Rotational hum and vibration after 3”lift
Discussion in 'Suspension' started by upertij, Nov 22, 2022.
  1. Nov 22, 2022 at 8:11 AM
    upertij
    upertij [OP] New Member
    2014 tundra
    3” rough country lift, 20” fuel rims, 33” general tires
    I recently needed new struts but instead of replacing the oem struts and the leveling kit I hat, I had the rough country 3” kit installed with new UCA’s and diff drop etc. since the install, there has been a rotational hum and vibration from 35 and up that gets louder as u go faster. I replaced my tires as I thought that was the cause. The noise is tracking to the center front. The noise goes away when loading the right side so I assumed hub bearing. I replaced the hub bearing and the same noise and vibration persists. The shop that installed the lift has torn it apart and cannot find the cause. I thought the cv axles even with the diff drop were at steep angle but the shop says they are fine and the diff drop puts the truck in good geometry. Any help would be great.
  2. Nov 23, 2022 at 4:22 PM
    2mchfun
    Maybe the drivers side differential needle bearing. It may have been worn already and just became more noticeable after the recent lift. East Coast Gear Supply makes a bushing to solve this problem. Put it in 4H and if the noise stops, this is most likely the problem.
    Silver17 likes this.
  3. Nov 23, 2022 at 4:23 PM
    2mchfun
    BTW welcome to the family!
  4. Nov 24, 2023 at 6:45 PM
    Rugerla1
    Rugerla1 New Member
    Tennessee
    2018 Tundra TRD Sport
    did you ever figure out what your noise was?
  5. Nov 24, 2023 at 10:38 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Does the noise go away when you put the truck in 4WD?
