Rokblokz mud flaps - now w/ Installation guide/pictures
Discussion in '2.5 Gen Tundras (2014-2021)' started by BlueBottle, Jan 20, 2017.
  1. Jan 20, 2017 at 9:24 PM
    BlueBottle
    BlueBottle [OP] not a PRO
    '16 Platinum 4x4
    See fine print
    Anyone have these? Haven't seen it around much. Wondering how they mount/fit on a 3rd gen.
    http://rokblokz.com/toyota-tundra-08-13.html
    Edit * 2/27/17
    Rokblokz mud flaps
    Received the flaps. Fronts mounted fine but can not get the rears to fit on my 2016. Sticker on them says 07-13. Not sure if there were any differences in the liner from 2nd gen to 3rd gen....
    Edit * 3/26/17
    So I finally took some time to fit these mud flaps. Was able to make them fit to my satisfaction. I still think they are over priced for what they are as it is just a flat piece of ABS. Wish they molded it to properly fit our liner. Oh well, theres not much options for us with aggressive wheels/tires.
    Went to the store and purchased extra hardware to fit the rear mud flaps. They should have came with them.
    You will need 4x 1/4" x 1" stainless screws
    I was able to fit the fronts with the hardware they supplied but I trimmed the area where the cab mount is or else my tires would rub on it.
    Here are photos of the fronts installed
    On to the rears [you can see the inners screws are the ones that I used the longer screws on]
    Conclusion:
    They are good for what they are. To protect the truck from debris/projectiles from having more aggressive wheels/tires(Keeping the sides of the truck cleaner & scratch free). The way these mount, I can see them working with flares. Wish there were more options for our trucks but unfortunately these are the only options that I have seen.
    HulkSmurf14, Jsena and ColoradoTJ like this.
  2. Jan 21, 2017 at 9:41 AM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    I had these on my Tacoma and the quality and toughness were great. A little pricey for the Tundra. You should get them in lime green lol
    BlueBottle[OP] likes this.
  3. Jan 21, 2017 at 9:57 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Their website is a little confusing as far as which Tundra they'll fit. From their website....
    "MADE IN THE U.S.A.
    FITMENT:
    Each RokBlokz mud flap set for the 2007-2017 Toyota Tundra comes with 4 flaps, stainless steel mounting hardware, and instructions to fit factory hole locations for the 2008-2013 Toyota Tundra.
    Fits: '08-'17 Second Generation Tundra without fender flares. Larger option for Flares is available. Please email for info."
    They're calling 2008-2017 second gens basically.
    I would email them and ask them. A bit pricey for mud flaps though. $150 for a set of 4. Wow!
  4. Jan 21, 2017 at 10:11 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
  5. Jan 21, 2017 at 2:29 PM
    TheBeast The Beach
    some guys run them on their tacomas on TW
  6. Feb 24, 2017 at 9:13 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    So I ordered a set and they came today. Fronts fit but I could not for the life of me get the rears to fit! The sticker on them said 07-13!? I emailed them to see what's up.
    Newm, TheBeast and Wrongside like this.
  7. Feb 24, 2017 at 9:47 PM
    TheBeast The Beach
    keep us posted
  8. Feb 24, 2017 at 11:51 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Looks really good. How's it fit around the cab mount?
    HiFi1234 likes this.
  9. Feb 25, 2017 at 6:47 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    It sits in front of the cab mount. The flap is pretty wide. Theoretically, it will fit on someones truck with the CMC. Of course that is if you have enough space, the flap is pretty thick, I will measure it later but I would guess it is 3/16" thick maybe.
  10. Feb 25, 2017 at 6:19 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    They are 3/16" thick. And I still can't get the rears on..... frustrating.
  11. Mar 5, 2017 at 7:33 AM
    sk8142
    sk8142 New Member
    Shawn
    WA
    2014 Black Tundra TRD
    Bilstein 5100 F&R - Front middle setting w/2 CB shims Toytec rear shackles @ 1" setting Method NV 18x9 +25 Bronze 295/70/18 Nitto Ridge Grappler Retrofit headlights with Morimoto DS2 4.0, Apollo 3.0 shrouds, switchbacks Prodigy P3 brake controller
    Any updated on fitting the rears?
    I saw in your build thread that you cut up the rear flap from the front wheel due to rubbing. Did the front RokBlokz fit in place without removing that bit of the flap?
  12. Mar 5, 2017 at 7:44 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    The manufacture emailed me back saying you just have to apply more pressure but I haven't had time to play with them yet. They did confirm it should fit up to '17. I still don't see how but I will try again.
  13. Mar 5, 2017 at 7:50 AM
    sk8142
    sk8142 New Member
    Shawn
    WA
    What about the front? Are you still rubbing the front rear flap with the Rokblokz? I'm thinking about ordering a set because my front rear flaps are slightly rubbing in the same spot as yours were before trimming.
  14. Mar 5, 2017 at 7:52 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I took it off because it was rubbing. I know I can trim that part though just haven't had time to mess with them.
  15. Mar 11, 2017 at 4:14 PM
    sk8142
    sk8142 New Member
    Shawn
    WA
    @BlueBottle I installed the rear flaps today. I wasn't able to use the factory screws for the middle and upper inside mounting points no matter how hard I pushed the flap toward the mounting point so I went down to the hardware store and picked up some 1.25" stainless steel metal screw similar to the ones included for the front. Those made the rear install a piece of cake so give that a try if you haven't already.
    iamsmokey and NewImprovedRon like this.
  16. Mar 11, 2017 at 4:25 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Great job and thanks for the tip! Do the flaps sits straight even though the liner isn't? That was what I was afraid of even if I was able to get the screw in. How about the front? How does that sit for you?
  17. Mar 11, 2017 at 4:38 PM
    sk8142
    sk8142 New Member
    Shawn
    WA
    They have about 1/2" of adjustability Up/Down/In/Out so I was able to square them up pretty well. I'm a pretty picky guy when it comes to things lining up and I was happy with the outcome. I installed the front but had to take them off until I get my alignment done. I get a tad bit of rubbing so I'm hoping getting all the alignment settings dialed in will straighten things out.
  18. Mar 26, 2017 at 3:55 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Updated OP with fitting these mudflats w/ pictures
    Thanks to @sk8142 for the recommendations on getting longer screws - definitely helped. 1/4" x 1" are perfect for the rears. You will need 4 total.
    blue16 and Jasonly805 like this.
  19. Mar 26, 2017 at 6:26 PM
    sk8142
    sk8142 New Member
    Shawn
    WA
    Looks good man. Those will help keep the truck a bit cleaner.
  20. Mar 26, 2017 at 9:51 PM
    CCTundra
    CCTundra New Member
    Seattle,WA
    2021 1794 Tundra
    Bilsteins 6112 top setting, 0.5" Coach builder shims, 5160 rear shock with 3" Coachbuilder shackle kit. RB20 Step bars, Forged TRD Pro wheels, Back flip cover, Kennwood 10" Head unit, 2JL 10" Subs, Alpine 6 channel Amp.
    These look great. I think I am going to pick up a set of these for my truck. Is Amazon the best place to purchase these? Any ideas on prices?
  21. Mar 26, 2017 at 10:00 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    not sure. i just bought direct from their website.
  22. Mar 26, 2017 at 10:20 PM
    CCTundra
    CCTundra New Member
    Seattle,WA
    2021 1794 Tundra
    I will check out their website. Thanks
  23. Mar 27, 2017 at 8:08 PM
    CCTundra
    CCTundra New Member
    Seattle,WA
    2021 1794 Tundra
    Do you know if there are ever any promos on these? I was doing some research on this company, and it looks like from time to time they run like a 10 to 15% discount promo code for Subaru forum members. I am wondering if we might be able to get a discount code as members of this forum. I emailed them and are waiting to hear back. I would love to pass on a discount to all the members and myself. Regardless I am going to pick up a set of these for my truck
  24. Mar 27, 2017 at 8:18 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I am not sure. I think I paid full pop for them. It would be great if you could get a discount as I think that these are overpriced. Let everyone know if you are able to get a discount code. Doesn't hurt to ask!
  25. Mar 27, 2017 at 8:34 PM
    sk8142
    sk8142 New Member
    Shawn
    WA
    They are definitely overpriced but they'll protect my travel trailer while towing down gravel roads so it was worth it to me.
    ColoradoTJ likes this.
  26. Mar 27, 2017 at 8:36 PM
    ramonortiz55
    ramonortiz55 I don't Even Own A Tundra
    Ramon
    2001 4runner, 2015 tacoma
    I didn't know you guys had rokblokz as a tundras option.
    if I can get enough people interested, I can organize a group buy for you all
    NewImprovedRon likes this.
  27. Mar 27, 2017 at 8:44 PM
    CCTundra
    CCTundra New Member
    Seattle,WA
    2021 1794 Tundra
    Yeah, I will find out what they can offer me and the rest of the members of this forum. Also, What did you use to cut the mud flaps so they don't rub on the front? I might not have to cut them up front depending on how much room I have. I am running a 4" fabtech lift and running 20x9 +25 offset wheel with 305/55/20. It looks like I have plenty of room, but I will see.
  28. Mar 27, 2017 at 9:02 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    A dremel.. The mud flaps are made of some type of plastic so its super easy to cut. Depending on how close your tires are right now will depend if you will need to trim
  29. Mar 27, 2017 at 9:18 PM
    CCTundra
    CCTundra New Member
    Seattle,WA
    2021 1794 Tundra
    sounds good thank you. I think I will order a pair as soon as they get back to my email
  30. Mar 27, 2017 at 9:56 PM
