Rodents chewed through....
Discussion in '2nd Gen Tundras (2007-2013)' started by johnxmccoy, Mar 8, 2016.
  1. Mar 8, 2016 at 1:44 PM
    johnxmccoy
    johnxmccoy [OP] New Member
    Grove City, Ohio
    2019 Crew Max
    my e vap line from gas tank to charcoal canister. Dealer states i need to replace whole tank since the line is connected to a piece of grommet that is pressed in the tank. I saw the line and where the little bass turds chewed through.
    My question, can I splice a piece of tubing where the rodents chewed and seal it up pretty good ?
    Has anyone experienced this ?
    I really do not want to drive around with my CEL on all the time.
    Help please as they want $1600.00 to fix.
    Thanks.
  2. Mar 8, 2016 at 1:48 PM
    ToyotaTundraMike
    2015 Tundra
    If it isn't TOO bad, you may be able to slide some heat shrink tubing over it and melt it on to the original piece. Would have to be careful not to shrink it too small to where the line gets stopped up. If you can't find any other options it would be worth a try before you spent $1600.
  3. Mar 8, 2016 at 2:55 PM
    For 1600.00, a new Titan 46 gallon tank would be purchased and installed.
    Do you have pics of the damage? I have used bulkhead fittings on fuel systems with good results.
    NewImprovedRon and Black Wolf like this.
  4. Mar 8, 2016 at 4:26 PM
    So I must be blind. Where is the damage?
  5. Mar 8, 2016 at 4:27 PM
    johnxmccoy
    Grove City, Ohio
    2019 Crew Max
  6. Mar 8, 2016 at 4:29 PM
    johnxmccoy
    Grove City, Ohio
    2019 Crew Max
    You can not see them in the pic. When you bend the hose there are gnaw holes and that is throwing the code.
    This tube leads to the charcoal canister and where smoke was coming from on the test.
  7. Mar 8, 2016 at 4:41 PM
    johnxmccoy
    Grove City, Ohio
    2019 Crew Max
    What are your thoughts on flex seal?
  8. Mar 8, 2016 at 5:15 PM
    So the tank can't be used due to the hose? I would be attempting sealing that up myself.
    NewImprovedRon and MT Madman like this.
  9. Mar 8, 2016 at 6:07 PM
    swede78
    swede78 Not so new member
    Lars
    westminster co
    2019 tundra platinum mgm crew max
    Nothing yet
    what about black electrical tape or the liquid electrical stuff?
  10. Mar 8, 2016 at 6:12 PM
    Is that hose actually like in the picture or is that just a covering and a tube under?
    You could try some epoxy or something that will last. Electrical tape will not hold up to fuel vapor in my opinion.
  11. Mar 8, 2016 at 6:35 PM
  12. Mar 8, 2016 at 7:08 PM
    johnxmccoy
    Grove City, Ohio
    2019 Crew Max
    Nothing underneath. When I bend the tube I can see the small holes. Mechanic told me only vapors go through so no pressure on the line. I thought about splicing a small part where the holes are.
    Very tiny holes.
    Thanks.
  13. Mar 8, 2016 at 7:14 PM
    Ok. I would use epoxy and get an outdoor cat.
    We have squirrels that destroy everything. I was out knocking them out of trees yesterday with a hot pink pellet gun.
    MT Madman likes this.
  14. Mar 8, 2016 at 7:35 PM
    johnxmccoy
    Grove City, Ohio
    2019 Crew Max
    What type of epoxy? I have not had a lot of need for it until now.
    Thanks.
  15. Mar 8, 2016 at 7:36 PM
    Post number 12 John
  16. Mar 8, 2016 at 7:37 PM
    Mike Tread lightly.
    south carolina
    Use epoxy it resist fuel and fuel vapors.
    While the tank is down goto a home depot and get a thin sheet on metal bend and secure it.. Problem solved.
  17. Mar 8, 2016 at 7:59 PM
    johnxmccoy
    Grove City, Ohio
    2019 Crew Max
    Thanks.
    I need to see if this is available in stores locally.
  18. Mar 8, 2016 at 8:32 PM
    Mike Tread lightly.
    south carolina
    That I bet you will have to order that unless you have a aircraft repair shop local to you that will sell it.
  19. Mar 8, 2016 at 8:44 PM
    AMRE2ME2
    AMRE2ME2 New Member
    2016 DC 4x4 Limited TRD
    Why not splice in a new piece of hose with some inline connectors and hose clamps?
  20. Mar 8, 2016 at 9:50 PM
    Do you think that would work with the flex hose like that?
    Might be worth a shot.
    If it were me, I would be looking at online salvage yard sites or going to Titan tanks.
    It would also be my goal in life to have a rodent holocaust.
    NewImprovedRon likes this.
  21. Jun 8, 2018 at 10:54 PM
    Cerebus
    Cerebus New Member
    Philip
    2011 Tundra TRD RW/DC 5.7L, Magnetic Grey
    TRD SuperCharged, Rock Sliders, SkidPlate, 5100's Front, Add-a- Leaf rear, Bedliner, ToolBox.
    I would just wrap it with a premium brand of electrical tape from a home depot.
    You can even get it in your choice of color. If the CEL stays clear problem solved. I had a packrat chew an antilock brake wire and it affected my 4WD System. $300 repair.
  22. Jun 9, 2018 at 2:46 AM
    Adam New Member
    I wouldn't go with electrical tape John. It gets too brittle when cold, and breaks down pretty fast over time. You would need something a little better like permatex. It is ment for a oh shit repair like this. https://www.amazon.com/Permatex-82112-Self-Fusing-Silicone-Tape/dp/B00X8T3MVY
    Personally, I would use this as an excuse to get a bigger fuel tank like the others above. I would just tell my wife, "the mechanic said I had to buy a new one. WTF was I supposed to do?"
    Cerebus and Midnite72 like this.
  23. Jun 9, 2018 at 3:33 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Insurance claim. It would fall under comprehensive. Act of nature or act of rat.
    ardnutoz likes this.
  24. Jun 9, 2018 at 3:56 AM
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    2018 Black TRD OR CM Limited
    What he said... or,
    Use the sealant in post 11. I have a lot of experience using it. It should seal it right up and will withstand the environment its in. You need to follow the mixing instructions to the T or it wont set up right. The A2 version will give you a longer work time vs the A1/2. Follow the cure time and it should last a life time.
    If you go this route shoot me a message and i will explain how to properly mix it. You will need a tongue depressor and or an acid brush to apply it evenly.
    Good luck
  25. Jun 9, 2018 at 4:08 AM
    Professional Hand Model
    Hand Protectors
  26. Jun 9, 2018 at 5:25 AM
    Cerebus
    Cerebus New Member
    Philip
  27. Jun 9, 2018 at 6:51 AM
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    that tape will dry rot within a yr and need replacing... its great tape for protecting not so much for sealing and fighting gas vapors and the abuse of the environment. great for a quick fix get me home type repair, but not long term. we use a similar tape on aircraft and we are always replacing it in areas like the landing gear wheel wells where it dry rots.
  28. Jun 13, 2018 at 5:31 PM
    Tomcat
    Tomcat Ever see a motorcycle outside a shrinks office?
    2010 SR5 4X4 5.7 20" wheels Metallic Gray
    Bakflip
    I would be real careful about melting anything with fuel vapors in them.
  29. Jun 13, 2018 at 5:42 PM
    Uncle_Charlie
    Uncle_Charlie New Member
    2018 Tundra- Work truck package
    I did the same thing several years ago using a bit of fuel line and a couple small hose clamps to seal up a busted plastic vacuum line under the hood of my old chevy pickup. That repair is still in place.
    Adam likes this.
