Rotors and Pads needed
Discussion in 'Sequoia 2nd Gen (2008-2022)' started by allrelative, Feb 27, 2024.
  1. Feb 27, 2024 at 9:49 AM
    allrelative
    allrelative [OP] New Member
    Kevin
    The last set of brakes and pads I had on my 2013 Sequoia had no stopping power. No one in the house would drive my Sequoia but me because they felt unsafe. You had to push the pedal to the floor to stop it. The rotors and pads only lasted 20,000 miles in the front, the backs are fine. If the rear rotors and pads are fine and the fronts are 95% worn and the truck is hard to stop are there other issues I should be looking at?
    I need to replace the front runners and pads I guess (per the shop), I told them no for now because I wanna do some research and get better pads and rotors.
    Any suggestions?
    Thanks for any and all help.
  2. Feb 27, 2024 at 9:52 AM
    Jckdanls07
    Jckdanls07 We May Not Know Them All, BUT, We Owe Them All !!
    Keith
    Tampa Area
    2015 White Tundra SR5
    Yes... Replace calipers as well.... And if it has rubber hoses from caliper to main line, replace as well....
  3. Feb 27, 2024 at 9:55 AM
    allrelative
    Kevin
    I replaced the calipers last time and the shop says they are fine on all four.
    Any brands of rotors / pads I should focus on?
  4. Feb 27, 2024 at 10:06 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    The OE Toyota rotors are usually ok.
    Try one of the Bosch QuietCast pads from Rockauto. They have ceramic, semi-metallic, and severe duty. Another is one of the better Dynamic Friction pads. The fellow that founded Centric started DFC, and their pads seem to be pretty good. They make truck/HD pad that has good bite and stopping power.
    Centric once made good pads, but they have been going downhill since being acquired by Raybestos.
    NCSCOTT likes this.
  5. Feb 27, 2024 at 10:18 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Centric or another good brand of cryo treated rotors (Cryo rotors last better on our heavy trucks) and akebono pads are very good quality, last and perform well and dont break the bank.
    Kwe1982 and NCSCOTT like this.
  6. Feb 27, 2024 at 12:28 PM
    allrelative
    Kevin
    Thank you for the info and links > looking at those now. The shop quoted me $412 for the Rotor / Kit SG-X - OE Ceramic +$220 Labor for the fronts. As I mentioned, the last set did not last 20K, no towing, no aggressive driving.
  7. Mar 9, 2024 at 5:43 AM
    NCSCOTT
    NCSCOTT New Member
    Scott
    Charleston, SC
    Silver 2008 Sequoia 5.7L 2WD Towing Package, JBL on 35x12.5s
    2.5"/2.0" Lift Front Bilstein 5100s/Rear Coil Spacers w/Bilstein 5100s, 35" x 12.5 Nitto Terra Grappler G2, Hypertech Speedo Calibrator, XD 778 Monster 20" x 9" +35 offset, Go Rhino Matte Black Bullbar, Power stop Drilled/slotted rotors all 4 corners. Airlift 1000 Airbags. LED lo/hi Beams and Fogs replacement housings. Headlight Washers removed.
    Lets talk about the bigger problem "You had to push the pedal to the floor to stop it." That is your root issue.
    Had our 08 since 2011... 195K miles now, Never have we ever had to push the peddle to the floor to stop it. There is another issue at work here that needs to be addressed. It sounds like there is air or moisture in the system or you have a brake master cylinder issue. If air is in the antilock brake module it must be bled using a techstream device, to my knowledge. Full brake fluid flush is needed and full inspection of the brake system. And Like others stated upgraded stainless brake lines at each wheel will help a bit.
    If the peddle to the floor issue is not addressed and you put fresh rotors and pads on it you likely will just be pushing the peddle to the floor still.
    The brake Peddle should never go to the floor in normal daily driving.... never.
    If you have no lift or bigger tires, IMHO you can not go wrong with OEM Toyota Rotors. They are very well made. Centric makes very good rotors as well.
    With that said I use Powerstop Z36 Truck & Tow rotors and pads, front and rear, since I am on 35" tires and tow a boat regularly. 5 years now with them. My pads last 50-70K miles front and even long rear. My OEM pads lasted that long as well.
    I have done all my own brake work for over 30 years. Owned nothing but Toyota since 2004. You have a bigger issue that needs to be addressed for your safety please get another shop to look at the problem. Your calipers could be fine, but something else in the system has a problem.
    Best of luck to you.
    jamess28 likes this.
  8. Mar 9, 2024 at 6:24 AM
    CMikeB
    CMikeB New Member
    My brake pedal on my 2010 hasn't dropped in 88,000 miles. Mechanic says I should see 100,000 miles from my OEM brakes. If Toyota hasn't 'beancounted' away the quality, I'll by them next time too!
  9. Mar 9, 2024 at 12:00 PM
    allrelative
    Kevin
    Thanks NCSCOTT
    I ended up going with the same, Powerstop Z36 Truck & Tow rotors and pads
    I don't know what my mechanic used for the fronts but I didn't get 20,000 miles out of the pads. The pads on the front were 95% gone. Since adding the Powerstop Z36 Truck & Tow rotors and pads on the front the truck feels much better, what I expect.
    I still have a lot of pad left on the rears so did not did not swap them out yet. However, I did purchase the rotors and pads for the rear as well. So I'll swap them out when I need to.
    I've done brakes on boat trailers but not on cars. I have to say it was pretty smooth I'm pretty easy. What do I do with the old rotors? They look fine, but I'm not a mechanic.
    Thanks for all the help!
  10. Jan 1, 2025 at 11:58 AM
    allrelative
    Kevin
    So far so good! I added these to my son's 2010 Tacoma also.
