Rostra Seat Heaters - Relay Required?
Discussion in 'Canada' started by OB36, Oct 25, 2020.
  1. Oct 25, 2020 at 5:13 PM
    OB36
    OB36 [OP] New Member
    Installed pair of Rostra seat heaters with dual-dial switch kit in my 2013 Tundra (5.7L Crewmax TRD), looking for best place to connect accessory for 20A circuit. Otherwise do I need a relay - what would you recommend? Thanks
  2. Oct 25, 2020 at 5:39 PM
    Patch999
    Kyle
    TX
    2017 Bad@$$ TRD Pro
    I didn't use that type but, the Rostra's I used had a relay's with the kit. I used an add a fuse on my 15 and 17 in the seat warmer spot in the fuse box. Not sure if that's on a 13 but you should be able to search with a light and find a IGN source to use.
  3. Oct 29, 2020 at 1:22 PM
    OB36
    Thanks very much, I'll check the fuse box and see what I can find
