Rockford Fosgate R2S 1-10
Discussion in 'Audio & Video' started by MikeyMTBs, Jul 4, 2017.
  1. Jul 4, 2017 at 3:40 AM
    MikeyMTBs
    MikeyMTBs [OP] New Member
    Is anyone running this box from Crutchfield? It has a single 10" and the dimensions look to fit based on TundraTex's box build.
    It is 3-1/4" deep on top and 5-1/4" deep at the bottom. Only issue is it is taller at 13-1/2" whereas Tex's is 12". He measures the seat back angle at 17deg, which means another 1" might be too high at 3.25" thick.
    Maybe worth a try....
  2. Jul 4, 2017 at 4:00 AM
    KrazieZ
    KrazieZ New Member
    Zachary
    2017 Toyota Tundra sr5
    K&n filter, leather seats, stubby antenna
    Build your own box that's what I'm doing
  3. Jul 4, 2017 at 4:02 AM
    MikeyMTBs
    Right. I could for sure. But, if this fits without the headache, great. I don't have a table saw either.
  4. Jul 4, 2017 at 5:34 AM
    KrazieZ
    KrazieZ New Member
    Zachary
    Yeah table saw helps , if you use chalk lines and good with a skilsaw you can build it
  5. Jul 4, 2017 at 1:16 PM
    xj2202009
    xj2202009 New Member
    x
    Lutz, Fl
    2017 tundra sr double cab v8 5.7L black 4x2
    looking to replace factory Radio with a pioneer avix588bhs
    That looks pretty similar to mine.. Mine is 12 p3 I have it behind the seat..it's a tight fit will need a grille
  6. Jul 4, 2017 at 5:46 PM
    Abrook
    Abrook New Member
    Savannah
    2016 Supercharged Tundra
    Magnuson Supercarger, bullydog gt, fuel cleaver wheels on 33 Terra grapplers, custom royalty core grill, rigid industries LED's(20,30, d-series), katzkin, bilstein shocks, spyder head & tail lights. spyder 3rd brake light, TRD sway bar, corsa exhaust.
    JL Audio makes aStealth box that will fit. Not cheap though but JL makes great speakers.
    That's the route I'm taking.
    MotoTundra likes this.
  7. Jul 5, 2017 at 6:48 PM
    birdman076
    birdman076 Bird, bird, bird...bird is the word
    Chuck
    Montana
    2015 Brown Tundra Crew Max Limited
    Airbox with K&N Filter, 2" lift on 33's, Alpine iLX-F309 head unit, Pull out bed tool boxes, brown with black trim, rims, etc, black leather interior, matching topper. Muffler delete (too loud..) 62k miles!!!
    Is this for DC or Crew? Got a DC here and Im going to get a 10 behind the damn seat come hell or high water!!!!
    MikeyMTBs[OP] likes this.
  8. Jul 5, 2017 at 7:12 PM
    MikeyMTBs
    Crewmax. Should have the box tomorrow and will report back the fit results.
  9. Jul 5, 2017 at 7:18 PM
    Harris1881
    Harris1881 New Member
    Oregon
    15' black CM SR5
    I do have it. It's not the loud since it doesn't handle a lot of power. I'm getting old so it's perfect for me. Adds a little extra sound. It's a pretty tight fit but did go in.
  10. Jul 5, 2017 at 7:18 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Have you done the rear seat back fold down mod?
  11. Jul 5, 2017 at 8:15 PM
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    What's that?
  12. Jul 5, 2017 at 8:27 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Free and simple mod allows DC rear seat back to fold down allowing access to the space there. I'm storing several ammunition boxes, first aid equipment, fire extinguisher, bivvy bag, tarp,& more.
    I'm not sure I attached the right link. If not, use the search function for "rear seat fold down mod ".
    https://www.tundras.com/posts/11902/
  13. Jul 5, 2017 at 8:34 PM
    birdman076
    Chuck
    Montana
    Not yet, going to do it when I pull the interior out to install the speakers, amps, LOC, sound deadener, wiring, etc.
  14. Jul 8, 2017 at 7:14 AM
    MikeyMTBs
    Ok, so I received the sub described above from Crutchfield. It's nicely built and the carpet is an exact match to the black CM carpet in my truck (not that it matters much).
    I started with the driver's side and while it went in, it needs to be in the middle to avoid the bar that stretches across the back of the larger, driver's side back seat. See pic.
    Pushing to the middle was a good fit but there was some minimal interference with the actual sub on the seat fabric. Maybe not a big deal but would rather it not touch at all.
    As I pulled the passenger side rear seat, I saw that it does not have the bar across the middle of the seat and that it is somewhat open in the seat back cavity. Hats good, but the jack bag is there. Easy enough to move to the driver's side.
    So, with some trial and error, this sub fits well behind the passenger side back seat and snugged up against the jack bag mount. The box itself can slide left right once seats are installed, so while its tight, it's not impeded.
    Went ahead and hooked up the 14g speaker wire and buttoned everything back up. I'll get back to the install in a few days.
  15. Jul 8, 2017 at 9:59 AM
    xj2202009
    x
    Lutz, Fl
    The description say seal but i see a vent..Could you kindly give us a verdict please?
  16. Jul 8, 2017 at 12:00 PM
    MikeyMTBs
    Hmmm.. I'm not sure what you see as a vent. I looked it over and it is a sealed box as far as I can tell.
  17. Jul 8, 2017 at 1:43 PM
    xj2202009
    x
    Lutz, Fl
    I think the eyes are playing tricks on this old man..I can't make out what that is5b6528baf82d86fdbeb7b54c72a6eb46_9c80ca6d0dcdfe96d34bf7cdaa3ce686d35f7e54.jpg
  18. Jul 8, 2017 at 4:11 PM
    MikeyMTBs
    Ah, now I see what you're looking at. There is a lip all the way around the edge. It is indeed sealed.
    xj2202009[QUOTED] likes this.
  19. Jul 9, 2017 at 5:45 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
  20. Jul 9, 2017 at 6:36 PM
    xj2202009
    x
    Lutz, Fl
    Does the bottom of your back seat bolts to the floor and back wall or just the floor?
  21. Jul 9, 2017 at 8:01 PM
    I bought my '14 Tundy CM used it came with a box but it has 2 - R2 10" sealed box sorry dont know dimensions of box
