Rotator Cuff Tear
Discussion in 'Off-Topic Discussion' started by Slayer, Feb 10, 2020.
  1. Feb 10, 2020 at 6:14 AM
    Slayer
    Slayer [OP] Member
    Slayer
    I fell down the stairs at work head 1st a couple weeks ago. Landed on my shoulder & back .. No broken bones.
    I Can’t move my arm at all without extreme pain.
    The Doctors are 90% sure I have a torn rotator cuff. An MRI scheduled tonight.
    Has anybody experienced this?
    how did they repair?
    Did you get back to 100% usage?
    How long did it take to recuperate?
    ..Slayer
  2. Feb 10, 2020 at 6:19 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    That sucks. Hope the MRI shows whats wrong.
    I have shoulder issues, but dont think its rotator cuff. Dont want surgery so I've never gone to find out.
  3. Feb 10, 2020 at 6:26 AM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    That is a rough one. MRI will tell it all. They have this surgery down to a science now, just make sure you get a good ortho that has done this bunch. Healing is a process and make sure you do as told and wear the immobilization/cast/nylon sling as directed. The rehab is what is going to make a difference it is a number if weeks and go to every appointment and do your exercises like they tell you to even when done. You have to do this to get full range of motion back in your arm so it doesn’t get all stiffened up on you. You should do just fine. Do your rehab and follow direction and keep up the exercises even when done. Best of luck to ya.
  4. Feb 10, 2020 at 6:26 AM
    browntundra77
    browntundra77 New Member
    Devon
    DMV
    2017 SBM Tundra Platinum CM
    Hope you feel better soon!
    Slayer[OP] and jewsNbrews like this.
  5. Feb 10, 2020 at 6:31 AM
    Black@Blue19
    Ken
    SE Texas
    Could be a bad Labral tear?? Broken Humerus?? Like I said MRI will diagnose the issue/s. Some super stitches and anchor it back in place and you will be right as rain!! Do Not Miss Rehab!!!
    jewsNbrews and NewImprovedRon like this.
  6. Feb 10, 2020 at 6:40 AM
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    yep. Had mine repaired Sept 2018. It sucked. 12 months after surgery I pretty much wouldn’t even know I had it. PT is key. Good luck.
  7. Feb 10, 2020 at 6:40 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Do whatever it takes to avoid surgery!
    I had a bicycle accident 30+ years ago and suffered injuries that resulted in a frozen shoulder about 10 years ago. Treatment for that condition revealed two huge bone spurs that were ground down via surgery. I have never recovered from this surgery...
  8. Feb 10, 2020 at 6:50 AM
    Deuxlatch
    Deuxlatch AirBus
    Chris (Latch)
    Tomball, Tx./Lafayette, La.
    2010 Super White Tundra CM
    TRD Supercharger, TRD Big Brake kit, MotoMetal wheels, Undercover Tonneau with dual swing out saddle bag tool boxes.
    I had shoulder surgery 2 years ago for torn RC and Bursitis. My RC was just frayed and not torn all the way through. 40 years of baseball/softball took its toll. Surgery was 1hr but coming out of anesthesia took 3. Dr told me to leave the sling on until the pain said I could remove it. Was actually tossing a softball the following week and by the next season (8weeks later) I was back slinging across the infield like I was back in high school, and I am almost 50. Do the rehab and try to keep the pain at bay.
  9. Feb 10, 2020 at 6:57 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    I know i should. I did go in and get examed. Doc doesnt think rotator cuff because i have strength when testing for it without pain. But i cant throw a baseball or softball anymore without pain. Sucks, both shoulders as i can throw left and right handed. Never been the same after my motorcycle accident.
    Slayer[OP] and NewImprovedRon like this.
  10. Feb 10, 2020 at 6:58 AM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    Been there, done that. I was in a sling for 8 weeks total, the first 4 was 24hrs/7 and for weeks 4-8, I could take the sling off around the house as long as I wasn't doing anything. Physical therapy sucked, but totally worth it bc other than a few scars (mine was orthoscopic so 4 total, 1 about 3 inches long, and 3 others about 1/2 long), it's like it never happened.
  11. Feb 10, 2020 at 7:05 AM
    Dswenson3423
    Dswenson3423 New Member
    Derrick
    Loudon, TN
    2018 Quicksand CM SR5
    I’ve torn both rotator cuffs from benching heavy. Just had my right done last year and have three anchors holding it in place and one metal anchor holding the bicep in place and it was torn as well. I’ll echo what others have said.
    Make sure your ortho has done this procedure many times and has a good reputation. Do EXACTLY as he/she says. Go to PT as directed and finish the program. It is very painful the first few months at PT as they will push you. I also did PT at home to help stretch it out. I’ve got about 90% of my mobility back and I’m happy with that.
    It sucks man, but I’m glad I did it. The pain from a rotator cuff tear is bad.
  12. Feb 10, 2020 at 7:10 AM
    CNE0207
    CNE0207 New Member
    Arvada, CO
    2020 Cement CM Limited
    Had mine repaired 3 years ago. Took off 2 months from the firehouse...Back to work. Took about 10 months to be back to 100 % and pain free. Do the PT every day religiously and let it heal.
  13. Feb 10, 2020 at 7:29 AM
    akmerle
    akmerle New Member
    Wasilla, AK
    2018 Tundra Platinum & 2024 GX550 OT
    Not sure about the availability in your area, but I went the STEM cell injections route to repair my shoulder let go (labrum SLAP tear, partially torn rotator cuff, and bicep anchor 90% detached). STEM cells were from me, taken via bone marrow extraction from my hips (by far the most painful process). I mainly didn’t want to have the bicep anchor relocated, and since the rehab time for everything was going to be up to a year. Also have seen and known too many people where their shoulders were never the same after surgery, and their procedures were just normal rotator cuff or labrum tears.
    Was back to jiujitsu, Olympic weightlifting, everything pain free within 6 months. There is a reason all the pro sports teams go the STEM cell route first instead of surgery.
    Was not covered through my insurance, but figured it was worth the risk. Then if it didn’t work, I’d just go the surgery route.
  14. Feb 10, 2020 at 7:42 AM
    Ditto. ^^
    Don't wait too long like I did. The longer you wait the more damage. I'm about 99% back to normal.
  15. Feb 10, 2020 at 7:48 AM
    cmack
    cmack New Member
    AZ
    2018 Burrito
    Tore my left one a couple years ago. Long and painful recovery - do your PT religiously
  16. Feb 10, 2020 at 8:23 AM
    Check me off as rotator cuff repair.
    - I lost a little range of motion.
    - The Physical Therapist is just as important as the Doctor you choose.
  17. Feb 10, 2020 at 8:28 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    I have been working in sports medicine for 20+ years now' lots of good advice so far. The surgery for these types injuries has evolved over the past 5-10 years. It used to be they had to open you up to fix it. Most surgeries nowadays can be accomplished arthroscopically. Get a surgeon who does a tone of these surgeries and one who has references. Don't take the "This is the BEST guy around" advice from others......do some research and ask for references. If you'd like some real world experience PM me and I will see if I have any contacts in the area. The real key to shoulder surgeries especially is the rehab. A good PT with knowledge of the surgeons protocol is worth their weight in gold. Happy to be of assistance of I can
  18. Feb 10, 2020 at 9:56 AM
    Fiesta346
    Fiesta346 New Member
    PA
    2013 Rock Warrior
    Look into stem cell therapy, could avoid surgery. MAKE sure your health ins provider would cover such treatment.. I know a few guys that had great results with knee and shoulder injury's using this method with NO surgery
    Slayer[OP] likes this.
  19. Feb 10, 2020 at 10:17 AM
    johnxmccoy
    johnxmccoy New Member
    Grove City, Ohio
    2019 Crew Max
    If it happened at work that's good.
    Get it looked and and enjoy your time off.
    Workmans Comp!
  20. Feb 10, 2020 at 10:27 AM
    johnxmccoy
    Grove City, Ohio
    2019 Crew Max
    I would never cheer someone getting hurt and I don't think that's what I did.
    Should be taken care of thru the OP employer.
  21. Feb 10, 2020 at 10:33 AM
    coTony
    Tony
    Montrose, CO
    I have had rotator cuff surgeries before. Pain in the ass for recover just because of the recovery time to get back to normal. If they try and make you go to PT "before" MRI (does not sound like your case since yours is tonight) DO NOT DO IT. This more times than not will make a tear worse, how else can you exercise with a tear and not make it worse (my first surgery they had me do PT first, never again).
    The stronger you are going into surgery the much better off you will be afterwards.
    Always push yourself within limits (I tend to go too far but have not had trouble yet) and listen to your Therapist.
    Homework sucks but not when it comes to PT, always do your exercises.
    DRINK PLENTY OF WATER
    Stretching does hurt but it is a necessary evil. Work with your Therapist to understand the feeling while stretching to make sure you are not going too far and not understanding the pain. Takes a bit to get the feel but once you do you are golden.
    I have had 3 rotator cuff surgeries (4 if you count the infection surgery caused from the pain pump in my first surgery) and I have 100% range of motion in both shoulders.
    Be brave soldier!!!
    Slayer[OP] and Rex Kramer like this.
  22. Feb 10, 2020 at 10:36 AM
    shawn474
    MoCo, Maryland
    If it happened at work, MOST DEFINITELY file a workman's comp claim. They MAY try to get you to see one of "their" providers. At the end of the day, it is YOUR decision who you see. They MAY try to say that they will only pay for a portion of another provider, but talk to your primary insurance company to see if they will make up the difference. They MAY do it. If they do not, you can always petition the workman' comp insurance company.
    Stem cell therapy, traditionally, will not work on full thickness ligament or muscle tears. I am of the opinion that less is more when it comes to surgery. The unintended consequence of not getting a rotator cuff tear fixed is the propensity to do further damage. You do NOT want to get frozen shoulder; do not want to have a multidirectional instability that causes another issue like a chondral defect or the like. I would get this looked at asap - an MR Arthrogram is likely the test of choice...….
    At any rate, good luck man. This IS a challenging recovery but well worth it in the long run.
  23. Feb 10, 2020 at 10:40 AM
    Northbound Train
    Northbound Train Masshole
    Glenn
    Western MA
    Black 2016 SR5 Double Cab 4x4 5.7
    Had my rotator cuff tear repaired a few years back. I don't regret it, no pain now and I got full use and range of motion back. As mentioned, if you do it, make sure you do the PT on schedule.
    Best of luck!
  24. Feb 10, 2020 at 12:07 PM
    tenntundra
    tenntundra 2013 SR5 crewmax Barcelona red
    Walter
    Tennessee
    2013 barcelona red sr5 crewmax TRD tundra
    3" suspension lift, BMF 20" wheels 305/55/20 nitto ridge grappler tires,painted RED bushwhacker fender flares,fold up tonneu cover,100 watt led fog lights,led interior lights,borla dual exhaust,tinted windows,window vent visors, Toyota hood protector,toyota step bars,spyder carbon fiber floor mats,k&n air filter,painted brake calipers red, installed red lug nuts on wheels remote start.
    I'm going to my orthopedic surgeon today to see when surgery is.I have a torn rotator cuff and upper tendon bicep tear.He wanted to do surgery 2 yrs ago and I put it off.the pain is so bad now that it has to be done.
  25. Feb 10, 2020 at 12:57 PM
    Rex Kramer
    Georgia
    If you must have surgery, follow this advice!
  26. Feb 10, 2020 at 1:05 PM
    Slayer
    Slayer [OP] Member
    Slayer
    yeah. I can’t do any of those motions.
    I can bend my forearm from the elbow only.
    I can pick my arm up forward with my other arm.
    Absolutely no movement to the side or rear with out intense pain. I wake up multiple times during the night in pain.
    good advise on the ice mixture.
    My Wife is on it with the ice 20 min on 40min off.
    I finished working the day when it happened & have been working every day since.
    I have one good arm to point & tell people what to do. Although if I have surgery. I will likely take some time off.
    ..Slayer
    NewImprovedRon likes this.
  27. Feb 10, 2020 at 1:07 PM
    ColoradoBoo
    ColoradoBoo New Member
    Rick
    2014 Red Toyota Tundra 4X4 TRD Maxcrew
    Firestone Airbags; remote starter; replaced stock mirrors with larger, pull-out mirrors for towing; hard plastic sectional cover for bed.
    I have a couple friends who had the surgery and both had great results. If you're a side-sleeper who rolls around a lot, getting a recliner that allows your lay back and sleep might be a good idea to avoid rolling on it while it's repairing. Yes, some crappy insurances require a person to go to PT before they will approve an MRI and if yours done, you have to go but do NOT let them move your arm around...tell them you will try to do what they want but just say, "Nope, hurts too much" if the movement is hurting. Tell them to show you what they want you to try and then try it...but don't hurt yourself. Best of luck and keep up updated!
    tenntundra and Slayer[OP] like this.
  28. Feb 10, 2020 at 1:09 PM
    Fellow at work totalled his rotator cuff. Had surgery with an Dr. that handles injuries for the University of Wyoming athletes. Was laid up for about 6 months, but he followed the doctor's instructions to a T and has better mobility in his repaired shoulder than his uninjured one.
    Slayer[OP] and CBrown like this.
  29. Feb 10, 2020 at 1:12 PM
    WellWater
    WellWater New Member
    2020 Tundra CM
    Been there done that.
    Here are my lessons learned about the whole ordeal.
    1. Doing PT before my surgery (and pre-MRI) likely made my issues worse
    2. MRIs are good, but not always precise enough to give you the whole picture of the issues you have. I ended up with a torn supraspinatus, bone spur, and torn labrum.
    3. Be 100% compliant with your PT after the surgery
    4. Use an ice-bath recirculator for your shoulder (pre and post surgery)
    5. Set reasonable expectations: I think your 100% target is around 2 years
    6. Important Add. After surgery, do not wait for your nerve block to wear off before you take your pain meds. I have had a lot of orthopedic surgeries and the pain from my RC surgery was by far the worst I have ever experienced.
  30. Feb 10, 2020 at 6:11 PM
    tenntundra
    Walter
    Tennessee
    Surgeon said rotator cuff repair, subacromial decompression,bicep tendonesis,and distal clavicle excision.feb,19 at KOC (Knoxville orthopedic clinic). Probably out for at least 2-3 months.I do remodeling and tile work. I'll visit a lot of friends and read a lot!!
