Roof Racks: Where is it safe to drill?
Discussion in '1st Gen Tundras (2000-2006)' started by TimSchaldach, Apr 28, 2021.
  1. Apr 28, 2021 at 10:05 AM
    TimSchaldach
    TimSchaldach [OP] New Member
    2006 Double Cab
    I need to install a single roof rack with crossbar using either a short track that goes in the ditch, or a fixed-point base. Either way, I am worried about where it's safe to drill -- don't want to mess with the sunroof or damage any electrical components.
    Does Toyota or anyone else have a diagram that shows the no-go areas in the roof of an '06 DC with sunroof?
  2. Apr 28, 2021 at 11:09 AM
    slowpokepete
    slowpokepete New No More
    Peter
    Hillsdale, NY
    2007 Blue Tundra DC 4x4 SR5
    Any chance you can find something that doesn't require drilling?
    I know Thule (and prob Yakima and others) make a cross bar that doesn't require drilling holes,
    SPP
    Joss1799 likes this.
  3. Apr 28, 2021 at 11:32 AM
    The Californian
    The Californian Good Vibes Only
    Eric
    2020 Super White Tundra TRD Pro Crewmax
    I'm sure @Victory4x4 is very aware of all of the "no-go" areas by now.
  4. Apr 28, 2021 at 12:07 PM
    TimSchaldach
    2006 Double Cab
    @slowpokepete: Good question. I currently use Yakima bases with clips that reach down between the door and the frame. Unfortunately, at highway speed, they cause too much whistling from the seal that gets squished by the clip. I have looked at lots of options, and am convinced that a "permanent" mount will work best for my situation.
    @The Californian: Thanks for the pointer to Victory4x4. I went back to the long and spicy thread you were referring to. Seems like the clear answer is to remove the headliner AND to use a drill stop. Then I should be good to go.
  5. Apr 28, 2021 at 1:24 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Our sequioa has a roof rack on top that's factory.
    No whistling at all until you put anything up there. Then it sounds like you're on the space shuttle Columbia.
    It also has no fairing so that may play a part in it.
  6. Apr 28, 2021 at 1:53 PM
    Sunnier
    Sunny
    San Diego, CA
    Wrong truck. OP is asking about a 1st Gen but your point is valid!
    OP the only “safe” way to know where to drill is to drop the ceiling liner and look. The Victory 4x4 fiasco taught us that every truck may be a bit different... so safest is to look and verify clearance before you drill.
    Edit: ah, man. I see you’re already up to speed.
  7. Apr 28, 2021 at 4:38 PM
    Cummins3500
    Cummins3500 Never finishes.....
    Logan
    Got my hopes up somebody was installing one of those spider roof racks for a double cab. It’s a drill to install unit.
  8. Apr 28, 2021 at 5:38 PM
    blackoutt
    blackoutt YEAH BUDDY!
    Indy
    07 DC Long Bed - Old Man Tan
    OEM+
    Here we go again.... at least it's not a 3rd gen.
    Drop the headliner edges slightly (easy) and drill away with confidence!
    des2mtn, Sunnier and The Californian like this.
