Rotor resurfacing by dealership at 24K?
Discussion in 'General Tundra Discussion' started by scpete24, Apr 6, 2018.
  1. Apr 6, 2018 at 12:01 PM
    scpete24
    scpete24 [OP] Duuuuuuude
    Orange County, CA
    2016 TRD Pro Super White
    Couple weeks back I was coming down Big Bear mountain here in CA and every time I would hit the brakes I would get a bad steering wheel shake. I'm talking shake the entire truck bad. Let off brake and I would cruise without issue. I figured the issue was the brakes, but I had an alignment and re-balanced my tires to see if that would help, it didn't. Around town it was noticeable but not bad enough to not drive.
    Today, went into the dealership to have them look at it under warranty. Service manager said Toyota is aware that the brakes designed for the Tundra are undersized and he could do a 1-time good will resurfacing and replace the brake pads for free. I asked that they check the caliper pistons for lubrication as well.
    Has anyone else heard of this or experienced warping issues under 25K? Seems strange that I would need this done this early. I had my Tacoma for 45K and never had any issues and I don't consider myself hard on brakes.
    Any comment or advice welcomed. My truck is still there so if there's something in particular I should be asking for please let me know!
    Thank you
  2. Apr 6, 2018 at 12:04 PM
    Not sure if I agree much with the undersized brakes. Warping is common with the crappy OEM rotors though. Get some decent Power Stop rotors or equivalent IMHO.
    Adam, ColoradoTJ and mudslinger79 like this.
  3. Apr 6, 2018 at 12:07 PM
    mudslinger79
    mudslinger79 New Member
    Christopher
    Williamsburg, Va
    2006 Double Cab, Phantom Grey Pearl
    Leveled. 16x8 Pacer 164 wrapped in 295-75-16 General AT2. Flowmaster exhaust. K&N Cold air intake.
    I had an Avalon sent to use by a dealer exchange. Well, when they do that we have to do the pre delivery inspection again. On my test drive I noticed a bad vibration when braking. Car had 200 miles on it. We ended up resurfacing all 4 rotors and replacing the pads. 200 miles. Only time I've had that happen. I have seen our trucks burn through pads quickly. Especially if they're lifted with big tires. More weight, more wear.
  4. Apr 6, 2018 at 12:09 PM
    mudslinger79
    Christopher
    Williamsburg, Va
    I have powerstop calipers and am very happy with them. I'm still on my factory original rotors that have been resurfaced twice. Next time I need brakes I think I'm going with EBC pads and powerstop rotors.
  5. Apr 6, 2018 at 12:16 PM
    scpete24
    Orange County, CA
    @matluth I agree with you on the undersized comment, service manager saying it was the first I've heard of it.
    @mudslinger79 thanks for the reply, I was going to swap everything out this time but didn't think it was necessary with 24K miles. If they wanted to charge me for it I would have. Next time I need anything done with brakes, I plan on going with slotted rotors and better pads.
    mudslinger79 and Black Wolf like this.
  6. Apr 6, 2018 at 12:24 PM
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    I thought that I had "warping" issues really early with my Tundra as well. I did some research and found that rotors rarely warp - unless you really heat the eff out of them (and I mean causing a fire type heat). Or, they can wear unevenly over a long period of time (which isn't the case if you have only 24,000 miles). More often, there are deposit imprints from the pads after a hard stop that cause the "warped" sensation. Either that, or the brakes weren't bed properly from the get go. I have posted it several times in the last couple of days, but here is a long video that describes the process of bedding brakes. It is more for racers, but it does cover how to do it for street pads.
    After I did this procedure with my Tundra, I haven't had an issue with wheel shake under hard braking since. Hope this helps.
    https://www.youtube.com/watch?v=pdPX6rzuINc
    scpete24[OP] likes this.
  7. Apr 6, 2018 at 12:32 PM
    If the front rotors are continually subjected to excessive heat from a lot of down hill braking they can and will warp. Granted it does take a fair amount of heat over time to cause warping. My local dealer service manager said as much concerning the OEM rotors. Lots of better aftermarket rotors to choose from.
    mudslinger79 likes this.
  8. Apr 6, 2018 at 12:33 PM
    scpete24
    Orange County, CA
    Black Wolf likes this.
  9. Apr 6, 2018 at 12:46 PM
    Agitated1
    Agitated1 Newish Member
    Los Angeles
    2017 Tundra Crewmax TRD 4x4 Quicksand
    TRD Pro Grill King Coilovers with compression adjuster Tint 5% Rear, 30% front and 70% windshield Husky X-Act Floor liners BA Muffler 8in standard system Truck Covers USA retractable bed cover Yakima bed rails
    I came down from Big Bear a few weeks ago with my fam (2 2017 Runners and a 2016 Civic). All of us experienced bad shaking/Vibration. Once we got down the hill the shaking stopped. We all came to the conclusion that is was the road.
  10. Apr 6, 2018 at 12:54 PM
    TheBeast The Beach
    I replaced my rotors at 45K with stop tech. If you tow often and run oversized tires, the stock rotors dont like it
  11. Apr 6, 2018 at 12:59 PM
    Atomic City Tundra
    Devin
    New Mexico
  12. Apr 6, 2018 at 1:12 PM
    Stop Tech good!! (heat is not metals' friend)
  13. Apr 6, 2018 at 2:11 PM
    scpete24
    Orange County, CA
    Come down the front or back? I would agree with you on the road, but it was only when I hit the brakes.
  14. Apr 6, 2018 at 2:11 PM
    scpete24
    Orange County, CA
    Do not tow often, seems like consensus is to change out my rotors. Will do that next time
  15. Apr 6, 2018 at 2:17 PM
    scpete24
    Orange County, CA
  16. Apr 6, 2018 at 5:53 PM
    TheBeast The Beach
    keep the old ones though. they are oem toyota. you can probably resurface them.
  17. Apr 6, 2018 at 6:39 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I have always heard to avoid hard braking before a large water puddle. Something about the heat and then rapid cool down.
