made HERE - the frame and rear axle housoing made by DANA. The Tundras/Sequoias/ (even Tacos) built in Japan with Japanese parts - not so much. So much for made in America...
  7. Oct 30, 2023 at 8:19 AM
    If it was just the cover rusted out, others have been able to cut off and replace it with a Dorman part. Can link you up with more info.
    But yeah, 4WD or 2WD you'll need to know, to figure out gear ratio. car-part is a great resource to search remotely. But honestly, hunting for parts trucks on Facebook Marketplace and Craigslist from the Carolinas and Tennessee southward for "parts tundra" can be pretty effective too.
    Seqoia axle, while it'll fit width-wise, you're up against challenge b/c drums vs. rotors, and I swear the shock mounts or some other welded mount is diff't.
  8. Oct 30, 2023 at 8:21 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    Today I learned something about nomenclature! I thought "third member" was the whole rear axle/differential assembly, but general consensus seems to be it's just the differential.
  9. Oct 30, 2023 at 8:37 AM
    Jack McCarthy
    Bill
    North of Boston
    Damn, it’s gotta be pretty rotted for the bottom of the front of the housing to be rotted through (if I’m understanding you correctly). I’ve escaped that scenario using POR-15 as a protectant.
  10. Oct 30, 2023 at 9:06 AM
  11. Oct 30, 2023 at 10:41 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Can't comment without a picture...
    Jack McCarthy likes this.
  12. Oct 30, 2023 at 5:22 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Tundras are made in the US and only sold in North and South America. They are not available in Japan. Toyota plans to sell them in Oz. I lived in Japan during First Gen times and never ever saw a single Tundra. I drove a Hilux and a Surf
  13. Oct 30, 2023 at 5:54 PM
    Jack McCarthy
    Bill
    North of Boston
    The 2uz-fe engines were made in Japan up until 2003 when the Alabama plant took over.
    Everything else, made in USA.
  14. Nov 12, 2023 at 6:46 AM
    Richid
    Richid New Member
    There someone in northern NH / western ME that sell refurbed housings on CL/FB. That might be the cheapest way. I bought a used one and had to clean it up myself.
    Good luck!
