Rotor upgrade help.warped for no reason
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Throwwire, Jan 28, 2019.
  1. Jan 28, 2019 at 10:06 PM
    Throwwire
    Throwwire [OP] New Member
    Gerry
    Humboldt county
    08 ext cab,16 platinum crew
    08 leveled 35s fab four bumpers light bars 16 leveled
    My 2016 rotors are warped and all this truck sees is freeway use, I'm pretty annoyed as my 2nd gen has seen 170k miles and I use it hard and is fine. Looking to upgrade any suggestions would be greatly appreciated
  2. Jan 28, 2019 at 10:43 PM
    Throwwire
    Gerry
    Humboldt county
    Actually ended up ordering these
  3. Jan 28, 2019 at 10:44 PM
    Throwwire
    Gerry
    Humboldt county
  4. Jan 29, 2019 at 12:29 AM
    Wonder if you have a stuck caliper?
  5. Jan 29, 2019 at 3:55 AM
    Dabutcher
    Dabutcher New Member
    D
    Twin Cities
    2022 Tundra 1794 Supersonic Red
    Nitto Ridgegrapplers 175/60/20
    What he said?^^^^^^^^^^^^. My oem rotors lasted 97k before replacement. That’s why I replaced them with oem. Good luck. D
    Mountun Goat likes this.
  6. Jan 29, 2019 at 4:21 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    I only use the oem rotors. I abuse the crap out of them and I've never had a warped rotor. I like em because they are cheap and durable/reliable
    DalTee likes this.
  7. Jan 29, 2019 at 4:36 AM
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    I had warranty work done on my 2011 because of a caliper issue. Is it squeaking?
  8. Jan 29, 2019 at 4:37 AM
    DalTee
    DalTee New Member
    Dal
    Have you used them for long?
    Bajis likes this.
  9. Jan 29, 2019 at 4:39 AM
    2015Crewmax
    2015Crewmax New Member
    Cory
    Centennial, CO
    15 Crewmax
    BOSS 4x4 3" Lift kit, TRD Swaybars, TRD dual exhaust,
    I have 70K on my 15 CM and i have warped front rotors as well. wondered if the brakes aren't up to par trying to stop such a beast? HAHAHA
  10. Jan 29, 2019 at 4:46 AM
    MOTORHEAD
    MOTORHEAD New Member
    DAVID
    LOS ANGELES CA
    2002 Toyota Tundra SR5 V-8 4.7L WHITE
    RCD 6" SUSPENSION LIFT,ICON EXTENDED FRONT COILOVERS,3" BODY LIFT,CAMBURG UPPER CONTROL ARMS.REAR DISK BRAKE CONVERSION,BIG BRAKE FRONT CONVERSION, AND MANY MORE
    Check out disk bake Australia brand. I have them they are great
  11. Jan 29, 2019 at 4:51 AM
    Mnorris1206
    08 tundra
    Next week going back with oem I also have a 2nd gen 08 they have lasted 80k miles with pulling a camper a lot .I have kinda been told not to use slotted but idk why others have said that .
  12. Jan 29, 2019 at 4:56 AM
    Boudin
    Boudin New Member
    Louisiana
    Tundra#4
    Good deal, ordered the last set at that price, Thanks
    Throwwire[QUOTED][OP] likes this.
  13. Jan 29, 2019 at 5:01 AM
    ARES35
    ARES35 New member for life
    Mile high
    Blown 2650 17 1794 Tundra 4x4 CM
    2650/750cc/76mm/SPD DP-DD exhaust/HP tuned
    I’m at 18k and have a growling front driver side. Checked the pads, wheel hub/bearings, and calipers all looked good.....believe the rotor is warped. Mine might be from washing the truck after a long drive though
  14. Jan 29, 2019 at 5:15 AM
    conlons26
    conlons26 High speed dirt mobile
    Raleighwood, NC
    2018 Quiksand Limited CM
    King 2.5's, Toytec shackles, FN BFD 18", 295/70r18 NItto Ridge Grapplers, Dirty Deeds 8" SS, no more chrome, 17' pro grill, Husky mats, TRD Pro shifter + 15hp...
    I had 18k mi on my 2010 DC and they started pulsing. Took it in for one of my "free" oil changes and asked them to check. They had the nerve to leave me a vm and say "rotors are warped but we have it on the lift now and can have them turned for $298" I called them back and asked the service rep if he had lost his mind. I was told it was a wearable part and the larger trucks routinely needed this done. I told him I was amazed at how stupid and ignorant he thought I was. They ended up doing it for free. 40k same thing, maybe I drive like an ass... bought a set of power stops slotted and ported for under $200 with pads and they lasted for 130k and continue to bash that dealer to this day.
    Throwwire[OP] and Mnorris1206 like this.
  15. Jul 13, 2019 at 3:11 PM
    RDRunner
    RDRunner New Member
    2016 SR5 Crewmax 4x4 TSS Edition
    This is a common problem with 2nd and 3rd generation Tundras. Google it and you will find lots of people complaining about it. I have a 2106 CM that I bought new, and around 35k my front brakes started a pretty bad shimmy when I applied the brakes. The weird thing is that it comes and goes and sometimes it is worse than other times. That does not logically sound like a warped rotor to me (If it is warped it should consistently do the same thing.). I almost think it is pad buildup on the rotor of some kind. I am easy on my brakes and don't tow, so it is not me. My last Camry had 100k on the front brakes when I sold it and I bought it new and put those miles on it. I have owned lots of vehicles and this has never happened before. However, I am reading that it is happening to more and more different brands of cars, so it is something the manufacturers are doing.
    15whtrd likes this.
  16. Jul 13, 2019 at 3:13 PM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Buy some new rotors and move on with your life. They're $65 each and takes 20 min to install
  17. Jul 13, 2019 at 4:48 PM
    RDRunner
    RDRunner New Member
    That is what I am going to do, and normally I would prefer to use Toyota brand parts, but I think there is a design flaw in their pads or rotors, so I am going aftermarket (normal rotors and pads--not high performance).
    Rica25 likes this.
  18. Jul 13, 2019 at 5:42 PM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    There’s a lot of issues that many will not have the same experience with, I have a 2014 stock brakes and rotors with 73,731 miles. Still good, maybe by 90k it’ll need replacing but we’ll see.
  19. Jul 13, 2019 at 5:52 PM
    15whtrd
    15whtrd Mr. Blonde
    I think I would try the bed in process that you do with new pads. I don’t think it’s necessarily a warped rotor but pad material buildup in certain spots causing it to feel warped. I have thought my truck do this after going off road. Then it went away. What you want is an even amount of pad material left on the rotor. Go do a few heat cycles as you would with new pads.
    Kn4x2 likes this.
  20. Jul 13, 2019 at 6:06 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    My 2017 four wheel drive has 51,600 miles and all is good. I bought it new.
    My 1997 T100 four wheel drive has 265,000 miles on it and still carries the original (I bought it new off the lot) front rotors (back are drum) and all is good. I'm on my 3rd set of pads.
  21. Jul 14, 2019 at 12:26 PM
    RDRunner
    RDRunner New Member
    Good replies to my post. Yes, some of these problems only happen to some folks and others do not have the same problems. I also think it may be brake pad build up on the rotors. I am not the kind of guy who nitpicks every little thing or bad mouths Toyota. I am a Toyota guy and buy only Toyotas and have bought lots of new Toyota cars and SUVs and this truck over several decades--not a Toyota basher.
    Rica25 likes this.
  22. Aug 5, 2019 at 1:26 PM
    Potts228
    Potts228 New Member
    2017 Tundra TRD Pro
    I have a 2017 TRD Pro with 20K and my front rotors are warped and the dealer says my pads need replacing. I just visited a friend with a 2019 SR5 with 30K and he has already had to replace his brakes up front (same issue, warped rotors causing a pulsating pedal. His brother also has a 2019 and has a pulsating pedal at 17K. No doubt Toyota has a problem. Now I need to decide which aftermarket rotors and pads I will buy.
    Rica25 and Throwwire[OP] like this.
  23. Aug 5, 2019 at 3:58 PM
    RDRunner
    RDRunner New Member
    I am probably going to do my front brakes (rotors and pads) when I put a slight leveling coil (6112) on the front. At least that is what I am thinking. I am going to do a lot of research and hopefully get something better than Toyota pads, if that is what is causing it. I will put a dial gauge on it too to find out if it is really warped or not before I pull it off. I have around 47k miles on my truck.
  24. Aug 5, 2019 at 11:46 PM
    Throwwire
    Gerry
    Humboldt county
    The ebc kit I put on is working amazing, probably 10k miles on them so far
    ColoradoTJ and Rica25 like this.
  25. Aug 6, 2019 at 6:49 AM
    KB Voodoo
    KB Voodoo New Member
    Chad
    2017 Tundra Pro Crewmax, Cement
    Many KB Voodoo Fabrications accessories!!
    Mine started shaking the wheel braking down steep inclines at about 10K. It's like holding onto a paint shaker.
    I always blamed it on my notoriously hard braking (I like to party).
    Tundratoofun, BashFab and Rica25 like this.
  26. Aug 6, 2019 at 10:51 PM
    Throwwire
    Gerry
    Humboldt county
    Lol I party hard too, my 08 has 177k stock rotors, smooth, my 16 was garbage after 10k miles
    Rica25 likes this.
  27. Aug 7, 2019 at 4:50 AM
    Just an FYI, brake rotors do not warp but wear unevenly.
    The rotor is a machined surface. When using the brakes, the pads come in contact with the rotor in different places, and wear this machined surface unevenly.
    Another place to look is improper lug nut torque and torque sequence.
    If you have the tools (buy them at HF for 25.00), check run out, and this should be around .002.
    Rica25, Omohundro and jeremyd like this.
  28. Aug 7, 2019 at 4:56 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    @ColoradoTJ , 002 reminds me of my Military days down in the engineroom working as a MM, Anything over that number got dumped..
    AKJ78 and ColoradoTJ like this.
  29. Aug 7, 2019 at 7:53 AM
    RDRunner
    RDRunner New Member
    I think most people consider an "uneven" surface to be loosely referred to as "warped". The bottom line is that the surface has "run out" which as a practical matter is the same as if the entire rotor was "warped" with the same type of "run out". In short, technically you are correct that the entire rotors don't usually warp (but they can) and it is usually just the surface that has run out, but everybody uses the term "warped" (even dealerships and brake shops) to mean the surface of the rotor is no longer running true (it has high and low places). In other words, it is really just a semantics difference.
    Throwwire[OP] and osidepunker like this.
  30. Aug 7, 2019 at 8:41 AM
    I would politely disagree. Instead of listening to a goofball like me, take it from the experts.
    https://www.onallcylinders.com/2017/05/19/6-biggest-brake-rotor-myths-debunked/
    https://www.frozenrotors.com/tech-tips/view/warped-brake-rotors--are-you-sure-/
    https://www.powerstop.com/what-causes-brake-pedal-pulse-vibrate/
